Question about Car Audio & Video
I have a power acoustic cd dvd player witha usb port on it when i plug it in with my mp3 it doesntrespond what to do?
  • 97 Answers
Try to reset it
Posted on Oct 04, 2008
Toshiba dvd recorder will not record from webcam it is hooked into the ubs line
Do you mean USB? According to the manual for your DVD recorder, the USB port is only for the playback of MP3 (audio) or JPEG (photo) files. So you can't record video from your camera through the USB port.
http://support.toshiba.com/support/staticContentDetail?contentId=2912443&isFromTOCLink=false
Jun 06, 2016 | Toshiba DR430 DVD Player/Recorder - 1080p...
How to charge a cativa AT-MP420 portable Media Player
Ti charge the MP3 player, connect the supplied USB cable to the player and then plug the other end of the USB cable into the USB port of your computer.
OR
Purchase a 5 volt mains USB power adapter and plug the USB cable from your player into the USB port on the power adapter.
Aug 13, 2012 | Toymax Audio Players & Recorders
How do I use my MP3 player? Where do I connect to dvd player?
Hello there,
If your player does not have the usb port or hub on it,you will not be able to connect the mp3 player to the dvd player,but if it does have the port, that is where to connect the mp3 player.
There are some kind of devices that helps to connect the mp3 to the dvd through the audio plug in on the back of the player.
Hope this helped, Goodluck Elect_Comp
Aug 10, 2011 | Sylvania DV220SL8 DVD Player/VCR
When CD Inserted the port gets disconnected and does not recogonize
are you using a single usb connection? Unless you have power plugged into the unit you probably need a dual usb cable (two usb connect to pc (or mac) and one connects to the cd player. Most usb ports do not provide enough power for a cd player plugged into one port.
Hope that works for you
Nov 30, 2010 | Samsung External Slim DVD-W USB Compatible...
I just got a usb 2.0 external cd dvd rw burner drive for acer aspire one don't know how to connect has no instructions. Is this just a burner for cd dvd's or can I watch my dvd's with it?
If it's a DVD/CDRW It can play DVD's but not burn them. It can burn CD-R and CD-RW. It should just plug into your USB port. Make sure you have the enhanced USB 2.0 drivers for your operating system. Also you will need power for the external box the drive is mounted in. My external box needs 115 volt power. This hooks to an AC adapter, and then to the external box. You will also need Power DVD or some othe player. Windows media player will play DVD's with out some third party software.
Oct 24, 2009 | Acer Computers & Internet
Erasing music from mp3 player
get pc with usb 2.0 port, and at least win 2000 professional on it
get mp3 player
get install cd for mp3 player (if you have one)
boot up, plug in player, wait for recognition by win2K or above, then treat as if it was an usb-stick or
external harddisk: erase the files you want or format it all to have it blank, copy new files
if not, run hardware detection via device manager, if windows does detect unknown device,
let it find driver from the hardddisk or win setup-cd/dvd, install, try to find as harddisk
or run install from mp3-related cd, choose the right driver fitting your operation system, install
remove mp3-player, reboot, repug, win should now find it automatically!
now erase the music files(mp3's) on your player and/or copy new ones, unplug,
put in fresh battery and enjoy!
Jun 18, 2009 | Audio Players & Recorders
Usb error
check new USB cable or resolder the USB connector
also change the usb plug istelf.
Dec 31, 2008 | Wharfedale DVD-M3 DVD Player
Gpx mp3 player downloads
i dont know the exact model. but there should be a usb cable that came with it. you should then plug the usb cable into the mp3 player and then plug it into the usb port on your computer. at which point on your computer it should have a popup notification recognizing a expansion drive. such as C: would be your hard drive and D: your cd/dvd rom. open the newly formed expansion drive and you can just copy the mp3's to the mp3 player.
Jun 15, 2008 | Audio Players & Recorders
Power sugre with m240
Hi there. This message would indicate any one of the following: 1. You have a lot of USB devices plugged in to your computer, and the maximum power supply for the USB ports has been exceeded by plugging this player to your computer. It would be best if you unplugged 1 or 2 of the USB devices connected for the time being. 2. You are plugging the player on your front USB port, and may need to plug it in the rear USB port to acquire ample power supply (front USB ports do not get as much power as the rear USB port -- sad but true) 3. You are using a laptop and may need to try another USB port on that computer. Purchasing a self-powered USB hub would be ideal as it gets its power supply directly from the wall electrical socket.
May 11, 2007 | SanDisk Sansa m240 MP3 Player
Car Audio & Video Logo
50 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
