Casio FX-115ES Scientific Calculator Logo
Posted on Oct 04, 2008
Binomial distribution How to calculate probability of a binomial function
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jan 26, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
4284
Points
14
1helpful
Texas 30XIIB binomial cdf
The only known equation for the cumulative binomial distribution is the sum of the individual binomial probabilities. Some more sophisticated (and more expensive) calculators have that equation built in, but the 30xii does not.
If n>30 and n*p>5 and n*(1-p)>5 then you can approximate the cumulative binomial with the normal probability function, but again the 30xii does not have that built in.
1helpful
The number of combinations of n objects taken r at a time has a reserved symbol nCr. On calculators it has a special key (or shifted key) marked nCr.
By definition nCr=(n!)/((r!)*(n-r)!)=nC(n-r)
In what follows, I am using parentheses to enclose what is in the denominators). So
10!/(8!2!)=10C2 or 10C8 =45 (they have the same value)
10!/(9!1!)=10C9=10C1=10
10!/(10!0!)=1
Binompdf binomial binomcdf
Do you have a question about the binomial probability distribution function or the binomial cumulative distribution function?
Probability distribution n=2 x=2 p=.80 P(2)
There are a lot of probability distributions: binomial, chi-square, F, normal, poisson, and t, just to name a few. Do you have a particular one in mind?
2helpful
Binomial function
The binomial probability distribution is defined as
P(r;p;n) =(nCr)(p^r)*(1-p)^(n-r)
where n is the number of trials, p the probability of success, and r the expected result.
Let n=20, r=7, p=0.15 ( I do not know wether this exemple has any meaning in the context of your problem, but you have to enter values that mean something to you. I am only showing you the key strokes
To enter 20C7 you press 20 [SHIFT][nCr]7 ;
To enter 0.15 to the power 7 you type 0.15[X to ] 7 the key is between
[x²] and [log]
To enter (1-0.15) to power 20-7, you type 0.85 [X to] 13
With [*] standing for multiplication key , and [X to] the raise to power key, the exemple above can be entered as
( 20 [SHIFT][nCr] 7) [*] ( 0.15 [X to] 7 ) [*] ( 0.85 [X to] 13 ) [=]
Here is a screen capture to show you what it looks like. However on this calculator the combination 20 [SHIFT][nCr] 7 is represented as nCr(20,7).
Hope it helps
5helpful
3answers
Binomial function in calculator fx-911ES
[x²] and [log]
Hope it helps
4helpful
I was told that, to do binomial distributions on a ti-86, I would need to hit 2nd Math, then More, and I should see something that says STAT and go from there to get to DIST and Binomi. I see nothing...
Sorry, but you information is wrong, to find the binomial distribution use the PROB menu not the STAT menu. Its name is randBi
[2nd][MATH][F2:PROB] scroll right.
Hope it helps.
3helpful
Error message with binopdf function
Yes, eleven million is rather extreme for the binomial distribution. For this large a value the binomial distribution is sufficiently indistinguishable from the normal approximation.
10helpful
2answers
BINOMIAL DISTRIBUTION
Let us start with a review of the formula for the binomial distribution
f(r;n,p)=n!/(r!(n-r)!)x(p^r)x(1-p)^(n-r)
But n!/(r!(n-r)!)=(nCr) you get
f(r;n,p)= (nCr)x(p^r)x(1-p)^(n-r)
Exemple : n=25, r=6, p=0.7
f(6;25,0.7)= 25 [PRB] [-->] 6 [ x ] {0.7[ ^] 6 }[ x ]{0.3[ ^ ]19}
The arrow means a horizontal scroll once to select the (nCr) function. [ x ] stands for the multiplication sign.
[ ^] is the raise to the power key
The { } are used here as parentheses to make formula legible.
Hoe it helps
Hope it helps
Hope it helps.
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
