Question about KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher
Flood switch This DW is a Kitchen Aid version of a Fisher & Paykel. Both drawer rinse lights stay on, the drain pump stays on. Book says the flood switch is activated. Is this somthing that a homeowner can fix or am I required to call for service?
  • 3 more comments
  • robtomolillo Nov 15, 2008
    I have been trying to find a repair manual with no luck.
  • wilmerstradl Nov 24, 2008
    flood  switch reset
  • gtcasias Nov 24, 2008
    How do you reset the flood switch?
  • morganvpi Dec 21, 2008
    Mine is acting up as well.  It's possessed actually.  it just continues to try and drain both drawers, but there's no water in either....
  • alsincorp Apr 09, 2009
    Mine started to do the same thing. Full of bubbles, now pump stays on and both top and bottom drawers flash red. Won't reset by unplugging.
I had the same problem and I fixed mine. It wasn't hard at all. First, make sure power is off either unplug or shut off breaker. Next, open the lower drawer and on the sides toward the bottom you will see a circular recessed pin with a flat slot. Without forcing, wiggle the door down. When you get it off you have to remove the wire harness, just unplug it. Now, on the sides at the bottom, you will see where the drawer fits on the slid rail. Push the plastic button slightly to release the lock for the slid rail to the drawer and push the slid rail all the way back as to release the drawer fronm the rail. Be carefull when you release one side as to hold it up still while removing the other one. Now, flip the drawer on its side and try to get it as far out of the way as possible to the right of the unit. You will now notice a plastic cover at the back left of the unit. This is where the flood swith is. Remove this cover by sliding to the right. The will be water under the circuit board you see. Soak up as much as possible and you can use a hair dryer to get the tough spots. Now try to find the resson for the water. I had a mouse living under mine. Look for a break in one of the hoses. After all dried up turn power back in before reinstalling lower drawer. If dried properly, the dishwasher should stop beep beep beeping. Now turn water back on and run upper drawer. Inspect hoses again. 50/50 chance. If now water, reinstall lower by replacing plastic cover, place drawer on rails and slide all the way back. It should click back in if on rails correctly. Now install the door face, line up tabs into drawer, and slide up. Align holes for recessed circular pins and just push them in. Test lower. Thats all I got, Hope it helps.
Posted on Jan 26, 2009
  • 1 more comment
  • kshanklin534 Feb 07, 2011
    Thank you, Thank you! I have got the drawer off and am drying it out at the moment but I think this is going to fix the problem and only took me about 15 minutes to fix. I will let you know if it worked. Also very proud of myself for even attempting the project.
    Thanks again,
    Sincerely,
    Kimberly Shanklin
    kshanklin534@aol.com
  • dmcnews Apr 27, 2011
    Hi, I have no power to the bottom drawer and was thinking that the flood switch was tripped. I got my face 4 inches from the bottom left inside of the dishwasher (with the cover pulled off) and for the life of me cannot see anything that resembles a switch or button. can someone help me locate it please, thanks
  • alicrokin Jul 19, 2011
    This worked for me! At the end of the third sentence that ends "pin with a flat slot" it took me a bit to realize I needed to remove those pins to proceed. Also, I had luck using a fan to get completely dry out the circuit board after I got up most of the water. This was easier than holding a hair dryer. THANK YOU SO MUCH for this post. I'm running the dishwasher now!
I had this problem as well and reseting the machine worked for a while before I figured out the problem. The lower lid is not sealing properly allowing water out of the tub setting off flood switch. I'm still trying to figure out how to adjust the lid after replacing the actuator on the bottom drawer.
Posted on Aug 28, 2012
E6 error code on fisher and paykel dishwaher
The code E6 is for the flood switch
Pull the appliance out, tip it back about 45 degrees and see if water runs out of the base.
If it does, drain the base (under where the tub) completely and the anti flood should reset.
If there is an aquastop device on your fill hose, after draining the base, turn off the water supply, disconnect the aquastop device and allow it to de-pressurize. Connect it back up and try again.
If it happens again, you'll need to check for a leak.
The normal cause is over foaming, using multifunction tablets and rinse aid, or just spilling rinse aid.
