Question about Rockford Fosgate T600-2 Car Audio Amplifier
Externally fused amplifiers
I've noticed that there are car audio amplifiers on the market without built-in fuses. Instead the manufacturers recommend external ANL fuses. What are the reasons for this? Are there hidden benefits or detriments in the performance of one product to the other? Is this to address the serious power fluctuations that particular amp could experience, or is it just laziness, and simple economics, quantity over quality?
    Scholar:
  • 92 Answers
I believe it's because the fuses (or any other connection point) is deemed to be a weakness. If an amplifier is properly installed, there will be a large fuse as close to the battery connection point as possible. Any other fuses in the amplifier itself would be considered redundant. From a safety standpoint, if an installer chooses not to fuse the main power wire to the amp the fuses in the amp will not prevent a fire from occuring should the wire get shorted. Therefore there MUST be proper fusing on the power wire and further fusing in the amp is not necessary.
The other reason for this may be that in many larger amplifiers from reputable companies (RF and others) they use un-regulated power supplies to get the maximum from their amps. Fuses could be considered a bottleneck in these systems as a properly installed system, again, has the required fusing at the battery.
Posted on Oct 06, 2008
Fuses amp
Yes, your amplifier needs the amout of fuses as there are fuse ports.
In case something were to go wrong it would blow the fuses instead of your amp and subs and burning your wire harness up..
I hope this helps.
May 12, 2013 | Power Acoustik A1800DB Car Audio Amplifier
Where is the fuse located on the rockford fosgate p300-1 amplifier? my amp will not turn on and i checked the voltage on all connections and they were fine. I've read several people saying that you...
The 40A fuse should be immediately to the right of the B+ terminal. If you bought this amp used, and it's never turned on before, it's possible the previous owner removed the fuse. It's hard to miss if it's actually there, so you're probably seeing an empty slot where the fuse is supposed to be. With the radio turned off, insert a 40A ATC (blade style) fuse into the slot, and then power it up.
Nov 17, 2017 | Rockford Fosgate Punch P300-1 Car Audio...
Were is the fuse located on the punch 300s?
I just read all the information about this amp on crutchfield and never saw anything about a built in fuse or external fuse. I don't think it has one.
May 22, 2011 | Rockford Fosgate Punch 300S Car Audio...
Hi! I have a Jensen XA2150 Amplifier, from the speaker output I have connected a Subwoofer Sony 10 inch 1100W. Tha'ts gave me a nice bass sound, but now it's death! The amplifier have a 25A fuse,...
Have you checked the fuses inside the amp?Unscrew the cover and with the amp sitting on its back,remove the cover.You have 2-4 fuses,old round type,in there.
May 21, 2011 | Jensen XA2150 Car Audio Amplifier
Where are the fuse on this amp?
The Tantrum 1200.1 is externally fused -- there is no fuse within the unit. Per the installation guide, it should have an 80 amp fuse between the amp and the power source.
Feb 18, 2010 | Phoenix Gold Tantrum 1200.1 Car Audio...
Cant find out where the fuse is in the amp.
Hello willflo,
All of the information that I can find on the JL products indicate that their amps are fused "externally". The 500/1 needs a 50A external fuse.
Hope this helps.
May 09, 2009 | Jl Audio 500/1 Car Audio Amplifier
Ground zero amplifier overheating and going into protect.
Since you changed the amperage of the fuses and the cable, you allowed the internal problems of the
amplifier to get worse than they were before the original fuses started blowing.
A fuse is a safety instrument that blows instead of your amplifier.
The problem is NOT the fuses frequently blowing, as such events warn you of internal problems with
the amplifier which you should have had serviced at the time to prevent them getting worse.
It is very much like the persons who replace the fuses in their household wiring with pennies, to prevent
frequent fuse replacement only to have their house burn down from overloaded circuitry.
Service your amplifier immediately.
Revert to the original amperage on all fuses in your vehicle to prevent a car fire.
Apr 07, 2009 | MA Audio Hard Kore HK-898 Car Audio...
Radio quit working
does your system have power amplifier aside from your built in amp on radio? if yes, disconnect all supply then put new fuse. try this time, should not blow the fuse. then one by one, connect the supply fo your radio only, if ok, then next is the amplifier, if it blow the fuse, your power amplifier has an issue.
Apr 03, 2009 | 2001 Mitsubishi Eclipse
ROCKFORD FOSGATE Punch 301M Amplifier Problems!!!!!!!!!
Check the Inline Fuse -=Usually located Close to the battery in the engine copartment=- and also check the fuse in the AMP. Without knowing and seeing all of the details i would say to try to bypass the capicator, I know that i always unhooked my inline before jumping the car but i know it happens. Hopefully it will be just that a fuse or the capicator but if some sort of surge resulted from multiple failures get the amp bench tested at A car audio shop. Just some thoughts.
Feb 21, 2007 | Rockford Fosgate Punch 301M Car Audio...
Rockford Fosgate T600-2 Car Audio Amplifier Logo
118 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
