Question about Philips 60P8341 60" Rear Projection Television
Fuzzy, washed out screen - fix was change crt coolant
What is this coolant and how is it changed? Philips 60" projection screen, 6 yrs old.
  • Philips Master
  • 3,459 Answers
A common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
fuzzy, washed out screen - fix was change crt cool - bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Jun 06, 2010
How hard is it to change the cooling fluid in phillips projection tv.
The CRT coolant change is all mechanical which involves removing the crt and disassembling the coolant chamber so it can be cleaned then reassembled and filled with coolant the phillips CRT coolant kit from www.tvrepairworld.com has the coolant and the instructions for the repair on cd
Jul 31, 2011 | Philips 60PP9352 60" Rear Projection...
Good picture but its still fuzzy looking
Classic sign of the CRT coolant needing replacement. You can get the Phillips CRT coolant kit from www.tvrepairworld.com the kit contains the coolant and the CD with instructions.
Sep 29, 2010 | Philips 60PP9363 60" Rear Projection...
I just bought it and it is fuzzy and all the white has a glow around it
U bought this tv used right,hope u pay it cheap?Ur tv have CRT coolant porblems.It have CRT coolant contamation,must replaced the coolant.Tries Websites Tv repair World.com,Tvrepairkits.com to buy the CRT coolant kit to replaced.
Mar 30, 2010 | Philips Magnavox 9P6034C 60" Rear...
Blue fuzzy haze. guns need to be pulled and cleaned
Need to replace the CRT coolant. You can get the phillips CRT coolant kit at the following link. The kit contains instructions plus the coolant.
http://servicemanuals.vstore.ca/
Sep 30, 2009 | Philips Magnavox 9P6034C 60" Rear...
Philips 60 inch rear projection screen is wacky!!
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 10, 2009 | Philips 60PP9202 60" Rear Projection...
60" Projection Tv - Approx 6 yrs old
Your CRT fluid needs to be replaced. After many years the crt cooling fluid gets a ton of alage built up in the tubes.  This will cause the screen to get a halo effect or get darker.
You only need to replace the fluid in the blue and green tubes.
Dec 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips 60
First of all,this is a major labor intensive repair on Philips TV's changing the blue CRT because the new CRT does not come with the coolant that is sealed between the lens and the tube.If you have never done this type of repair before you should not attempt. Changing the convergence board is one thing (you can solder in two STK392-120 IC's and repair the board instead)
but changing the CRT's can be a nightmare.If you are brave go to PARTSTORE.com and get the parts $600+ (I would order the service manual too...you will need it)
Aug 27, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 50P8341 50 in. Rear... Problem:
You CRT coolant needs to be replaced, its a very common problem with the phillips and magnavox projection TVs. If you need more info on the Coolant Change let me know.
Jul 14, 2008 | Philips 55P8341 55" Rear Projection...
60 inch phillips magnavox projection tv
CRT coolant change and advanced convergence - how to
I documented the procedure I did on a Philips 55" rear projection 55p916
http://tinyurl.com/lmp6eu
CRT coolant change procedure
http://tinyurl.com/l7bd7r
basic and advanced convergence
Dec 24, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips 60P8341 60" Rear Projection Television Logo
103 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
