Question about Coleman Powermate Premium Plus 6250W Portable Generator
Engine missing engine starts easily but when power tool is pluged in and turned on tool runs slowly and the engine dies down
  • 169 Answers
Get a DMM that can measure frequency (Hz), then check that with no load and the idle control set to off the frequency is 61.5 Hz - If it isn't you have to troubleshoot why it isn't and correct it.
You should also check the idle control mechanism if there is one on the generator, with it on the generator should start up at regular speed, then slow to idle speed, then rev back up to regular speed when you draw current from the generator. To check it use the DMM to measure the speed at startup ( should be 61.5 Hz), when it idles down (about 37 Hz), when you're drawing power from any other outlet ( pretty close to 60 Hz). If the generator has idled down and you shut off the idle control it should rev back up immediately.
Please rank my solution,
Carl
Posted on Dec 02, 2008
Engine runs for about 30 seconds and shutdown like an electrical shutdown as opposed to a fuel related shutdown.
Engine fired up, ran normally for 30 seconds, then shut down ...
www.thedieselstop.com > ... > 7.3L IDI Diesels (Not Power Strokes)
Sep 25, 2012 - Engine fired up, ran normally for 30 seconds, then shut down. ... it fired up and has been running since... if it just ran out of fuel jump it, and keep ...
Viewing a thread - cummins m11 starts then dies - AgTalk Home
talk.newagtalk.com/forums/thread-view.asp?tid=332921...flat...1
Sep 24, 2012 - 9 posts - ‎9 authors
98 KW with a cummins m11 will start and run for 5 seconds then dies. ... anything else like that, because it would run for 30 seconds and then die, not 5. ... The engineprotection system will not shut down the engine unless the ...
[PDF]John Deere Engine Safety Shutdown with "Black Box" (prior ...
www.tuckerbilt.com/.../John%20Deere%20Engine%20Safety%20Shutdo...
John Deere Engine Safety Shutdown with "Black Box" (prior to Tier II ECU ... Ifengine fails to start in 30 seconds, the Low Oil ... Test #1 (Engine not running).
1800 RPM for 30 sec before shut down [Archive] - Pilots of America ...
www.pilotsofamerica.com > ... > Pilot's Lounge > Technical Corner
Jan 01, 2016 | Cars & Trucks
I have a 98 Mazda millenia it will start but then dies
The alternator might be shot. It is what charges the battery and keeps the engine running while the car is on. There are many other things it could be, though. How does it sound? Does it slowly die, or suddenly cut out? Does it always start easily, or is it getting harder to turn over each time you start it?
Jun 11, 2015 | 1998 Mazda Millenia
Briggs and stratton 463707 starts at full choke
Once the engine starts move it off full choke slowly. It will flood the engine if you don't.
Sep 30, 2014 | Measuring Tools & Sensors
How many turns of low idle screw for 1986 johnson 30 hp, ELCDM
Start with one. Bring the speed down slowly. If the motor "sneezes" and dies ,open more, maybe one-half turn and restart. If engine now runs as you idle down, slowly turn in the idle screw until the motor starts to speed up without moving the throttle. A little more and it should sneeze again. From the point where it started to speed up, back the adjustment about one eighth to one quarter turn open. See how it runs. If you have to open the idle screw way out or it keeps sneezing you probably need to clean the carb.
Aug 23, 2014 | Boating
My 2001 dodge caravan ust died while driving it. it wouldnt turn over so we changed the starter, still wouldnt start, was told had bad wires so we changed the fuse box, and was also told my fuel pupm was...
if you were driving it then it slowly died down if you noticed your lights, radio, car clock, seem to be running out of power your alternator is broken, if not that is probably an engine problem
Oct 26, 2012 | 2001 Dodge Caravan
Vanguard V Twin 18 hp. monted in Cushman Motor scooter, runs great at W.O.T and at on quarter throttle, misses at range inbetween
Sounds like your carb needs the fuel/air mix adjusted..uses all the gas at high speed but has excess at low speeds...find your adjusting screw and at med throttle slowly screw it clockwise until the engine starts to sputter then back it out until it starts to sputter again then continue to do this until you reach ideal mix where it runs the best it can..then go slowly through the throttle up and down..when set..unjust your idle speed screw to your ideal idle speed..if this dies not fix ..carb will bed cleaned or rebuilt. Good luck.. Note always push or pull your throttle handle slowly to position avoids gas load up causing sputter and backfire.
Mar 15, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
My Freelander engine is missing out, and I am experiencing loss of power. Could it be plugs?
definitely...check wires as well....disconnect wires, one at a time with engine running (don't shock yourself) if the cylinder is firing properly the engine will run worse or die when you disconnect it...plug it back in and move on to the others until you find the cylinder that doesn't change how the engine runs, when disconnected...this is the problem cylinder...you can check the plug simply by swapping it to a known good cylinder...same with wire...there are other ways to check them, but i am assuming you have hand tools only to keep this simple....a plug wire can also arc through the wire insulation to ground and cause a miss...this can usually be easily spotted by running engine in the dark and watching for a blue spark around where the plug wires run...it will show up brightly in the dark...hope i have not lost or confused you and i hope this helps
Dec 15, 2009 | 2002 Land Rover Freelander
Cold starts ok warms up shakes and stalls
check engine coolant temperature when it gets warmer, or at operating temperature, and verify that the temperature gauge is showing warmed up to operating temperature. If the coolant temperature sensor tells the computer the engine is cold it will over fuel and miss and the engine will die. When cooled down it will run fine until it warms up. Also could be coil if it starts missing after warmed up.
Aug 18, 2009 | 1990 Ford Bronco II
1996 Plymouth Voyager missing violently, hesitating, dying,
Take it over to a Auto Zone store they advertize that they will read the diagnostic cods for free. with the check engine light on there are codes logged in the cpu. the codes will point you in the direction to go. this will save you lots of time.
May 25, 2009 | 1996 Plymouth Voyager
Coleman Powermate Premium Plus 6250W Portable Generator Logo
737 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
