Question about Lands Phones
Why does my panasonic phone cut off
I have a panasonic digital phone that cuts off at least once a day. No reason. the phone is connected with a modem to my computer, the phone is kx-tg1033s. ICan you suggest why this happens?
5 Suggested Answers
cnavarro
  • 2460 Answers
SOURCE: I have a Panasonic KX-TG7210ET
I think something is broken.
Try unplugging all phones and see if it still trips the ring. If it does, you have a wiring problem if not, probably a bad TG set.
Carl
Posted on Aug 26, 2008
SOURCE: panasonic answering machine not working
We had the same problem. Unplugging the unit and restarting it again solved the problem.
Posted on Mar 03, 2009
  • 131 Answers
SOURCE: PHONE CUTS TO MESSAGE AFTER 2ND RING. I WANT IT
if answering machine is on phone , go to messaging menu it should have a setting for number of rings... make sure toll saver option is off!
Posted on Nov 09, 2009
SOURCE: Panasonic KX-TGA641 handset - the
After following the instructions in the operating instructions manual multiple times, I called Panasonic at 800-211-7262. I spent at least 10 minutes with support and what it came down to was unplugging the original base unit and taking the batteries out of the new handset. Then we followed the same directions and it finally worked. Should have known to unplug to reset, seems to be the case on every piece of equipment these days. Good luck!
Posted on Sep 14, 2010
I keep on getting cut off the internet. i get back on then i get cut off again. i have new filters where the phones are. The 2nd from the bottom light turns red. and i am hard wired to the 2wire059. how...
hi good day,
i do believe that you got that router from your internet provider?
what i can suggest is have them replace the modem because it's not normal for that modem to cut your connection more often. call your isp now.
May 11, 2011 | 2wire (2701HG-B) Wireless Router
Why does my internet connection always cut off?
There are severals reasons why your internet connection cut off.
1. Faulty DSL modem - check your modem -> overheating?
2. Check Cable or telephone line connection defective.
3. ISP connection inconsistent -> check with your ISP provider.
4. PC infected with Malwares, spywares, virus & others dangerous objects -> scan and clean PC.
Do the above troubleshooting.
Oct 08, 2010 | Microsoft Computers & Internet
Internet connection cutting out intermitently
1. check the current firmware updates
2. verify no other devices next the the router interfering with the signal i.e. cell phones, cordless phone, microwaves, TV sets.
3. check your router or cable modem for connection during time the wireless is dropping connectivity.
Apr 25, 2010 | D-Link DIR-615 Router
Cox says my SB5120 is resetting 12 pulse times a
May be firmware get corrupted due to power-cut or an excess voltage or surge problem.
At times when there is thunder-storm a lot of excess volatge is generated on the phone wire which is link down to the modem
Ok
try to download recent firmware from manufacturer and see if it can be updated.
Cheers
Uttam
Jan 14, 2010 | Arris SURFboard SB5120 Modem
My phone cuts off laptop wireless
Wifi typically operates in the 2.412Ghz - 2.472 Ghz depending on the channel selected. ideally the Wifi modem/router and the DECT phone should be operating in completely different bandwidths.
If your DECT phone is cutting off your Wifi wireless connection, then they must me operating in similar/same range: you need to change either your Wifi or DECT frequency 'channel' to minimize this interference.
Also make sure that there is a least 3 meters between the DECT base station and your Wifi modem/router to eliminate Transceivers static RF/EMF interference.
Hope it helps: let me know how you go.
Jan 12, 2010 | Uniden Cordless Phone
Linksys speed cut off
First, are you connected via Ethernet cable or are you linking via Wi-Fi? If Wi-Fi the speed is alway slower (up to 54 Mps) If connected by Ethernet, your connection speed should read 100 Mbps. Once you have determined the connection mode and speed.unplug the wireless router and connect the computer directly to the modem. Now test the speed and see if the speed lag is still ther. If not, you have a routing /networking issue but, it it is still the same speed, it could very well be heavy traffic ( a lot of people drawing from the same local area signal., usually at specific times of the day).
Nov 24, 2009 | Linksys Wireless-G WRT54GL Router
I have Vonage phone, and TimeWarner cable. My
Remove your router for the vonage equipment. Direct connect to modem. Does your internet ****? If yes its TW issue. If no its Vonage issue. Try it for a day
Hope this helps!
john
Oct 03, 2009 | Computers & Internet
My internet cuts out when i am on the phone. we
Sounds like your filter is kaput...
Filter MUST be on the line to your phone. The line to the modem/router must NOT go through the filter.
Make sure EVERY phone connection has a filter on it. Do you have Foxtel or back-to-base alarm system? Everything needs to be filtered.
If it previously didn't drop out, and you haven't done anything to make it happen, replace your filter with a new one. Do yourself a favour, buy a C10 Communications filter... you can pick up a Jackson filter for about $25... they are one of the best out there.
Sep 06, 2009 | Belkin Computers & Internet
How Do i connect i tried once all the settings were correct also check with the IPfor some reason it show the connection but fails to run tes
Well, on my screen, your subject cuts off after the word 'were' so can't tell you much there. First thing to try is unplug both the modem and the router. Wait 30 seconds, plug in the modem. Another 30 seconds later plug in the router. After a minute or so you should be good unless there's a configuration issue. If so, reply and we'll walk you through it.
Ben
Sep 17, 2008 | D-Link AirPlus DI-524 Wireless Router
I have a Panasonic KX-TG7210ET Quad set. For some reason when anyone phones the house the phone rings once and cuts off the call, usually before I can get to it. Also the Caller ID which used to work...
Carl
Aug 25, 2008 | Panasonic Lands Phones
Lands Phones Logo
336 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
