Question about Toshiba Computers & Internet
I JUST purchased a laptop (toshiba sattelite L300D) I put the battery in, I pluged the AC...and I start it up for its first time....but nothing appears on the screen.....not even a bios or whatever...the screen stayes pitch black..but the laptop is supposed to come loaded with Vista Home Premium....help?
    Sergeant:
  • 268 Answers
I would not even touch it, if you JUST purchased it take it right back.......if your having problems with it straight out of the box its prob. not a good sign........
If you dont want to take it back , take out the battery and put it back in...plug it in and start it up again....take notice if there are any power lights on the laptop that turn on , or if there is no response from the laptop at all.....
If there are no lights it may be a problem with the ac adaptor or the power supply inside the computer.....
If there are lights and nothing on the screen then the LCD is faulty.
Posted on Oct 04, 2008
Toshiba Satellite won't start up when AC plugged in
Try another Cord/Charger to verify the Cord, AC jack. If you plug in the AC cord after starting on battery, does the battery charge? Open Control Panel, Power Options, set to High Performance, Advanced power settings, set Sleep and Hibernate to Never, Adjust Advanced power setting to your preference.
Feb 06, 2013 | Toshiba Satellite L300D-ST3501 Notebook
Toshiba l300d just turns off
You may have a bad battery, try running it on AC only. If it still does it, I would supect the cooling fan if not working or it is plugged up with dust and debris. Usually a shut down is caused from an overheat condition. The computer will shut down to protect itself. You may have to get a hold of a computer tech to resolve this.
Oct 27, 2010 | Toshiba Satellite L300D-ST3501 Notebook
Toshiba Satallite a75-s2112 laptop when plugged into a/c power, the ac power stops working, then goes to battery. If I unplug the power adapter and plug it right back in , it will start working and then go...
This is a problem with your charger, I had the problem with my toshiba Sattelite, it was either a break in the wire or a short in the brick. You need to purchase a new charger.
Dec 23, 2009 | Toshiba Satellite A75-S211 Notebook
I left my computer on and around a half an hour later i returned and the screen was black, i played with the mouse pad - nothing. turned it off then back on - nothing. did that around 100 times -...
Difficult to give an 100% positive solution, but try a cold re-start ie: Turn the power supply off, remove the battery, wait 20 seconds, replace the battery , re-connect the power supply, switch on. All being well the PC should start up normally.
Oct 02, 2009 | Toshiba SATP L300D Notebook
BIOS Update Problem
If your laptop is only 3 months old it should be covered by warranty with Toshiba, the best course of action would be to consult them regards this issue.
Mar 22, 2009 | Toshiba Satellite Pro L300D-EZ1006V...
I have changed my laptop to a toshiba sattelite L300d but I am having difficulty installing my lexmark 2500, can you please help.Thank You
u first install the driver cd by disconecting ur printer and after installing the driver software u connect ur printer and restart ur laptop it will work all the best
Dec 06, 2008 | Office Equipment & Supplies
Toshiba sattelite a200 won't turn on
This is a common problem for toshiba laptops, unfortunatly. Usually when this happens either your laptop charger is fried, or you will need to replace the actual laptop plug inside the laptop.
Oct 31, 2008 | Toshiba Satellite A105 Notebook
Try removing the battery. It might be faulty and shorting the adapter.
Oct 31, 2008 | Toshiba Satellite A60 Notebook
Computers & Internet Logo
57 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
