Question about Samsung Office Equipment & Supplies
Samsung REGISTER ER350 CODE ERROR EEOO SEQUENCE ERROR
I have a sams 45 cash register making a noise and showing an error cade Elo0000
The E00 code on your SAM4S cash register indicates a Sequence Error.
You can try an Initial Clear to reset the error:
1. Turn the power switch located on the right side of the register to the OFF position.
2. Turn the control lock to the P position.
3. Press and hold the key position where the SBTL key is located on the default keyboard layout.
4. While continuing to hold the SBTL key, turn the power switch to the ON position.
5. The message "INITIAL CLEAR OK!" prints when the initial clear is complete.
You may have to try the Initial Clear procedure a few times to clear the E00 error.
Jan 08, 2018 | Retail Supplies
It is locked and a code that is eo1 is on the screen it is the casio 3700
It simply means you started a sequence then tried to use another mode without finishing the sequence. Turn the key to each mode until the error stops. That is the mode you were last in and you must finish what you started in that mode before you turn the key again.
Feb 11, 2015 | Casio Parts Cash Register PC Desktop
How to fix E00 sequence error
To clear the error code do the following:
Turn key to P mode
Turn power switch off
Hold Subtotal key down
Turn power switch back on (while holding the subtotal key)
Wait for print out
Turn your key back to Reg position.
After you do this it will "Close" the register so you will have to log back on.
Jun 07, 2014 | Samsung Sam4s ER-5240M Cash Register
Sequence error warning comes up on display, as soon as i turned on my ER-5215 M cash register, how to fix it?
I have a cash register Model# ER-5215 M there is a message on the screen as follows: Reg. PBAL how do I fix it.
Jan 21, 2013 | Computers & Internet
H0w do you get unlock code for samsung galaxy s it keeps saying not registered.
You can get samsung galaxy s unlock code from your network provider, just call your network customer service and make request about samsung unlock code. To doing that process you must have a good standing account with them otherwise you will not get that code. Other solution, you can buy unlock code from third party sites. I hope my solution can solve your problem.
Jul 12, 2011 | Samsung Galaxy S GTI9000 Smartphone
Samsung er290 cash register missing manual
Same as er350...key to program mmddyy no sale
Feb 13, 2010 | Samsung HL-R4264W 42" DLP HDTV
60 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
