Washer Hello , I have a top load washer (110.2692 ) its about two years old. My leak detector went off . When I pulled washer out i did find water leaking from bottom. More disturbing was I also found a oil / watery mix. Or maybe it was a greasy / watery mix. anyway that is what I found on the floor and touching (what I call the drive shaft) found it there. Being stubborn, I cleaned everything up and threw in a small load.I put paper towels under unit and turned it on. After cycle was done I pulled out paper towels and found a small amount of water. I was just curious. I know it must be something serious , because of the oil / grease thing. Any ideas ? Thanks , Tom Solve This! I have the same problem. X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OKSolution #1posted on Oct 02, 2008 jsrock516 Rank: Guru Rating: 94%, 1883 votes Okay...what you are talking about is a honey colored oil, right? The gearcase (transmission) is filled with this oil. Sometimes the gearcases are prone to leaks. There is a small breatehr hole onthe top of the gearcase housing that oil will sometimes weep out of when it expands. This could be a potentially serious problem, as a leaky gearcase COULD mean it is beginning to fail. But...not always. This is kind of a gray area when it comes to this model washer. As leaking oil is generally considered a bad thing, the gearcase could actually run for quite a long time and experience no failures, or further leaks. I would keep the oil cleaned up and run the washer as you normally would. If the leaking becomes progressively worse, the tub begins to spin slower than usual, requires assistance to spin, clothes aren't spinning dry enough, or if the gearcase starts to exhibit loud noises, stop using the washer and plan on needing a replacement gearcase. They generally run about $150 and can easily be installed by the DIYer. If you wish to pursue that as an option sometime, just let me know and I can provide you with the steps required to do so. At this point, monitor what you have and let me know how much the gearcase is leaking. As far as the water leaking is concerned...you need to determine WHERE it is coming from. If it is leaking in the center under the wash tub in the location of the gearcase, the tub seal probably needs replaced, or you may have a crack in the tub somewhere. If the washer is leaking near the front, this is generally a sign of a leaking water pump, or associated hoses. Check to make sure the hoses are clamped snug. If the washer is leaking in the back somewhere, I would suspect a leaking water inlet hose, or drain hose. The best way to make the determination is to place a sheet of cardboard under the washer when it is empty. Do a load of wash and pull the cardboard out when done. Note where the leak patterns are and get back to me. I need to know where the water is coming from before I can give you a correct assessment. I hope this helps guide you in the right direction. JS, Last night I did three loads of laundry with the cardboard underneath. There were no leaks of any kind. What is going on with my washer ? Thanks , Tom
  • ilber Dec 27, 2008
    some kind of grease or oil leaks in the washer leaving clothes with stains
  • 5,911 Answers
Wow...your posting was hard to read, but I managed to "muddle" through it. I understand that you need laundry and experienced no leaks of any kind. Well...I don't have a good answer for as to what may be wrong. You could have experienced a momentary leak due to heavy vibration from an unbalanced load, or...you had a minor leak that sealed itself over time, I just don't know. That's the nature of this business sometimes. This is also why customers get frustrated by repeated service calls when the appliance doesn't do what it was doing wrong when the repairman shows up. Then, as soon as the repairman disappears down the street, the problem comes back. Believe me, I've seen this over and over. The best advice I can give you for now is to continue to monitor your washer with the cardboard underneath. If the problem comes back, no matter how minor, get back to me and let me know where it is leaking. Until then, if the washer does NOT have any problems continue to use it as you normally would. Good luck to you Tom.
PS To avoid confusion - to get back to me, all you have to do is reply to this post with your comments and I will receive an email notification.
Posted on Oct 04, 2008
Need APPROXIMATE water consumption on 10 yr old Whirlpool washer
Hello. The older top load washers use up to 60 gallons of water per load. That said, also check your toilets as a leaking toilet can use tens of thousands of gallons per year. Here is a link that explains how to check your toilets and other items for leaks. Regards, Joe
ps - kindly rate my answer as helpful. thanks.
Feb 17, 2010 | Washing Machines
Maytag washer top loading leaks water seems to be coming from the tub itself 7 years old thank you mija
does unit leak constant or only when spinning ther are 2 screws done low on front panel fill unit with water and watch center shaft there is a seal below basket
inside washer changing seal is a little difficult have also had this style of washer leak when starting spin cycle if water has not drained out fast enough
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram
this page has a break down of normal maytag top load machine part at center is called boot and seal have also had thi type unit leak where bolts go through tub
good luck ron
Dec 12, 2009 | Cameras
Hello - we have a top loading Maytag Performa washing machine that leaks water during the spin cycle when my wife is washing heavy items that she has placed on center spindal to avoid an unbalanced load....
Maytag Epic is leaking water from the bottom about 8 or 9 inches from the front door back on the right side. Is there and thing i can do. It only about 2 years old or less.
Oct 13, 2009 | Maytag Performa PAV2200
Leaking water from underneath towards the right side.
The pad is an insulation pad to keep heat in the washer. It might be worth pulling the washer out and checking the water feed and drain connections - it's a good bet one of these is leaking.
Mar 14, 2009 | KitchenAid KAWS700L Top Load Washer
Kenmore Elite washer
Oct 01, 2008 | Washing Machines
Washer
You bet, the tub seal is out and also the clutch and drive tub assemblies need to be replaced because like a drum brake oil has contaminated the pads. Did you notice that if you open the lid while spinning that it takes longer than seven seconds for the basket to stop? See the pic below, you need parts 1 and 5 plus the tub seal and center post seal.
Sep 30, 2008 | Washing Machines
Ammana washer less than 5 years old making loud noise and leaking water from bottom of washer
it sounds like the tub seal is going bad and leaking on the bearings,not good,you can remove the top with a putty knife into the front seam one clip on each side(make sure no screws on bottom front,you can now check everthing out to see what you find,let me know -mike
Sep 26, 2008 | Whirlpool Washing Machines
How do I open my GE Top Load Washer to check for leak
Pull the washer foward, tilt back against the wall and look under it.... look where the water pump connects to the motor shaft... check for rust etc.... if so replace pump....
Dec 15, 2007 | GE WCXR1070A
Washing Machines Logo
228 people viewed this question
Top Washing Machines Experts
