Question about Maytag Washing Machines
Maytag MAF1300AAW Error code 4. The machine starts to fill then drains which is repeated several times before eror code 4 appears.
    Novelist:
    Champion:
  • 261 Answers
Hi this searstechtoo I did some research on similar american models and will paste what I found for you.
Will Not Lock
• Door not all the way closed or not properly
aligned. Possible laundry load is too large to
close door.
• Place washer into Service Mode and check for
diagnostic codes 4 &18.
• Perform Board Output Test. Check door lock
system.
• Check electrical connections at lock switch
assembly and machine control board (CN2).
Cn2 is a thermistor used in a wax motor to control the lock and unlock feature of the door.
I would start at the lock and trace the wires then unplug and replug them.
Thanks SearsTechToo
Posted on Oct 04, 2008
LF appears after my maytag front loader is washing for about 4 min. We took the screens out, cleaned out and swapped ends of hoses from washer to the water valves. Still not working. Washer only a yea
LF means long fill....if the flow meter does not detect
the correct amount of water entering the machine the
code will appear. Google Maytag front load washer
LF code...there are several links including a video
that should help you solve the problem.
Regards,
Dennis
Oct 05, 2014 | Maytag Washing Machines
Code nd
Don't know if this is your problem but sometimes ours will appear to drain, but there is still a lot of suds that remains and trips the nd (no drain) indicator/lockout. We had to pour water in from a bucket to beat down the suds, then repeat several times to get all the suds out. First time I took off the back of the washer, disconnected the pump, then let the suds out. To much work.
Nov 11, 2013 | Maytag MAH6700AWW Neptune Front-Load...
Maytag washer throwing fault code 21
An "F21" or "F02" error code is indicative of a slow draining cycle, normally caused by a clogged or kinked drain hose. If an "F21" or "F02" error code appears, check the drain hose on the back of your washer to ensure that it is not clogged or bent. Once the drain hose has been unblocked, the error code should disappear and the machine drain properly. However, if you have a high efficiency washing machine and the error code continues to appear, make sure you are using the correct detergent; because high efficiency machines use much less water than traditional washing machines, they require the use of a low sudsing detergent. Traditional detergents may produce too many suds, which can block the machine's drain hose and lead to slower draining cycles.
May 20, 2012 | Maytag Washing Machines
I have a Maytag MAH-24 Washing Machine showing a 5E error code
You will have to contact Maytag and speak to their service dept and give them your model number. Ask them what a 5E eror is and when you call for service, tell the repair facility what Maytag told you. That will next to eliminate labor cost for Diagnostic.
Apr 17, 2012 | Maytag Washing Machines
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Apr 03, 2011 | Maytag Dryers
Error code Lr
locked rotor you need a new motor control
Oct 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Apr 28, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Maytag Error Codes
Appreciate the direct "Ask Me". Apologies for delay in responding due to regional/time differences.
To my knowledge no, specially on a new unit. On similar incidents, it would appear that multiple error could stem from incorrect connection to the water supply. You could try bypassing the error codes by selecting "Extended Fill" option.
Pls reference this page for additional insights.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 20, 2008 | Washing Machines
Wont work, flashes LR
rapoyner The "LR" error code means "locked rotor". It appears on the display after the machine has repeatedly tried to turn the motor. The cause of the problem could be the motor itself, the motor control board, the main control board or the wiring. If your washer is less then five years old most likely the parts are still under Maytag warranty. It has very sophisticated design and I wood recommend to call the Maytag authorized repair man even if the warranty is already expired. Gendos
Jul 06, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
154 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
