Question about Kenmore Elite 45986 Front Load Washer
Tub bangs and seems to be spinning out of round
Kenmore elite 11042822203 front load tub bangs with or without load checked shocks and counter weights ok. stainless tub seems to wobel inside plastic tub.
  • drwilk Oct 04, 2008
    I will be trying to fix it and your assistance would be great. Also would like to locate replacement tub. Thank You. (PS. are these support arms metal, is it something that could be welded if taken apart?)
  • 5,911 Answers
One of the support arms on the back of the spin basket (stainless steel tub) is broken and causing it to spin in the fashion you describe. The only fix is to replace the spin basket. Using it in its current condition will cause serious damge to the outer tub shell. Let me know if you decide to replace it or need assistance locating a replacement tub. I can assist you in how to disassemble the washer and how to reinstall a new tub. Sorry...I wish this was better news.
Posted on Oct 03, 2008
  • Jeff Rockwell
    Jeff Rockwell Oct 05, 2008
    I apologize for taking so long gettng back to you. To answer your question, "no" it is not recommended that you weld the support arms of the spin basket as I believe they are made of aluminum. A replacement spin basket can be purchased online at searspartsdirect.com. Just type in the model number you provided and the spin basket is listed under the "Tub and Basket Parts" heading as item number 11. This is not an inexpensive part. Hopefully, the basket if you ronly problem. Dependent upon how long your washer was allowed to run in its current condition you may have also caused significant damage to the outer tub shells (items 8 & 21). As long as they are aren't leaking, you may get by without replacing the shells. The front shell typically takes the blunt of the punishment when the spin basket is spinning off balance, however. Just some things to consider...
    The following link is rather lengthy, but it gives you all the steps necessary to complete the repair on your own:
    http://www.fixya.com/support/r752855-rep...
    The link explains how to replace the rear tub bearing, but you cannot perform that repair without removing the spin basket. I would recommend you read through the link thoroughly first to see what you're up against before getting too deep into taking the unit apart. No special tools are needed. I would recommend an electric screwdriver with socket attachments to make this process go faster for you.
    PS I would also recommend that since you are going to have to break the seal on the tub shells to get to the spin basket that you purchase a new tub gasket at a minimum. This will ensure you have a good seal when you bolt the two shells back together. The seal is listed under the same heading as item number 10.
    I hope you find this information helpful. Let me know if you have additional questions.
Why does my LG washing machine make a rattling noise even at low RPMs?
It is not uncommon for items that get loose in the washer (paper clips, coins, etc.) to slip underneath the "paddles" and then make noise as the drum turns. While an annoyance, it is not anything to be overly concerned about. Eventually the item(s) will come back out.
Mar 19, 2015 | LG WM-2277HW Front Load Washer
Could the spinning barrel be off center,what has come off?
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
By the way my advice is free cuz God is good!
Mar 19, 2015 | Washing Machines
How do I fix the last few seconds of spin that vibrates off balanced and aloud noise.
Sep 23, 2014 | Samsung WF419AAW 4.3 cu. ft. Front Load...
I have a Samsung washer model number wf338aab/xaa my tub is off balance
Sep 17, 2014 | Samsung WF328AAW Front Load Washer
Why is my basket leaning to the side on my easing machine
Sep 06, 2014 | GE Washing Machines
Will not complete spin/rinse cycle - shakes big time
sounds like he just wants money? No spin, try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sep 04, 2014 | Whirlpool Cabrio WTW6600SG 4.6 Cu. Ft. Top...
Why does my washing machine shake?
FRONT LOAD OR TOP LOAD? The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Jul 24, 2014 | Whirlpool Washing Machines
Tub spins out of round
When that happens it is usually because of a drum bearing problem, have it replaced before this damages more parts.
Dec 31, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
602 people viewed this question
Sal De
fordexpert
Robert Rankin
