Pioneer RX-570 no power
Hey! My stereo won't turn on anymore. I took off the lid, found a blown fuse, and am attempting to replace it now but it isn't working. The blown fuse is a 6.3 A / 125 V but the guy at Radioshack didn't have that and told me a 5 A / 125 V would work. Suggestions?
SOURCE: POWER ON
yes
Posted on Jul 13, 2008
robotek
  • 1512 Answers
SOURCE: Blown fuses in a Pioneer RX-570
Hi sabackdoc
Ok, it is probably not an easy fix for a layman. It may have blown output transistors, or power supply failure. As to whether it is economic depends on what has actually failed. But if it is output transistors failed, be prepared for $130 to $170 to fix it. Probably not worth it. They are a little temperamental to fix, and I recall repairing a number of them under warranty when the were new for blown output stages. It is worth getting an estimate from someone near to you. Try and use a Pioneer agent as they have experience and access to spares. Sorry this is not a fix for you, but I hope that it turns out ok for you. :)
regards
Robotek
Posted on Aug 07, 2008
robotek
  • 1512 Answers
SOURCE: setting channels for am and fm on pioneer rx 570
Hi gbrokaw
Generally speaking, you select the station you wish to store, then depress and hold down the preset button you wish to store it to. After a few seconds, the screen will blink, and the will be station stored. On to the next one. Try this and see how you get on. If you have any problems, I am happy to help you help you sort it out. Cheers
regards
robotek
Posted on Nov 07, 2008
CAYPIANAN
  • 227 Answers
SOURCE: i have a pioneer Rx-570
hello my friend you have a short in the output ckt,also check the power supply for any damage(shorted) components. like diodes,caps,transistor.
but your main concern should be the audio output circuit.
caypianan@yahoo.com
  • 3 Answers
SOURCE: AR1 Subwoofer Keeps Blowing the 5 Amp Fuse
Well, so far so good. I reinstalled the newly repaired amp and fired it up and so far, so good. Ran it through about an hour of fairly intense break-in tracks and then ran it through about 2 dozen power up and down cycles to try to get it to fail (better now than a month from now and have to fight them on backing it up).
Posted on Nov 13, 2008
HELP PIONEER RX-570 NO SOUND
Check the connected speaker/s first. If found OK, the power amplifier section circuit inside the Amp: is faulty. Contact any service technician to get it repaired. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 12, 2015 | Pioneer Audio Players & Recorders
2004 sunfire
The best advice for a quick solution is for you to look at your fuse box. It should indicate right there what fuse is for the radio. If not, look at all of the fuses and replace the one that is blown.
Aug 31, 2014 | JVC AM FM CD DET FACE CAR STEREO
Fuse rx 570 pioneer stereo
Sounds like you have a much bigger problem than just a fuse. Popping sound and burning smell means something much more serious.
Jun 18, 2013 | Audio Players & Recorders
Hey I have a CRf 230f 2009 model just wondering why my bike won't start we found a blown fuse near the battery box and we have put another fuse in it but it still Won't start unless we jump start...
That blown fuse is most likely attached to a round thing with two big terminals on the top. That is your starter solenoid, it is possible that, that has failed.
Although it if starts off a jump start then it might be your regulator that is junk and isn't allowing your bike to fully charge your battery.
Sep 11, 2011 | Honda CRF 230 F Motorcycles
My unit does not turn on anymore
If no power at all then check the vehicle fuse box for a blown fuse. If all are well, there may be an inline fuse which would require pulling the stereo out and checking a fuse that is inserted in the wire just before the stereo. Another place may be a fuse that is plugged or screwed in to the actual stereo. Hope you find the problem. Good luck.
Apr 17, 2009 | Pioneer AVIC-D1 Car Video Player
I have a pioneer Rx-570 stereo the fuse blowout i replaced the same fuse but blowout again I wounder what is the cause for it
caypianan@yahoo.com
Nov 07, 2008 | Pioneer Audio Players & Recorders
Hi sabackdoc
regards
Robotek
Aug 07, 2008 | Audio Players & Recorders
Pioneer DEH-P3100 dead
The DEH-P3100 has an onboard 10 amp fuse which protects the whole package. I would not think that is blown, but it does have to have 2 power sources to operate. Usually one from the switch key & ACC and one with 12VDC at all times. The Red goes to the switch key and the Yellow to the continous 12VDC. One of these fuses may be blown.
May 04, 2008 | Pioneer DEH-P3100 CD Player
303 people viewed this question
 Grubhead
Grubhead
