Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
XP Admin passoword change
I do not know my XP admin password. I have a corrupt config file I need to fix.
  • Larry Remmert Oct 04, 2008
    When I press r I am ask for the admin password. Is there a way around this? I also do not get the Licensing Agreement screen. This might be part of the problem. I am using the CD Dell sent with the computer.
  • 781 Answers
Here.. give a shot with some tools...
http://www.petri.co.il/forgot_administrator_password.htm
Posted on Oct 04, 2008
  • 657 Answers
1. Place your Windows XP CD in your cd-rom and start your computer (it’s assumed here that your XP CD is bootable – as it should be - and that you have your bios set to boot from CD)
2. Keep your eye on the screen messages for booting to your cd Typically, it will be “Press any key to boot from cd”
3. Once you get in, the first screen will indicate that Setup is inspecting your system and loading files.
4. When you get to the Welcome to Setup screen, press ENTER to Setup Windows now
5. The Licensing Agreement comes next - Press F8 to accept it.
6. The next screen is the Setup screen which gives you the option to do a Repair.
It should read something like “If one of the following Windows XP installations is damaged, Setup can try to repair it”
Use the up and down arrow keys to select your XP installation (if you only have one, it should already be selected) and press R to begin the Repair process.
7. Let the Repair run. Setup will now check your disks and then start copying files which can take several minutes.
8. Shortly after the Copying Files stage, you will be required to reboot. (this will happen automatically – you will see a progress bar stating “Your computer will reboot in 15 seconds”
9. During the reboot, do not make the mistake of “pressing any key” to boot from the CD again! Setup will resume automatically with the standard billboard screens and you will notice Installing Windows is highlighted.
10. Keep your eye on the lower left hand side of the screen and when you see the Installing Devices progress bar, press SHIFT + F10. This is the security hole! A command console will now open up giving you the potential for wide access to your system.
11. At the prompt, type NUSRMGR.CPL and press Enter. Voila! You have just gained graphical access to your User Accounts in the Control Panel.
12. Now simply pick the account you need to change and remove or change your password as you prefer. If you want to log on without having to enter your new password, you can type control userpasswords2 at the prompt and choose to log on without being asked for password. After you’ve made your changes close the windows, exit the command box and continue on with the Repair (have your Product key handy).
13. Once the Repair is done, you will be able to log on with your new password (or without a password if you chose not to use one or if you chose not to be asked for a password). Your programs and personalized settings should remain intact.
HOW DO I ENABLE PORT FORWARDING ON MY NETGEAR N150 ROUTER
First you have to get onto your router's config page. Your router should be located at http://192.168.1.1 OR http://192.168.0.1
When asked for login info, the Username is admin. The password it either "admin" or "password", minus the quotes, assuming you havnt changed the default.
When on the config page, go to the firewall. Create a new rule. Use an Inbound rule. Thats the same as port forwarding. Select the service(port) you want to forward to the LAN Server(your system running the port you want stuff forwarded to). Then click apply. If you need more info later, the manual can be found at the following address: ftp://downloads.netgear.com/files/DGN1000_UM_19Jan10.pdf
Mar 08, 2011 | Operating Systems
I can't open windows xp i got this message:\r\n"unable to read file C:\windows\system32\config\software " I tried to fix it thru recovery console copying the i386 file but nothing happenned Help me please
hi You need to get a Windows XP from someone and follow these instructions: Windows could not start because the following files is missing or corrupt \WINDOWS\SYSTEM32\CONFIG\SYSTEM or \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
1. Insert and boot from your Windows XP CD. 2. At the first R=Repair option, press the R key 3. Press the number that corresponds to the correct location for the installation of Windows you want to repair. Typically this will be #1 4. Enter in the administrator password when requested 5. cd \windows\system32\config 6. Depending on which section was corrupted: ren software software.bad or ren system system.bad 7. Depending on which section was corrupted copy \windows\repair\system copy \windows\repair\software 8. Take out the CD ROM and type exit
Aug 28, 2010 | Microsoft Windows XP Home Edition
Whenever i switch on my system, it displays NTLDR MISSING PRESS CTRL+ALT+DEL... WHAT SHOULD I DO?
NTLDR is a file which is kept in the windows directory in the sytem32 folder, and is basically the boot loader.
Most of these problems are caused by bad BIOS configurations but sometimes the files are just corrupt.
Try going into the BIOS and setting it to default configurations, save the changes and exit the BIOS. The computer will restart and hopefully boot into Windows.
If you still get the same error message then follow this instruction bellow:
  1. Insert a Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the rootdirectory of the primary hard disk. In the below example we are copyingthese files from the CD-ROM drive letter, which in this case is "e."This letter may be different on your computer.
    copy e:i386tldr c:
    copy e:i386tdetect.com c:
Good luck and please post back if need anymore help.
Nov 10, 2009 | Microsoft Windows XP Home Edition
My home PC has booting up issue. It has issues with the boot file. I have a multi-drive unit. AMD 3000+, 1.5 GB DDR400, 2 SATA drives and 1 IDE. Three OSs, two XP pro, and Server 2003 enterprise. The IDE...
In order to replace system files, you need to be logged in as Administrator or a member of the Administrators group. There are ways around it, but that lies in the realm of hacking and we don't discuss that here.
Apr 06, 2009 | Microsoft Windows Xp Home Edition English...
Password problem
This will only work if you have another PC you can use to download the software and burn to a CD.
http://sourceforge.net/projects/ophcrack/
Nov 10, 2008 | Microsoft Windows XP Professional With...
Dont have admin password for used computer
Here is a helpful site to recover or change your Admin password:
http://home.eunet.no/pnordahl/ntpasswd/
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 25, 2008 | Microsoft Windows XP Professional With...
Forgotten Admin Password For Windows Vista
google ophcrack and download...
burn the .iso file to dvd using Daemon tools
boot from cd
follow instructions on cd
your admin password will magically appear in front of you
any questions, email me at suvayanr10@gmail.com
Aug 13, 2008 | Microsoft Windows XP Professional With...
Downloading yahoo messenger
Unless u get the admin password u can't assign rights to other user for installing software.other users with admin privilages can only install software.
Jul 22, 2008 | Microsoft Windows XP Professional
Forgotten admin password xp
You cant fix it with RECOVERY DISC!Download in google.com active password changer then with that you can change or remove admin password!
Mar 23, 2008 | Microsoft Windows XP Professional With...
REMOVING A ADMIN PASSWORD
you may ask your friend to give you the admin password. or else you need to reformat your pc in order to change everything.
Dec 18, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
80 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
