Question about Motorola Mobility RAZR V3
Phone will start taking pictures all by itself. Then the keypad won't work. Then after a while, and phone starts working again. Battery is charged.
  • richter01 Oct 04, 2008
    I did a master reset and now it's fixed.
    Brigadier General:
  • 7,752 Answers
Okay that is good to hear
Posted on Oct 05, 2008
My nokia E63 wont start up. the screen just lights up dark for a few seconds and then turns off by itself. i tried charging it, but the square keypad just lights up.
Take the battery, sim card and microSD card out for an hour or so then place the components back in the phone. If this doesn't work, go to www.nokia.com and download the firmware for your phone via instructions on the Nokia web site.
Apr 23, 2010 | Nokia E63 Cell Phone
My HTC Touch display goes blank and phone doesn't ring
Ok,
Good to read the detailed description. You said, the battery is full but did u checked the battery healthiness. Is it really full. Put the battery in another set if you have because the true picture will be in front when u check the battery on load condition. You can check the battery voltage but it might show you the full desired volt but without load. So, the better way has mentioned.
Tell me one thing that was it going off when u swap/filip ist screen. If this is the case, then u need to check the strip that connects the keypad of your phone with the LCD. This can be the issue...
good luck...
Sep 15, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Nokia 6500classic won't switch off
its not the problem with software . It is the problem with your keypad. It has been freezed from inside . Just because of this whenever you put the battery (due to freezing) phone starts itself. pls vote me thankyou
Feb 13, 2009 | Nokia 6500 Classic Cellular Phone
Motokrzr
Well it sounds like a combo of both. Definitly get the battery replaced again. The phone itself probably needs new software. take it your service provider's corp store to get the software updated.
Sep 23, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Moto w30 keypad not working
buy a new phone. your phone is buggered
Jul 03, 2008 | Cell Phones
Hi k750i,phone works perfect but won,t hold a charge for long,even with new batteries. thank you
Before you change the battery:
  1. Charge the battery fully
  2. Discharge the battery fully
  3. Repeat steps 1 and 2
If the battery does not reset itself and start lasting longer then you do need to replace it.
If that does not work the phone will require repair of the leads from the charger to the battery or the battery to the phone
Jun 26, 2008 | Ericsson Cell Phones
Keypad stops working on handsets
After you remove the battery and the two obvious underlying screws, you will need to pop the two halves apart. This takes some force and you may break some internal plastic clips, but you have no choice. There are approximately six internal plastic clips, so don't worry about breaking one or two. The screws hold it together securely anyhow. Then there are 5 more little screws to get the back PCB off. Then use nail polish cleaner and q-tips and clean the contacts on both the rubber pad and the PCB.
The keypad will work like new again - magic.
Jan 19, 2008 | Vtech VT-2431 Cordless Phone
Motorola KRZR Problems
UR KEYPAD IS AUTO RUN. TJIS ARISES WHEN PHONE IS WATER LOOGED OR HIT SOMWHER.GO TO SERVICE CENTER UPLOAD NEW SW N CLEAN THE MOBILE PROPERLY. IT WIL WORK
Oct 02, 2007 | Motorola Mobility L6 Cellular Phone
Display turned off, but i can make and receive calls
If you take the battery out then with the battery out plug in the charger, this worked for me.
Jun 15, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
