Just purchased a acer p244w monitor and it flickers, tried ajusting the refresh rate but i still have the same problem?
You'll never get it fixed. No one will touch it. My P244W started that too, it just gets worse from there! It all started about 3 months after I bought it, and I ignored it for the most part because the VGA still worked. The HDMI ports stopped working, then eventually the VGA too. I've called just about every repair shop in and around Syracuse, NY. Can't get the logic board it needs. And Acer wants $200 just to look at it.
Posted on Jun 19, 2010
How Are You Connecting It To Your PC? Maybe Its A Bad Cable
Posted on Mar 16, 2010
Laptop screen keeps flickering
Changing the refresh rate might help.
Right click on the screen. In the box that comes up select Graphic Properties. In the window that comes up click information. Box that comes up select monitor tab. Will have a list of display sizes and refresh rates that are supported by your monitor. Once you have that information you can make changes.
FYI: Acer says max resolution 1920 X 1080 with 75 HZ refresh rate.
Also if you have a tube light or speaker system close to the monitor then try moving it further away.
Apr 30, 2012 | Acer Computers & Internet
My Acer Aspire one screen flicker, I am running windows xp with 1 GB ram, I try to connect a external lcd monitor, the monitor display do not flicker. It seems that if I don't use full screen, the flicker...
Please check the refresh rate of the display. If it is more than 60Mhz, it could cause your LCD to flicker.
Go to your display options and adjust the refresh rate.
If that does not fix it, it could be a possible problem with video card.
Try updating the driver software for the integrated video card.
Good Luck Kumpadre!
Sep 08, 2010 | Acer Aspire One Netbook 8.9" Notebook
My Acer AL1716W monitor flickers, but only when I'm on the internet.
flickering monitors normally mean the lamp is on its way out but this sounds like your PC has issues either with the graphics card or memory. Run a virus check and antispyware software. If you don't have this software try microsoft security essentials its free. and people tell me its good.
Also try changing graphics card settings like resolution and refresh rate changes it might have something to do with colour schemes. Update graphics card drivers and I recently had a similar issue and had to upgrade the graphics card to handle the resolution of my monitor
Dec 30, 2009 | Acer AL1716WAB LCD Monitor
Acer AL1914 flickering background
check the monitor refresh rate setting.right click on the back ground on the main windows screen. Choose proprieties from the menu that opens, then click on the settings tab on the top of property window. Next click 0on the monitor tab and increase the refresh rate at the bottom of monitor window. That should do it.
Jan 24, 2009 | Acer 19" LCD Monitor
My LCD monitor is blinking very frequent.
When the refresh rate changes then the screen will flicker. Change your refresh rate to above 75.
Here is how: Click on Start>Control Panel>Display>Settings>Advanced>Monitor>and you will see screen refresh rate. Change to higher rate.
Rate this solution.
Jan 09, 2009 | Acer Aspire 4315 Notebook
Screen flickers
Computer Video Card Support and Help The below image is an example of a screen running at 640 x 480 which means 640 ... Refresh rates below 75 Hz can produce an often-imperceptible flicker.
Monitor Help ... you may encounter a flicker or a noticeable steady line scrolling from the ... While new monitors (VGA / SVGA) do not have this issue.
Good Luck , Please dont for get to Vote/Thank You.
Dec 22, 2007 | Acer Aspire 3610 Notebook
Flickering screen
i had this problem & the circittree on the back of the monitor has a little ajustable screw if you ajust this till the flickering stops hope this helps
Nov 30, 2007 | Compaq FP 7317 17" LCD Monitor
Screen flickers badly at the resolution i want to use and no option to alter refresh rate - any ideas?
I assume you're using windows XP or Vista ? The OS uses data from the monitor to tell it resolutions and refresh rates supported. If you get flicker and cannot alter the refresh rate, it is because the monitor will not supprt a fatsre refresh rate. Your only option, unfortunately, is to get a new monitor, or the cheaper option, use a different resolution.
Nov 26, 2007 | Gateway FPD2275W LCD Monitor
Flickers
how about more higher rate for that then confirm the cable or any unusual soudn from the monitor?
Oct 25, 2007 | Acer AL1916W 19" LCD Monitor
Moniter flicker
Any monitor flickers at 60 hertz. The usual reason for being unable to use faster refresh frequencies is that the correct video card driver and/or monitor driver are not installed. Another possibility is that the resolution is set too high. Assuming Windows XP, right click on the background, choose "properties", settings tab, advanced button. Check to make sure your video card is named - the monitor is not as important but would certainly be helpful. If not, did out the CD's that came with them or download drivers from the manufacturer's website. On the other possibility, on the adapter tab, there ought to be a "list all modes" button so you can choose resolution and refresh rate at the same time. Your LCD monitor will be fussy about the resolution, so you may need several tries to get something that looks good and doesn't flicker.
Sep 12, 2007 | Acer APFV MT (APFVUP5152) PC Desktop
Computers & Internet Logo
276 people viewed this question
David Payne
David Payne
