Question about Admiral AAV7000A
Grinding sound When the Barrel is spining there is a grinding noise comeing from the base of the barrel. Sounds like maybe there is a coin lodged in there.
  • 1 more comment
  • Garvis Oct 04, 2008
    I got under the machine to locate the noise. I thought it was coming from the water pump. So I took it out cleaned and replaced and ran the machine again. Then relized the noise was coming from the gear case. Not sure what to do from hear. The machine is only three years old, four at the most. Is the gear case difficult to replace? Thanks for such a quick responce!!!
  • Garvis Oct 05, 2008
    Thanks you.
    Garvis
  • Anonymous Oct 05, 2008
    grinding sound
    Novelist:
    Champion:
  • 261 Answers
Hi Garvis, I see two possible issues with this machine. Either the pump bearing is out or a coin and or the gear case is failing.
Here is a good pic of the base;
Number 4 is your pump which is accesible by a panel on the back of your washer. I would pop this cover off and run the washer while examining with a flashlight watching out for the gear case in the center. Feel the pump for vibration matching the noise and check the movement of the tub to help locate the noise.
Posted on Oct 04, 2008
  • John Robbins
    John Robbins Oct 05, 2008
    The gear case requires two special tools to remove and replace. One is to release pressure on the brake spring at the bottom and the second is for the six springs positioning the tub and basket. I would get a warranty if possible and have it done, it will be cheaper this way. Some folks I have done these with have called Sears to get a one year warranty and the 250 or so you pay is around 70 to 80 percent of the cost.
  • John Robbins
    Your welcome,
    Any time.
When i turn my camera on it makes a grinding noise, displays an camera with red x
Power is fine, your case sounds like a jam or an obstruction by a foreign object in the lens (lodged between the extension barrels of the lens. This is an extreme situation and you need professional help, unless you are good at fixing things yourself.
Nov 03, 2015 | Cameras
My Whirlpool WTW6400Sw3 is making the loud noise during the spin cycle. There is no water leaking anywhere. I can freely spin the inner basket without any grinding noise or any other noises. Do I need
stator ? maybe? did u check for a foreign object in between the drum and barrel? sometimes a pc of something can get lodged and cause loud noises
Feb 11, 2015 | Whirlpool Washing Machines
How do I remove the agitator from LG top Load washer
the agitator is held by a bolt with a 7/16 drive nut located inside the middle of agitator from the top downward? however by ur description sounds like maybe u have bad bearing in the hub? the cam dogs in the agitator dont usually make any noise especially when bad they just dont allow the agitator to move or catch the groves to agitate. The grinding could also be coming from something stuck inside the tub or on its outside and thus is hitting the wall lining and makes a screeching scraping sound, Ive seen this several times, a bra wire, or loose coin or key, etc
Sep 28, 2014 | Washing Machines
The barrel on my hotpoint dryer is making a grinding noise-
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
May 01, 2011 | Hotpoint NBXR333GGWW Gas Dryer
Makes a noise when in the spin cycle. Almost like coins in the barrel only there are no coins in the barrel. Or sounds like it is trying to change gears and grinds.
Welcome to FixYa.
Based on what you've described, sounds like a worn tub bearing unfortunately.
To check it, remove the agitator assembly inside the tub, once it's off. take the tub assembly and move it side to side to inspect for "play" in the bearing. This will explain the bad sounds and the grinding...I bet it doesn't spin the items out very well either due to too much vibration sensed to maximize spin.
Let me know what you find and I'll try to help you move forward from here. I can provide more detail with pictures if necessary.
Regards,
Macmarkus :)
Mar 12, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Dryer sounds like metal to metal while running and clothes get stuck between barrel and housing
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The barrel makes a rubbing squeeking sound as it turns. Sometimes it is really loud and other times it doesn't make the noise.
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up
May 20, 2010 | Dryers
When you use the sewing machine it makes a grinding noise
It sounds as if a pin or some small object may have slipped down and gotten lodged in the workings of the sewing machine. This could become a serious issue if it is not remedied. Remove the bobbin area cover under the sewing foot to look inside. If the noise is coming from one of the completely encased areas on the right side of the machine, there may be a problem with the gears rubbing against each other (disalignment). If this is the case, and the machine is still under warranty, I would return it to the place where you purchased it. If not, I would try to take a look and see if anything is lodge in the workings. Grinding noises are not good when it comes to machinery.
May 03, 2009 | Singer 8280 Mechanical Sewing Machine
Grinding Noise when Washer Attempts to Spin
It is probably the same problem because it is trying to drain during the spin cycle. My machine sounded as though a chain wis clanking, the solution was removing a coin caught in the drain pump. Access the pump from the bottom of the machine. 4 screws hold the mounting bracket on undo those, the electrical connection and two hose to the pump. Undo three screws holding impeller to motor and coin can fall out. Examine for damage if it is not too tore up, put back together. Keep in mind that when you unclamp the hoses that water will come out.
Feb 02, 2009 | Maytag MAH2400A Front Load Washer
Admiral AAV7000A Logo
141 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