Dec 28, 2016 | Fisher and Paykel Washing Machines
Fisher and paykel error code 6 on dishwasher
Dec 28, 2016 | Fisher and Paykel Dishwashers
Flood switch 920 model
Not sure what the actual model number is but usually the F1 error with Fisher and Paykel dishwasher means water has entered the flood switch located at the base. This could be due to leaky hoses or water leaking through the door or lid seal. Wait for a day or two until the water evaporates and try again. Otherwise you will have to dry out the flood switch and then try again. Location of flood switch will depend on your model. For double drawer dishwasher you will have to take the bottom drawer out from the housing and the switch is on the floor of housing. But make sure you take the mains power chord out before touching the insides of dishwasher. Will also need to find the cause of the leak. Other reason for F1 could be loss of power to top dishdrawer if you have double drawer. But in that case the top drawer will have no lights on. The power board is located on the base of housing under bottom drawer. Once again do not touch inside of dishwasher without shutting off mains power.
Jan 27, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel mw512 stops during washing and beeps. the lights for the short wash and rinse stay on. i can reset it by turning it off at the wall and putting it through a rinse cycle. its intermittent,...
12. (00001100) Phase 1 to 6 - Flood Protection Error
The Motor Controller module has found the water level to be above the flood level
and tried to pump the excess water out. (Under extremely high flow rate conditions
the machine may overfill during the "top-up" routine in agitate.) After pumping for
30 seconds, it has been unable to lower the water level below the flood level. Either
the water valves have stuck on and are letting water in at a flow rate that is higher
than the pump can handle, or the pump is blocked and can't remove the excess
water.
Primary Source: Water Valves.
Action:
If the water valves are on continuously, check that the water valves turn off
mechanically (remove power from machine).
Secondary Source: .Pump system
Action:
Check pump for blockage and drain hose for correct height and kinking
Tertiary Source: Motor Controller module. (Display Module Phase 1)
Action:
If water valves are being driven on electrically, replace Motor Controller
Mar 04, 2012 | Fisher and Paykel Fisher & Paykel Washer
F1 has come up
This video explains how to repair this issue
Feb 21, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
I am getting a F 1 code on my dishwaser. I hit power to shutt off but it just comes back on and blinks F 1
This video will aid you in you F&P dishwasher repair.
http://www.appliancerepairlesson.com
Feb 09, 2011 | Fisher and Paykel 23 in. DD603H SS...
F1 showing
Hello here is a video that explains how to repair a Fisher Paykel dishwasher
http://www.appliancerepairlesson.com/
Dec 10, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel f1
Hi
Error F1 on your fisher & paykel means an overfill condition. One of the most common causes for an overfill fault is that the dishwasher cannot pump out the dirty water due to a plugged drain hose. Check the drain hose if it is clogged. Now remove the bottom drawer from the unit to inspect the flood switch. Remove the wire harness cover on the underside of the drawer. With the bottom cover off, unclip the wire harness, fill hose, and drain hose. Then unclip the linkage at the back of the drawer and lift the drawer off the slider arms. Now’ you’ll be able to look at the flood switch. Note the positions of the wires on the flood switch and remove them. Then unclip the switch housing from the base panel. The switch housing contains one switch for each drawer. The switches are wired normally closed (NC) and each switch has three spade connections, so it's important to note where the wires went. Now clean the contacts and let it dry.
Hope this helps...
Daniel
Aug 13, 2010 | Fisher and Paykel 24 in. DD-602 Built-in...
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
Fisher & Paykel Dishwasher leaked
From what you describe, drain water from the top drawer is getting into the bottom drawer or waste water from the disposer is backing up into the bottom drawer.
1. Each drawer has its own drain hose. Each hose should terminate at the drain point with a 'Y' adapter.
2. Inspect the drain point (under the sink where the drain pipes are) to make sure this 'Y' adapter is present. (you should see two drain hoses from the DW). If not present, then the DW drain lines are not installed properly. (Someone took a shortcut and installed the 'Y' adapter behind the DW)
3. If terminated properly, make sure the drain hoses extend upward as they leave the drain point.
It is important the drain lines are connected properly to ensure proper drainage from the DW. Consult the installation manual for complete details.
Jun 08, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher Logo
2,424 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
