Question about Refrigerators
REPLACING BROKEN WATER LINES!
HOW DO I REPLACE IT?
  • 943 Answers
Hi .thanks for the question. remove the old ones .take the hoses to a hard ware store. buy new .replace .thanks the appliance doc
Posted on Oct 04, 2008
I replaced the ribbon cable on my Frigidaire refrigerator and the ice auger for the ice continue to run and water will not dispense when water dispenser is activated. I want to correctly replace the r
Hey friend, thank you for your inquiry!
From my understanding you were replacing the water dispenser on your Frigidaire refrigerator and the ribbon cable disconnected. I would suggest a generic search online for any additional information regarding the ribbon cable. I was unable to locate that information for you. Additionally, if you continue to have problems I would consult with a professional technician for proper attachment of the cable. Best of luck! -Matt
Sep 11, 2014 | Frigidaire Refrigerators
Fix water leak in water dispenser
Water leaking inside it
  1. Check the lines to your dispenser
If the lines to your dispenser are broken or damaged you will need to replace them.
  1. Damaged drain pan
If your drain pan has holes or cracks it will also need to be replaced.
  1. Clogged drain
If you experience any clogged drains, they must also be unclogged or replace. If you experience this at the ceiling of your unit it can be attributed to a clog in the freezer section. Remove the divider and let the insulation thaw out and dry.
Sep 08, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
I am replacing the water filter holder and would like to know how to disconnerct the water lines
Good Afternoon Friend,
I understand that you are trying to replace the water filter holder, or housing, on your Frigidaire refrigerator, and are wondering how to disconnect the water lines. Typically, this is not a do it yourself repair. There are no manuals that will guide you in replacing the water filter housing. I suggest contacting your local authorized technician for further assistance. They have had the necessary training to replace the housing with ease. Should you have any other questions, please feel free to reconnect. Hope this is helpful.
-Best Regards-
WP
May 14, 2014 | Frigidaire Refrigerators
There are vertical lines appearing on the screen. the lines come and go.
The lines could be a broken or faulty video cable (VGA, HDMI) whichever your using. Try replacing the cable, if it persists it could be a faulty or broken screen.
Aug 22, 2010 | Dell E173FPb 17" TFT LCD Monitor
Replaced timing belt and noticed the rubber bushings in the torque struts were broken. Right engine mount rubber also cracked, Did not replace them and the engine jumps up when put in drive.Do I need to...
hi yes it would be adviseable to replace all three, if they are broken its a sure sign they need replacing, if not you could cause more damage to other parts like exhaust and gear linkage and maybe fuel lines ( these suffer from bad fuel lines as it is ) so to save a lot of bucks spend a few..hope this helps
Feb 21, 2010 | 2002 Chrysler PT Cruiser
After I replace water pump than I start my car
LOOK UNDER THE HOOD. AND CHECK FUEL LINES FOR LEAKS. YOU PROBABLY HIT AGAINST FUEL LINES WHILE REPLACING THE WATER PUMP.YOU NEED TO FIX FAST.FUEL LEAKS IS DANGEROUS.
Aug 17, 2009 | 1996 Lexus ES 300
Neither dispensor or icemaker works after replacing water lines
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Feb 09, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Need to replace water purifier at base of Kenmore Refrig.side/sid
you need tro shut off the water supply to the refrigerator before replacing the filter. After replacing be sure to run the water to get the air out of the lines Thanks for using FixYa and don't forgat to rate this reply.
Dec 27, 2008 | Kenmore Refrigerators
When use water dispeser water comes out from behind the refridge
no real "schematic" available showing how hte water lines are run, but illtell you that they start at teh rear of machine,incoming water, form there they travel to the water filter and into an opening under the refrig side. can be viewed by removing hte lower crisper(theres a holding tank) from ht tank goes back out nad heads for the door assy, so a simple trace of water lins will determine point of leak, usually a fiting or hte water lineitself has dry-rotted, in which case needs replacing, hter are no "hidden" lines with refrig, ohter then within the freezer door,and even that can be removed and replaced if ness.
Dec 01, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Unit is not pumping water out
This is most commonly caused by the rubber belt being broken, as the belt powers the main pump.
Check the belt, (through the access door on the side of the machine,) and if it appears worn or stretched, (or is broken or absent,) replace it.
Otherwise it could be a problem with the pump, or could be soap clogging the main water lines. Try flushing the water lines out with warm water. A good way to see if this is the problem is to try using the hand tool. If the hand tool sprays water, the problem is most likely not the pump. If it doesn't, it is probably pump-related.
-R
Jul 31, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Refrigerators Logo
166 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
