Question about Texas Instruments TI-83 Plus Calculator
Equations I have a ti-83 plus that i haven'y used in years..... now I am trying to enter simple equations (7x+9=30) and can't get the answer............ could you please please walk me through the steps in entering and getting the answer to this equation I would really really appreciate it thanks
    Genius:
  • 1,011 Answers
Dear,
is there any INVALID DIM msg or not..
regards,
Posted on Oct 12, 2008
  • 19,396 Answers
    Scholar:
  • 52 Answers
You need to download starter edition-app4math
Posted on Oct 03, 2008
    Genius:
  • 1,847 Answers
Solving an equation in one variable. (Also known as finding the roots or x-axis intercepts.)
a) Enter the function and graph.
b) Press 2nd, CALC.
c) Press 2 to select zero.
d) Move the cursor to the left of the intercept and press ENTER.
e) Move the cursor to the right of the intercept and press ENTER.
f) Press ENTER again.
g) The root wilI appear at the bottom of the screen.
NOTE: This can also be done using the Solver. See the last item in this section for that procedure.
  • 6,487 Answers
This user manual will be helpful to you http://www.math.oregonstate.edu/home/programs/undergrad/TI_Manuals/ti83Guidebook.pdf
Hope that helps........
  • 13,433 Answers
You can't simply enter 7x+9=30 into the calculator, there is a way to calculate what the x is but its been a few years since I've done these..
  • Ekse Oct 03, 2008
    Hold on, I will try to figure it out for you.
  • Ekse Oct 03, 2008
    7x+9=30
    We turn it around
    7x = 30-9
    Minus
    7x = 21
    Devide both sides
    7x = 21 ||:7
    Answer
    x = 3
    7*3 +9 =30
How do i use this for algebra equations, putting in varables and such
Calculator manual: http://education.ti.com/downloads/guidebooks/scientific/30xii/30xiiqrg-eng.pdf
If you are just trying to solve a simple quadratic equation by entering coefficients, this calculator does have those features. The TI-83 is a better choice for that kind of function.
Sep 15, 2011 | Texas Instruments TI-30 XIIS Calculator
I have a very old Texas TI-83 calculator, and I have not used it in years and have lost instruction manual. How do I change the setting to get the calculator to work out equations to more than two decimal...
Press MODE to enter the mode editor. Scroll to the second line and select FLOAT or a larger number of digits than the 2 it appears to be in now.
You can download a Guidebook from http://education.ti.com
May 18, 2010 | Texas Instruments TI-83 Plus Calculator
TI 83
Yes you can use it, here is the formula: Y= V(t+ (i/c))^(tc) V=amount put in, t=time, i=intrest rate, c= amount of times it is compounded.
(I know this because I have a TI-83 calculator)
Mar 27, 2009 | Texas Instruments TI-83+ Graphing...
TI-83 Plus No Longer Squares Correctly
when you type -2 imagine your calculator doing the equation: -1 x 2. The - sign actually stands for a -1 so when you do -2 squared your calculator is simply following order of operations. It first squares the 2 making it 4, then it multiplies the negative making it -4. In order to get around this you must use parenthese. (-2)^2.
Hope this helped
Nov 20, 2008 | Texas Instruments TI-83 Plus Silver...
Graph feature is not working on TI-83
you have one of your stat plots on that is what is messing it up. So either turn off the stat plots. Or just reset your calculator. hit 2nd then the plus (+) key then 7 then 1 then 2. Good luck
Nov 12, 2008 | Texas Instruments TI-83 Plus Calculator
How to use the texas instruments ti 83 plus
Srry my friend the ti 83 is no magnificent Ti-89. meaning: you have to solve it yourself. There is a method for graphing though. Set the equation equal to zero and then plug the stuff on the other side of the equation into a graph by pressing y= and then typing it in. Then hit graph. Wait for the graph and then hit 2nd calc and select zeros. Bring your cursor using hte arrow keys close to where the line hits the x axis and press enter and then do the same except to the right of that point and then press enter twice and it will display the y which should be the answer
There are quadratic formulas for calculators programmed in tibasic for the calc but other than that there is no way to solve it
Apr 27, 2008 | Texas Instruments TI-83 Plus Calculator
Solver not working properly
try a simple equation like x^2-1 which should come out with x = 1,-1
no sign change would indicate that the graph of the curve never crosses the x axis, if you graphed the above equation and calculated the zeros, it would come out with -1, 1 which it should, but if you put in x^2+1, the graph would never cross and therefore have no sign change from pos to neg or vice versa, the left-rt are the left and right bounds or the lower and upper bounds which was corrected in later calculators, Please let me know the outcome of graphing both of the above equations and then putting them in the solver. you could also use the quadratic equation to prove the answers if you liked, hope this helps
Mar 13, 2008 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
754 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
