Projection Televisions
Problem for Projection Televisions
Generic problem for all Projection Televisions
BLUE HAZE AROUND ALL WORDS
By JPKLASSI on Oct 03, 2008
Solution #1
posted on Oct 03, 2008
Not Rated)
Shuttle83
Rank: Guru
Rating: 85%, 988 votes
Hello JPKLASSI,
Check your convergence first, use the AUTO adjust feature first then see if this clears up the problem. If the Auto adjust does not work then the following may be in order:
Only do this if you have a background in electronics, if you do not get a qualified TV technician to work on this set.
If you choose to do this yourself, here are the basic instructions:
1. Unplug the TV set
2. Take the rear bottom panel off
3. look for a large heat sink with two large black ICs (STK392-110) (6 sided components but rectangular in shape) on it, and remove the board the ICs are on from the TV set.
4. Unsolder the components using a soldering iron and a suction solder remover.
5. disconnect the components (ICs) from the heat sink
6. Unsolder all of the bias resistors and replace them with the proper values (usually 220, 150, 3.3, 2.2, and 3.9 ohms)
7. install the new ICs (STK392-110)
8. solder all connections IC and bias resistors
9. Inspect for shorts
10. reinstall circuit board
11. Plug the TV set in and turn it on.
I hope this helps
Thank you,
Shuttle83
Was this helpful?
Yes
No
Popular Solutions for Projection Televisions
Questions and Unsolved Problems for Projection Televisions
Answer
jvc 70' lcd tv. power indicator light flashes fast upon power up. no picture
Answer
The TV had a power surage. the T840 transformer is head. Toshiba says not available... (More)
Answer
i have a 52in rca it wont power up no sound just clicks what is this
Answer
I have a 62 inch samsung lcd tv and it keeps turning off. The sleeper mode is not on. I thought it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in , HI
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
