Question about Makita 10" Miter Saw LS1030N
Brake Blade does not shut down after releasing the trigger
  • lIVEFREE4EVE Oct 13, 2008
    the BLADE DOES NOT WORK WHEN I RELEASE THE SWITCH.I REPLACED THE SWITCH AND BRUSHES ???
    Champion:
    Filmmaker:
    Uploaded 5 video answers.
  • 271 Answers
Check the connection on the safety!
Posted on Oct 24, 2008
Self propelled poulan poulanpro mower wii not shut off when released why?
The ground switch on top of the carb is not grounding the coil when you release the blade brake. Release the blade brake slowly to avoid shearing the fly wheel key. Look for a black 16 Ga. wire at the blade brake cable near the carb. That is the shut off switch. Try blowing the switch with compressed air to clear grass and trash from the switch contacts
Jun 18, 2017 | Poulan Garden
Kobalt SM2505LW 10 sliding compound miter saw makes grinding noise and slow saw stop
a bearing ,brushes or brake broke more likely the brake mechanism if blade coasts
Jul 07, 2016 | Saws
While I was cutting grass the Engine shut down. Pulled the brake up. Push the PTO back down to shut the blades down. I started the engine, engine runs perfect.
try replacing the battery most with an electric clutch PTO have to have a really strong battery as the alternator system is not strong enough by itself
Jun 16, 2015 | Garden
Blade continues to spin after turn off
I don't know the make or model of your saw but the blade brake on circular saws is controlled by the power switch. If your saw previously did brake the blade rotation, you need a new switch to make it work again. Also a generic switch will not do, you have to have the brake switch made for your saw or it will do the same thing.
Apr 07, 2012 | Saws
Where is the blade brake on the miter saw
The brake on electric motor driven tools is the field & armature. When running the switch provides power to both sides/poles of the field through the brushes and armature. When you release the switch half of the field is powered pulling the armature to a stop. If your bladed continues to spin when the switch is released, you need to replace the switch. The Ridgid part number for the proper switch is 503317000.
Mar 06, 2012 | Ridgid Reconditioned 12 In. Compound Miter...
I friend has a craftman riding lawnmower with a problem, when the brake pedal is push down the engine will run, but when you released the brake pedal the engine wants to shut down, also when you pull the...
The drive pulley underneath has an arm with a rubber brake that rubs against the pulley when the brake pedal is released. Make sure that it is not jamming or defective.Let me know if this helps
Jan 19, 2011 | Craftsman Garden
How do I replace the blade on a Skill saw circular blade? The blade keeps turning. Is there a locking mechanism?
on most of the new saws there is a button that you push in to lock the blade, you have to hold down on the button and tighten blade.after you release button turn the blade to make sure the lock released befor you hit the trigger
Jun 28, 2010 | Saws
BRAKE DOES NOT STOP BLADE WHEN TRIGGER IS
the guard not releasing could be dirt around the spindle hub or the guard is bent, I would unplug tool and manually pull the guard down to see which one, if it is just sticking you can use a dry lube to cure that, the break could be dirty commutator or worn out brushes, switch. Give me the model number and I will try and find a breakdown for you and go further.
Oct 05, 2009 | Porter Cable Saws
6.5 push mower runs hot and stops.Unable to restart even after cools down.
Check and address the following:
  1. remove the rewind cover and clean the cooling fins
  2. change the oil with synthetic.
  3. clean the bottom of the deck and make sure the blade is sharp.
If it still gets hot and shuts down the bearings may be seizing or the blade brake is mal-adjusted.
Remove the spark plug and pull the lever to release the blade brake, spin the mower over by hand, if you feel a lot of stiffness or resistance to turn make sure the blade brake is not dragging. This is not likely to be the case being you would have noticed it was very hard to pull over when cold..good luck.
Aug 25, 2009 | Garden
Makita 10" Miter Saw LS1030N Logo
140 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
