Question about JVC SXXSW6000 Speaker
Optical output? How Do I connect this product to the Television? I just bought it and havent had it delivered yet. Is there an optical output?
  • 1 more comment
  • LEPROCY Oct 03, 2008
    Thanks jaketasnake, I have an HP LC3773N 37" LCD HDTV ----Leprocy
  • dileeponly Nov 20, 2008
    the product is - JVC SX-XSW6000 home theater.
    what do i need to connect this to my TV as the wires that came with the kit does not have a pin. They are just wires.
  • Anonymous Dec 30, 2008
    I have same problem.How do I connect this speaker to my TV?
    Scholar:
  • 125 Answers
Most Surround Sound Systems these days will come with An Optical Output but just to make sure If you can tell me the maker of your product and a model number it would be very helpful to further assist you with your concern.
Posted on Oct 03, 2008
LG sound bar connected to Pioneer TV by optical cable not working
1. if you have something else that you can test the optical wire on. do that first. dvd player etc... if the test item works, it's the sound bar (or a setting in the sound bar.)
2. check the audio settings on your t.v. make sure it's set to output to optical.
3. replace the wire.
if none of these solve the problem, the t.v.'s optical output may be bad.
May 08, 2014 | Pioneer PDP-4270HD 42 in. Plasma...
Try to go digital optical out to a receiver for surround sound (also Samsung) but not sound comes out. Tested it with a Samsung Blu-Ray player digital optical out, and it worked.... is this a problem with...
The digital audio outputs on televisions sometimes only work when the television is on certain inputs. It does not always work with all hdmi connected devices. I can almost guarantee you that if you connected an over the air antenna to this television and scanned for your free local television channels the digital optical out between the tv and the surround sound would work.Likewise if you have Comcast or one of the other cable carriers that has digital cable you could connect the coax cable directly between the television and the cable wall outlet without the cable box and get sound from the tv's digital audio output to the surround sound.
However there might be a digital audio output television setting you have not changed. Refer to the manual for that or call customer service if necessary.
Jun 10, 2011 | Televison & Video
I am attempting to attach a Samsung Sound Bar to my 42 inch LCD 1080P Polaroid Television. I can not seem to get sound from the Television connected to the Sound Bar. Thoughts?
Connect the audio out RCA jacks (white and red) on the TV to the white and red RCA input jacks on the sound bar for analog stereo sound or connect the black digital audio output jack (typically optical) on the TV rear panel to the sound bar's optical digital audio input jack for surround sound. Use an optical cable. There may be some user settings on the TV for audio.
Aug 12, 2010 | Polaroid FLM-4201 42 in. LCD Television
I want surround sound. How do I hook up my audio 5.1 RVC-884VBK, with my HDbox and LCD TV? It's too confusing. What hooks to what? Currently the HD box and blueray DVD is hooked straight to TV ...
Does you television have an "Optical Audio Output"? This would be the best and easiest way to get surround sound from your system. If your TV has an optical output the you can use an Optical Cable to connect the TV to the reciver. This way whatever you are watching from the TV will be in surround sound. The HDMI connection sends a surround sound signal from each device to the television. If you connect it to this output on the TV then make sure the optical output is turned on in you telivison's menu. If your TV does not have an Optical Audio Output then you will need to connect each optical output from the blu-ray and HDbox to your reciever. Your reciever will need to have two Input channels(one for each device). Then you can select that input to the device(blu-ray or HDbox) that you are using. The optical cable is the best way to go for surround sound because it is pure digital and produces the best sound. If the HDbox or Blu-Ray does not have an optical output then you will need the six rca jacks to get the surround sound. Let me know further info on what you have so I can assist you more.
Jun 26, 2010 | JVC RX-884V Receiver
Digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Sep 16, 2009 | Technics SA-DX930 Receiver
Does the Insignia ns-2brdvd digital opt. output work with HDMI
Below is what your manual says abour it. From hardware perspective, when you have a disc in there the optical audio driver is active and so is the HDMI audio. To verify, lift the lid on the optical interface and you will see a red or blue light on the inside. Don't look directly at it! View from the side.Plug that into your home theater system, select that input on your home theater and you should be good to go.
Insignia NS-BRDVD Blu-ray Disc Player
www.insignia-products.com
Connecting a digital audio optical system
To connect a digital audio optical system:
1Make sure that your player and the TV are
turned off.
2Connect one end of a digital audio optical
cable (not provided) to the DIGITAL OUT
(PCM/BITSTREAM) OPTICAL jack on the
back of your player.
3Connect the other end of the cable to the
DIGITAL AUDIO OPTICAL INPUT jack on
the digital audio system.
Aug 11, 2017 | Televison & Video
Problems connecting phillips tv to panasonic sc-pt660 home theate
I just bought a sc-pt660, I have a philips tv too, the TV only available output is digital coax but the home theater only has digital optical input, you may buy a digital coax to optical converter like this one:
http://www.amazon.com/Cables-Go-Coaxial-Optical-Converter/dp/B0002J2MV4/ref=pd_cp_e_3?pf_rd_p=413863501&pf_rd_s=center-41&pf_rd_t=201&pf_rd_i=B000I98ZQY&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1BS8MKCZ1CWQR071S8RN
Alternativelly you can also use the headphone output that is near the side input in the TV and buy an RCA adapter like this one from radioshack: http://www.radioshack.com/product/index.jsp?productId=2103225
Jan 04, 2009 | Panasonic Home Theater System System
Set up surround sound with the following
YOU CAN ONLY GET 5.1 FROM THE OPTICAL OUTPUT ON THE SKY BOX NOT THE HDMI
SO CONNECT YOUR SKY BOX OPTICAL TO TV OPTICAL
PLZ LET ME KNOW IF THIS HELPS
JonnieC
Aug 10, 2008 | Pioneer PDP-4270HD 42 in. Plasma...
No digital to reciever??
This tv will only output the sound from a digital tv channel through the optical output when using the tv's digital tuner. So if you are connecting a DVD etc it will not output through the optical output on the tv. ONLY digital chanels through the tv's tuner will give you sound. Refer to the tv's owners manual for more info.
Dec 27, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
JVC SXXSW6000 Speaker Logo
142 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
