Question about Dishwashers
The door springs broke. I got new ones but don't know where to hook them to the frame from the door hook.
  • 943 Answers
Hi .thanks for the question . sometimes you have to un install the dishwasher, just a bit, to rep[lace the springs. remove the screws that anchor the dishwasher, pull out the dishwasher just a bit ,till you see where the springs attach to. thanks the appliance doc
Posted on Oct 04, 2008
My door to my Samsung microwave stopped latching. Model number Smh1611s. It still works if you hold the door closed. What parts do I need.
Where the tab broke off drill a small hole about 1/8 in hook spring back close back frame. no new part needed
Apr 12, 2015 | Samsung Microwave Ovens
How to fix latch/ spring on door
Brand and model would help but here is the most common way to fix. There is a plastic frame all the way around the inner door which should have the 2 holes in it that the latch hooks come through. That frame usually needs to be gently pried away from the door. Use a small blade screw driver and be careful because it is brittle and will crack easily. Once that is removed, you should see the latch and spring system. springs are usually attached over a small hook on the door and one on the latch hook.
Apr 04, 2015 | Microwave Ovens
Can I fix a broken garage door extension spring myself ?
Yes you can!
Raise the door all the way. place clamps or vise grips on the frame to keep it safely up.
Very carefully, remove the unbroken spring and get a pair of new ones from the nearest overhead door company.
Install the new springs and then and only then remove the clamps.
Jul 13, 2014 | Building Materials
Emerson microwave door latch
I have an Emerson MW8999RD that all of a sudden yesterday wouldn't latch. I don't think you have to, but I took the door off (three screws hold the case on which needs to be removed to get at the top hinge). Then I took off the inner plastic picture frame - pretty easy with a thin blade to move the fragile tabs. Then I removed the metal frame that has the little microwave blocking holes. This was the hardest part because the plastic retaining tabs are even more fragile and I broke one. Then I found the loose spring due to broken plastic hook as described above. I was able to make a new hook by simply looping a small zip tie where the old plastic hook tip broke off. Now works great!
Aug 22, 2013 | Microwave Ovens
Broken Neff microwave hook for tension spring on door. Can I reconnect spring to metal frame or will there be too much tension?
If you very carefully prise off the inner trim of the door you should be able to see where the lug broke that was originally holding the screen. Use a small cable tie to fix one end of the spring to one a the angle pieces of metal around where the window is, about the same level (make sure the other end of the spring is on the hook assembly). You can secure the cable tie and adjust how tight you pull it to get to roughly the same tension it would be if still on the original lug. Cut off the excess of the tie and clip the frame back in position. Door should open and close now.
Hope this helps
Mar 28, 2013 | Neff H5430 Convection Microwave Oven
How to fix a door latch of Samsung SMH9207ST microwave?
The small tab on the latch broke so the spring was loose. Took my drill and drilled a small hole in the main body, ran a small wire tie thru it and hooked the spring to the wire tie. Works great and more durable than the orginal dinky hook.
Dec 10, 2011 | Microwave Ovens
I have a Kenmore Elite Microwave Oven - that I need to replace the door latch on... (plastic prong broke off - and I got new piece in the mail without any install instructions or door design) So, I do not...
Most of them you do have to carefully pry. You look on the inside of the door and you will see the choke seal. It runs around the whole outer edge on the inside of the door. Take a butter knife or a small screw driver and start to pop it up and out of the door. Slowly work around the door until it is completely free. Once you get that out you will see the door hook and will just have to look how it is mounted into the door. There will be a spring attached to it to allow it to pull up and down as the door is opened and closed. Make note of where the spring is attached to the inside of the door frame. It will have to hook onto your new part and back on the inner door.
Oct 15, 2017 | Kenmore Microwave Ovens
I have a Kenmore dryer from 1979 and when I open the door it just falls down. Is there anything I can do to fix this?
Check the door springs. One or both may be broken. Remove bottom panel and look to the right or left sides for the springs. If broken, just replace the same. One end of the spring hooks into the door hinge assembly and the other end hooks into the base of the frame. You should be able to see a hole in the frame to hook the spring as you will also see a hole in the hinge assembly. Easy fix. Just have to know where to look.
Jan 16, 2010 | Kenmore Dryers
I opened teh door and thought i felt something hit
Murray, It sounds like one of the door springs has broken and that is why the door seems heavier and opens with much more force.
You'll want to at least make a temporary repair and order a new replacment spring to get your dishwasher working like it should and so it's safer too.
You can check to see which side of the dishwasher the spring broke, by locking the door shut (with the cycle set to "off"). Now remove the lower access panel, beneath the main dishwasher door. There are a couple of screws near the top corner edges of the panel, just under the main door and a couple more on the toe kick near the very bottom.
Once you've got the lower access panel off, you'll be able to see the two door springs, (there is one on each side). Of course, the broken one might have fallen off the spring notches, so look around and you should see it.
With the door still closed and locked, you can remove the broken spring and see if it's just the hook end that broke. If that's the case, you can reform the end hook using a couple pairs of pliers and reinstall the spring on the door and frame mounting points. You'll have to use pliers to stretch the spring slightly to get it on the other mounting point, once you've got one end on a mounting point. If the spring broke off more than 3 coils, you'll need to replace it with a new one.
You can find a replacement by using searspartsdirect.com and putting in your model number to locate a line drawing and parts listing for your particular model. You can also order a new one from them, or use the part number to get one locally, if you wish.
Once you've got the spring back on the door and cabinet mount points, you can unlock the door and gently lower the door to see if everything is working properly. Once you've opened and closed the door several times, you can reinstall the lower access panel and you're back in business.
I hope you find this Very Helpful and best regards!
Oct 24, 2009 | KitchenAid Dishwashers
NEFF H5470NOGB Microwave door latch fault
theres a small plastic hook inside the door which holds a tension spring this will have snapped off stopping the latch from entering the lock its actually quite easy to fix the inner plastic frame can be unclipped with a small flat blade screwdriver exposing the hook mechanism and the spring will be lying in the bottom of the door frame you can reconnect it to the metal inner frame it stretches the spring a little more but it will never snap again ive done this loads of times with no probs otherwise you will have to replace the outer door to reinstate the broken hook.
Oct 27, 2008 | Neff H5470 Microwave Oven
Dishwashers Logo
71 people viewed this question
Top Dishwashers Experts
