Question about Lexmark X2350 All-In-One InkJet Printer
Printer wont load paper
The exact error message is called align the cartridge, and the first thing it tells me to do is print the allignment page and then the next step is to scan the allignment page.
  • kdog0588 Oct 04, 2008
    no message came up,my printer still cannot print anything,i have looked at the print rollers,turned those and the printer is still a piece of ****,do you recommend any places in corvallis, oregon, 97330 around this area, i have a car so i can probably drive an hour out of my way to get my printer fixed.thanks
    Genius:
  • 3,422 Answers
To align the color cartridge, simply try taking the cartridge out, and putting it back ini. Most often on Lexmark printers, this will bring up a message asking if your cartridges are new or old and of what number they are. after this menu you will likely be forwarded to a printing alignment page
Posted on Oct 04, 2008
My printer error message indicates- Alignment problem.(1) Remove tape from cartridges.(2) Check Paper.(3) Press Ok to retry. I do not see it being easy to remove tape from cartridge,but my allignment paper...
Make sure you are using the correct cartridges for your model. Try to remove both the cartridges. Close the cover. Unplug and replug the printer into the power outlet to reset itself. When the printer turns on, reinsert the cartridges when prompted. Close the cover and check for any error. If none, try to print again.
Apr 11, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
Hi. I cant get my printer to allign. I've just replaced the black ink cartridge and when i put the allignment page inside the scanner it wont scan
Did you try to align the unit manually or with the computer?
Alignment page does not print
1 Make sure you remove the sticker and transparent tape from both print
cartridges.
2 Make sure the color print cartridge is secure in the left carrier and the black
print cartridge is secure in the right carrier.
3 Make sure you loaded the paper correctly and did not force the paper into
the printer.
Aligning your print cartridges without a computer
Make sure you follow the steps on the Setup sheet to complete hardware
installation. Continue with the following steps to optimize print quality.
1 Make sure you have loaded paper into the paper support, and then press
and hold Scan for three seconds. For help, see "Using the control panel"
on page 4.
An alignment page prints.
2 Place the printed alignment page onto the scanner glass.
3 Press Scan. For help, see "Using the control panel" on page 4.
Once scanning is complete, your print cartridges are aligned for optimal
print quality.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Nov 15, 2010 | Lexmark X2550 All-In-One Printer
HEEEEELP PRINTING PROBLEM
check your printer paper alignment. some times when the paper is out of range the head cannot find a place to print it and reports it as out of ink error. But actualy the problem will be with the sensor that alligns the paper automatically for you. you must manualy align the paper and in word go to page setting do all setting manually and try printing.
Dec 09, 2009 | Epson Stylus DX4200 All-In-One InkJet...
Printer will not print after reinstall of software to macbook
yes ..if the sensor detect that there's is no ink or low ink..it display an error on the screen ..
to determine the status of the ink..
goto your desktop ..
click the printer driver software and select ink status..
good luck.
May 20, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp2210 message ''press enter to align cartridges'',
from user manual::
To align newly installed print cartridges
1. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
The HP All-in-One prints a print cartridge alignment sheet.
NOTE: If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
If the alignment fails again, you might have a defective sensor or print cartridge.
Contact HP Support. Go to www.hp.com/support. ....
2. Load the print cartridge alignment sheet print side down on the left front corner of the glass with the top of the page to the left.
3. Press the Scan button.
The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet
Score the solution and download the manual if you need it
Mar 24, 2009 | HP PSC 2210 All-In-One InkJet Printer
I changed the black ink cartridge as per instructions and the printer printed an alignment paper which i then placed in the printer for alignment but the alignment failed
the page should be absolutely new.and the scanner glass should be absolutely cleaned.and 1 main thing u replaced your black cartridge.but if your colour cartridge is empty it will not accept the allignment complete thing.it will show allignment failed as the particular colour is missing in your allignment sheet which is required to get the allignment complete.
Nov 23, 2008 | HP Office Equipment & Supplies
Do not see align or clean catridges at preferences /features
hi,
To Align the cartridges, please perform the following instructions.
  1. Load unused plain white letter or A4 paper into the input tray.
  2. Press the Setup button.
  3. Press the down arrow button to select Tools and then press OK .
  4. Press the down arrow to select Align Print Cartridges and then press OK . An alignment page prints.
  5. After the success or failure message displays, click OK to continue. Recycle or discard the alignment page
Regards,
Sagarjd
Nov 21, 2008 | HP Photosmart C4180 All-In-One InkJet...
Would not print C5280 Flashing Failure Print Cartridge allignment
Solution
  4. Press the down arrow to select Align Printer and then press OK . The unit prints a test page, aligns the printhead, and calibrates the printer.
  5. After the success or failure message displays, click OK to continue. Recycle or discard the alignment page.
Cause An incorrect type of paper is loaded in the input tray. If you have color or photo paper loaded in the input tray when you align the printer, the alignment might fail.
Nov 04, 2008 | HP Office Equipment & Supplies
Align page message
I have an OfficeJet 5780 and I have to do the alignment also. The allignment page it prints should have instructions on it. Just put it in the scanner and press "Enter". It needs to scan it to align the print heads.
This is from the manual on their website:
The HP Officejet prompts you to align cartridges every time you install or
replace a print cartridge. Aligning the cartridges ensures high-quality output.
To align the print cartridges when prompted:
1 Press Enter on the front panel.
An align cartridges (test pattern) page prints.
2 Load the align cartridges page face down in the ADF between the paperwidth
guides and press the Enter button again.
3 Recycle or discard the page.
Geno
Feb 21, 2008 | HP Officejet 4110 All-In-One InkJet...
Lexmark X2350 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
