Question about Whirlpool GGQ8831L Gas Dryer
Does not heat
Igniter works but gas does not always come on. gas dryer by whirlpool. the tumbler turns and the air blows but the heat does not come on.
  • 1 more comment
  • dasilvajose Oct 04, 2008
    I think is the starter, as it works sometimes.
  • uptick Nov 02, 2008
    I have the same problem with low heat. I cleaned the outlet and the filter. I check the pilot, looking thru the hole from outside and it seems fine. It takes a few seconds to ignite (fire on). But it doesn't provide enough heat as it used to. Clothes not dry.
    If this is the coil problem, please help with some guidline to replace it. Thanks in advance.
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    You may have a weak glow bar igniter. If the dryer is experiencing inconsistent ignition, I would recommend replacing the igniter as a start. They become weak with age and will not draw the necessary current to open the gas safety valve. Can you please confirm your model number so I can be sure?
  • 5,911 Answers
There is NO starter on a gas dryer burner assembly. The burner is controlled by gas valve coils and a glow bar igniter. Once the igniter reaches the appropriate current level, the gas valves open and you have ignition. The common problem is a weak igniter. You need to do a current measurement to make sure the igniter is within tolerance. If it is within specs, then I would agree with docjohn174 about replacing the coils. If its not within specs, you need to replace the igniter. Depending on the type of igniter you have, the current rating is as follows:
TWO BASIC IGNITER TYPES:
Carborundum (Cylindrical in shape) – needs to produce 2.5 to 3.0 amps for the gas safety valve to work.
Norton (Rectangular in shape) – needs to produce 3.2 to 3.7 amps for the gas safety valve to work.
NOTE: There is a UNIVERSAL FLAT BAR igniter on the market as well, that can be used as a substitute if the igniter type that came with your range is not available.
I still need an accurate model number in order to confirm WHICH type of igniter you have.
Posted on Oct 07, 2008
I think I have the same problem. My model MOD: LGR8648LWO. I clean the outlet & thr filter. Checked the pilot burnner & it seems buring good. It takes few seconds to ignite (burn).
But I still don't know the problem. There was heat initially but then it seems weak in time.
Thanks for any input.
Posted on Nov 02, 2008
  • 3 Answers
Replace valve coils.
Posted on Oct 19, 2008
  • 943 Answers
Hi the coils on the gas valve, is the problem here. replace the coils. thanks the appliance doc
Posted on Oct 04, 2008
How to fix a whirlpool gas dryer that tumbles but no heat ?
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Apr 12, 2015 | Whirlpool Dryers
Whirlpool Cabrio gas dryer does not heat. About every 1 minute it makes a low screeching sound for about 20 seconds. It spins fine but just cool air. I already removed the rear panel and completely...
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Air Flow and Heat
Warning
Mar 22, 2015 | Whirlpool Dryers
GE Spacemaker Dryer DPXH46 (gas) runs and blows but stopped heating. Gas supply is good. How do I troubleshoot the igniter?
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
Air Flow and Heat
Warning
Oct 05, 2014 | Dryers
What is wrong with a whirlpool gas dryer model #LGR4634EQ2 that won't heat and the timer runs down to near the end but not far enough to shut off?
Thermal Fuse
Air Flow and Heat
Warning
Oct 04, 2014 | Dryers
Gas dryer
Thermal Fuse
Air Flow and Heat
Warning
GOD IS GOOD !!!! AND THAT IS WHY MY ADVICE IS FREE
Aug 18, 2014 | Jenn-Air Jenn Air Clothes Dryer LSG2700W,...
Whilpool duet gas dryer not heating
CHECK:
Thermal Fuse
Air Flow and Heat
Warning There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Aug 18, 2014 | Whirlpool Dryers
No heat
SOUNDS LIKE BAD GAS SAFETY VALVE
Thermal Fuse
Air Flow and Heat
Warning
Jul 05, 2014 | Whirlpool LGQ7030KQ Gas Dryer
My Kenmore elite gas dryer sometimes starts and sometimes doesnt ?
Thermal Fuse
Air Flow and Heat
Warning
Jun 02, 2014 | Kenmore 74892 Gas Dryer
Dryer turns and air blows, but no heat. GGQ8811KQ0
Make sure that your dryer air vent is not being blocked by lent, and if it is not it is your element or thermocouple?
Nov 07, 2009 | Kitchen Ranges
My gas whirlpool dryer won't heat. Cool air does
Hi
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 06, 2009 | Whirlpool Dryers
Whirlpool GGQ8831L Gas Dryer Logo
348 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
