Vizio L32 component input and auto problems
The vizio will not accept the output from a new dvd player on the "analog hd 1 or 2" inputs. It will accept the player output when hooked up to the hdmi port. I want to use the hdmi port for my FIOS cable box however.
Also, when the tv audio inpput is "digital hd" I get a staccato popping noise proportional to the volume.
Are these expensive repairs?
  • palmettojeff May 24, 2009
    mine is the 37" 1080 LCD and I can't get the analog HD inputs to work...Me and my son are bummed, because we just bought the Monster Component cable kit to hook up his Sony PSP to the flat screen TV!
    all other functions/inputs seem to work fine....
Codigo de volumen
Posted on Aug 25, 2010
Problem? * The signal from componenant input,RGB,@ 1080i + 720p,doesn't work at all when outputting at component output or HDMI. 100% failure.
you cant record an hd picture and sound through component input rgb,for 1 you arent inputting hd,you are inputting analog,you cant up convert,
Apr 16, 2015 | Televison & Video
Where do to plug in the cord to connect the tv to the DVD player?
Hello
You have several options for connecting your DVD player to your GV42L FHDTV10A - HDMI,
Component, S-Video and Composite (AV) inputs. Based on your home theater configuration, you can
decide which option is the right one for you.
connected to the HDMI input of the VIZIO GV42L FHDTV10A for optimal results.
To maintain the display quality, use a VIZIO certified HDMI cable available up to 10 meters or less.
1. Turn off the power to the LCD HDTV and DVD player.
2. Connect a HDMI cable to the HDMI output of your DVD player and the other end to the HDMI
Input (white color area) at the rear of the LCD HDTV.
3. Turn on the power to the LCD HDTV and your DVD player.
4. Select HDMI using the INPUT button on the remote or side of the LCD HDTV, or directly by
pressing the HDMI button on the Remote Control.
a) If you are already using the HDMI 1 input for another component, or you do not want to use
the HDMI 1 input for the DVD player, you can connect the DVD player to the HDMI 2
connection.
b) Refer to your DVD player user manual for more information about the video output
requirements of the product.
OK
Apr 24, 2011 | Vizio 42 in. LCD TV
I have a Denon AVR2307 to which is connected,via optical audio and component video a DVD player/recorder and this works well but in order to take some of the work off the player part I've bought another...
HDMI signal from DVD can not be down converted to analog component signal.
Connect your new DVD to a component input 1..4. Make sure that component input assigned to desired input (dvd/vcr/sat/) (setup - input setup - input - component assign - component x etc). Connect coax output of DVD to coax x input of the receiver and assign it (setup- input setup - "input" - digital assign ..). Probably you need to setup DVD output resolution to 720i or 720p in dvd setup menu.
Sep 09, 2010 | Denon AVR-2307 Receiver
I have a 32inch Phillips HD ready TV but there does not seem to be and HD input for my DVD player
"HD input" is HDMI. If the DVD doesn't have HDMI output then use the 5 wire hookup - the component hookup.
The TV input for HD would be HDMI or component input - 5 wires.
Nov 25, 2009 | Philips DVR-1
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
Component video signal between KLH DVD8350 & Vizio 32" PlasmaHDTV
If the Visio TV has more than one input, don't forget to use its remote to make sure the correct input is selected. It probably wouldn't hurt to put a DVD into the player, confirm its running from the front panel counters) and let it keep running as you troubleshoot. At least then you'll know there is an active video source once you find it. Another thing you can try is to put in a music CD, if the player accepts these too (most do). Then when you get the TV set to the right input, at least you'll hear music, and can then go back to trying a DVD.
I know you're using component video, so remember that unlike HDMI devices, the TV is unable to switch to the correct source automatically. So it may just be that you've never had to switch the TV's input source before. Good luck! :-)
Jun 02, 2017 | KLH DVD8350 DVD Player
Picture from analog tv signal is not sharp
I have this same machine, you did'nt mention what input you are using (composite, S-Video, component or HDMI) or what type of display you have (CRT, LCD, Plasma etc.).
If your T.V. has a HDMI input I recommend using that, if not and it's of fairly recent vintage use the component inputs (not to be confused with composite video inputs, or yellow RCA-type input).or at the very least use the S-Video input.
In the setup menu (on screen) try setting the "TV Screen" option to the 480p setting and if you are using the HDMI input try setting that to the highest resolution your T.V. has or set it to "Auto"
Finally in the on screen video menu select the "Video" setting and set the "Still Mode" option to automatic, and the "Output Level" to lighter or darker whatever your preference is.
Remember...Always use HDMI or component video inputs on your television (if it has those inputs)!
Hope this helps!
Joe
Nov 19, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
How do I get sound on my Vizio SV420XVT 42 Great picture but no sound
I had the same problem. I could get an analog audio signal but no digitial signal. My problem was with the cable box setting. I have Cox Cable. With the Cable remote I went to settings/settings/Audio out and selected HDMI. Worked like a charm
Oct 19, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
TV ranking
Hi. You could look up reviews. I personally usually never offer advice on choices, because what I like, may not be what you like..its a matter of personal preference. But in this particular case, I'd go for Panasonic. Why? Better features, better service, easier availability of parts, and better resolution.Plus some nice features. If this answers your question, PLEASE don't forget to rate as fixed. I'd really appreciate it. Enjoy your new tube!!!
Jeff
May 12, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Video issues w/ Pioneer VSX-816 AV Receiver
Receivers generally cannot or will not convert from one input type to a different output. That's not to say there may not be some high end models around that do that.
I have this receiver and have it setup as follows. Monitor out Component, S-Video, and the Composite video channel (since I have surround sound I have no interest in getting audio to the TV since I keep its speakers off anyways) to their different inputs on the TV. Warning on some TV's if you plug in S-Video you cannot then use composite on that same input channel as it will override and disable the composite. Then you only need to choose the appropriate input on the TV when you switch sources. In my case Tivo is S-Video, DVD is component, and most of my older video games and VCR are composite.
Having a TV that allows you to change the labels for the input channels is helpful with teaching others that may be less adept, or a snazzy remote that you can program to do everything at once.
Aug 30, 2007 | Pioneer VSX-816-K/S Receiver
Televison & Video Logo
397 people viewed this question
Top Televison & Video Experts
Electro Med Services...
