Question about Intel Motherboard
Memory Upgrade causing reboots
Recently purchased Kingston 1G KVR333X64C25 mem for 7vm400M-rz gigabyte system.
When installed the system goes into reboot mode.
I have set DRAM from "by SPD" to 333, and have removed bios battery for an hour, and reset settings.
Any ideas ?
  • cajast Oct 04, 2008
    256K 266 DDR works fine.
    Replacing with 1G 333 DDR only.
    Sergeant:
  • 268 Answers
Have you tried to start the computer back up without the new RAM module in?
If it doesn't get stuck in that reboot loop, you either have the wrong RAM or a faulty RAM module.
If it does start up but still reboot , then you can start narrowing the issue down to the motherboard.
You should be able to send it right back and pick up the right one. If you give me the MOBO's make and model I can also tell you what type of RAM you should be running.
Posted on Oct 04, 2008
The AC97 on Motherboards after new Windows installation not working. I have Gigabyte 7VM400M=RZ
You should say what version of Windows. The AC97 chipset is so common that it must be supported. Many Windows XP drivers will work for Windows 7. You must unpack the driver files and select it manually from device manager.
Oct 29, 2013 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
One long beep tone---NO Display on monitor(monitor checked ok)
Definitely not your monitor. It is either a CPU or a Memory problem, is this a new build or did an existing computer suddenly start doing this?
Is that your motherboard, the Gigabyte 7VM400M ?
Jun 26, 2009 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
GA-8pe800 pro and kvr333x64c25 memory problem
the 1g is defective return it and get a replcement
Mar 28, 2009 | Gigabyte GA-8PE800 PRO Motherboard
Memory up-grade
you can go max 2GB (1GB each) DDR333 PC2700.
you have to reset the bus rate to match the RAM speed.
if you stay with DDR266 then you don't have to reset the bus rate
Nov 13, 2008 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Installing P4 2.8ghz cpu
That particular motherboard only supports AMD processors:
http://www.gigabyte.com.tw/Support/Motherboard/BIOS_Model.aspx?ProductID=1764
You will need a new motherboard to use your Intel 2.8ghz chip.
May 21, 2008 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Sound drivers
go to gigabyte.com us and download that driver for sound on your make model ok
Feb 02, 2008 | Computers & Internet
Intel Motherboard Logo
82 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
