Message on pad CE-09 keeps coming up. Cannot work pad at all. No sign of re-set button. We have a Spa Power 1000, 3.5 Spa was working, we emptied it and re-filled it. Then it would not start again. We turned it all off and tried again. No luck. Cannot find reset button. Had professional to look as well and he couldn't find it either. Please help
KOakaKO
  • 135 Answers
SOURCE: will not start
One thing you can try is to hold down on the power button and plug the unit in. Hopefully you will hear a "beep". Then you need to unplug it for a minute and plug it back in. This is a known procedure to clear error codes from the control computer on units similar to yours, so it might possibly work. Something else you can do is download and look through the Users Manual for your model, which is at this URL: --> http://www.haier.com/products/product.asp?proID=3632 Hope that helps! ;)
Posted on Aug 06, 2007
flexion1
  • 737 Answers
SOURCE: Casio CE-3700 giving E008 errors!
Hi.
Yes, it definitely is the CLERK function. When you enter 0 CLK#, you are just logging off (which has already been done), so that is normal for it to accept that. If you can't get in with 1 CLK# then I'd say someone has setup special codes for this machine (PIN numbers). You will need to do a prog. read. Also, if you have four raised CLERK buttons just below the keylock, one of them should be pressed down. (they are an option on some versions). Try 1 CLK# or 2 CLK# or 3 CLK# ... up to 7. If none will log you on, let me know, and I'll tell you how to do a read on it.
Mark
Posted on Jun 23, 2008
Krazytech
  • 725 Answers
SOURCE: Start light blinking
Test mode is Heated dry - Normal - Heated dry - Normal in 6 sec....
does it blink slowly or three time or fast or 7 times then repeat... let me know and I can help
Posted on Sep 14, 2008
SOURCE: GE Spectra XL44 Gas Oven, flashing "Locked Door". Can't use oven or close door
I had the same problem happen tonight. I have an XL44 self-cleaning gas range. We unplugged it for several minutes and pressed 'cancel' a bunch of times--neither worked. We finally lucked out--opened the oven door and pressed a black button on the upper left side of the front of the oven. It turned out the flashing words and unlocked our door. Weird. There was nothing in the manual about this...
Posted on Dec 28, 2008
dragonsthatk
  • 547 Answers
SOURCE: garmin c510 street pilot wont power up
http://www8.garmin.com/support/agree.jsp?id=521 please contact
Posted on Feb 26, 2009
Error code 09
During that 15 seconds, do you see the water moving in the spa?
If not then normally, that means the pump has not primed fully - hence the 09 Error Code. Pump could have a clog internally, but most likely problem, Dirty Filter.
Dec 31, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
What does error message E6 mean on a prompt set spa #jl017108?
I am having the same problem, not E4 but E6 error code and have to keep resetting it and about 15 min later it start beeping the error code again? Please help
May 21, 2012 | Pool & Spa
How to edit a player on fifa 09 wii
Hi. To edit your player you go to the main menu and then settings.then you go on to team management and pick a player by pressing (a). Then keep the button (c) pressed for 5 seconds and a editing chart will come up and you can make everything 99.
Feb 07, 2011 | Nintendo Fifa 09 for Wii
24th July 09, Eurovox 5401 AREA CODES PLEASE
5a01
AA B7 D1 D9 CE 8E 83 AF
8E 80 D7 EF 44 93 02 2B
Jul 24, 2009 | StarTech.com StarView SV211K 2-port KVM...
My printer, the Canon, Pixma Ip2000 stopped printing. It was giving me the message "the waste ink absorber is full". I took it to the only canon dealer in the city, and he reccommended that I replace the...
Reset Printer Canon IP2000 / IP3000
By pelda
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
http://freeresetterprinter.wordpress.com/2008/09/05/reset-printer-canon-ip2000-ip3000/
Mar 26, 2009 | Canon PIXMA iP2000 InkJet Printer
Need new codes for eurovoxmax need new codes dublin
codes for eurovox 5a01 6/5/09 aa b7 d1 d9 ce 8e 83 af a1 38 06 29 24 29 8d 2b should work ok bristol area
Jan 02, 2009 | Televison & Video
Reset ink level meter after refilling bj-w9000
At this stage we have found 2 ways that might work but not guaranteed to work with all machines.
Method #1
  1. POWER off printer
  2. Hold RESUME button then press and hold POWER, the beeper will sound once
  3. Hold POWER and release RESUME
  4. Press RESUME twice
  5. Release POWER button
  6. When the indicator light is steady press RESUME three (3) times. Indicator light should be orange
  7. Press POWER to set data
Oct 01, 2008 | Canon PIXMA MP160 All-In-One InkJet...
How do you set the clock/calendar on the Canon MP25DV?
on the bottom of your calculator is a reset button, with a paperclip or a pen press that button. Then, press the calendar, clock key. next, press the equal sign key until the date is flashing type in the date using 11172006. press the equal sign again and the date is set. Next press the calendar, clock key again the time should show up (12-00-00)press the equal sign again until the time starts to flash. enter in the time using 0903 (9:03) press the equal sign again. Time is set. to display the date and time when not using the calculator, press the calculator, clock key 2x's. to go to compute mode press the red CE/C button.
Nov 04, 2006 | Canon MP-25DV Calculator
Heating & Cooling Logo
166 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
