Question about Amana ALG331RAW Gas Dryer
Dryer i have a amana dryer model #le50aw ... i had a different fryer to start off with, it would not heat up anymore so i then purchased this amna dryer and i ran it, it heated up real hot, now it wkon't heat up, whats wrong? its an electric dryer
    Problem Solver:
  • 14 Answers
SOUNDS LKIE A HEATING ELEMENT
Posted on May 03, 2009
  • 5 Answers
Probably the heater element. You need to pull the back of teh machine off and check the heating element for continuity. If its open then its shot.
These are parts that normally go bad.
Check on ebay these can be had for less than 50.00
Posted on Oct 11, 2008
Amana Dryer model PDLE330RAW parts manual and service manual. I need these to fix my Amana dryer that I purchased in December of 2001. Where can I find one ?
http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Dryer-Parts/Model-DLE330RAWPDLE330RAW/1268/0151200?pathTaken=&prst=0&shdMod=DLE330RAW-PDLE330RAW
Remember, on all older Amana (and some of the new stuff as well) you will need the BOM number, which on yours will be DLE330RAW-PDLE330RAW. The link above is to Sears, because they seem to have the easiest pages to use as far as breakdowns. Would look into other places with the part numbers for better pricing. No service manual that I can find on the unit anymore, and can't find a tech sheet for it either. Parts list doesn't even show one, but you might have one under the console that was put there during manufacturing.
Nov 08, 2013 | Dryers
Amana Dryer NDG5805AW heats for a couple seconds after starting then no heat HELP
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 08, 2010 | Amana NDG5805AW Gas Dryer
Amana model 2330aww....runs but does not heat up....just started happening, dried one load then it stopped heating up
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 15, 2010 | Amana NDE2330AY Electric Dryer
Amana gas dryer Model #ALG866SWB: When pushing
The motor is bad and needs to be replaced.
Jul 23, 2010 | Amana ALG643RB Gas Dryer
Amana Dryer model # LEA60AW. Dryer runs but no heat.
check the heating element and the high limit fuse
Jul 10, 2009 | Amana ALE643RB Electric Dryer
I purchased an Amana drier a few years ago and my aunt purchased the exact drier the model #ALE331RAW It heats so hot you can not hardly touch the cloths
too hot??? thas gerenally a sign of insuffecient venting, check for arestricted and/or blocked vent. it cant release the proper amount of heat and its buildingup inhte machine
Mar 07, 2009 | Amana DLE330RAW Electric Dryer
Freezer side blowing all the time and fridge side is warm with no cooling on amana side by side unpluged and defosted with hair dryer and it worked for a couple days then went back warm in fridge side...
You have a defrost issue.
Adaptive defrost control.
Defrost thermostat.
Defrost heater.
These are the only 3 parts involved.
If there was a model number I could be more help.
Feb 20, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Dryer not heating
hello see if there is any sensors at the back of the dryer test them with a muiltmeter with the power off
shaun
Jan 30, 2009 | Amana Dryers
Accessing the heating element
I have a ALE643RB Amana dryer and believe the heating element has went out because the dryer will not heat anymore. I have taken the control panel off the top and all the screws out on the back and the bottom edge, but am still not able to get the shell off the dryer. How do you get to the heating element?
Feb 08, 2008 | Amana ALE643RB Electric Dryer
Amana ALG331RAW Gas Dryer Logo
135 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
