H-3 error code in a Sharp ARC260m
I have a copier with an H-3 code, I've cleaned out the fuser and reset the thermostat, but I can't get the sequence of buttons to get me into the service mode. I worked on older Sharp models but they have a different sequence of buttons to get to service mode. If someone could help me I could get to Sim 14 and see if the fuser is okay. Thanks for any help you could give.
  • tonerspill Oct 11, 2008
    Thanks for the lead, I went there and found the reset code and eventually got it going again. It turns out on this model, it wouldn't let me get into the service mode unless the fusing unit was slid out.
  • 2,794 Answers
The analog Sharp copiers used the crop code (clear, repeat, zero, pause).  Once the digital models came out the rules changed.  Sim 14 was for the analog copiers as well.
A good resource to get the answers you need is copytechnet.com.  They have Sharp copier technicians on there who can help you with the problem.  Unfortunately I only work on the low end Sharp models (for their product line).  The service codes are different on that machine. Copytechnet is a free service and they only deal with copiers.
Posted on Oct 04, 2008
  • Tim Babcock
    Tim Babcock Oct 12, 2008
    I've never heard of that trick before.  Interesting.
Eroor code on Sharp ARC260M copier
Please report the error code e.g., F1-47, C1-30, H5-01 and so on.
Jun 16, 2013 | Sharp Office Equipment & Supplies
Error code h5-01 appeared on my sharpmar-507
Check the fuser unit and make sure its installed correctly.
Dec 02, 2009 | Sharp AR-507 Copier
DP 2500 displaying E04-01
You have a failure in the Fusing Unit:
E4- 01 Fuser warm-up temperature
1. Fuser Thermistor is dirty.
2. Thermistor position is incorrect.
3. Fuser temperature is low.
4. Thermistor is defective.
5. Fuser Lamp connector is disconnected.
6. Fuser Thermostat is defective.
7. Fuser Lamp is defective.
8. HTC PCB connector (CN716) is disconnected
You can try resetting the error by using this key sequence:
enter simulation mode by pressing keys ''Function + Original Size + 3 ''
go to f9 mode ,06 (ram initialize ) sub code 04 to reset fuser error.
If the code comes back you will need a service technician to diagnose which part is bad.
Oct 20, 2009 | Panasonic Office Equipment & Supplies
Sharp Copier AR -407 Error code H3-00
H3-00 means there was a problem in the fuser unit of the copier - a temperature problem. The correct temperature is not reached within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
Apr 11, 2009 | Sharp AR-407 Copier
Sharp AR-287 HR-00 error code
I'm sorry for not getting back to you sooner - I lost track of this question. If you still need this info here it is :
H3-00 indicates a temperature problem in the fuser unit. not reaching a certain temperature within a certain time.
Hope this helps.
Mar 30, 2009 | Sharp AR 163 Copier
Sharp service code H5-01
To enter simulation mode to reset errors enter this sequence on keypad.
P, * , CA , P then enter sim # 14 to reset code.
press " custom settings" button to return to previous menu and CA to exit sim mode.
Dec 10, 2008 | Office Equipment & Supplies
Error h200
H2 indicates there is a fuser error.
Try resetting it by the pressing the following buttons on the display in sequence,
#, interrupt, Clear, interrupt,
display should go dead,
enter 14,
then press print, This will clear the error code
press CA to get out and return to normal.
However if there is still a problem with the fuser, the code will return. Then you may need to have a tech look at what is the problem.
Hope that helps...
Lbcoaster
Aug 05, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR 5320 error h200
H4 indicates there is a fuser error.
enter 14,
Hope that helps...
Lbcoaster
Sharp copier AR5316
H2 or 2H is related to a fuser under heat or overheat.
Try this first,
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
If this does not clear the problem the fuser will need replaced.
Feb 20, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp Z-830
Nov 21, 2007 | Sharp AR-5316 Advanced Digital Imager...
157 people viewed this question
jasbo
jasbo
