Run a setup with the command-line parameter
Hi
Would you please help in how to Run a setup with the command-line parameter.
Thanks in advance.
    Novelist:
  • 124 Answers
If you're looking for setup.exe's authored with Installshield or something similar, check this out.
Hope this helps.
Posted on Oct 03, 2008
Hi, we're trying to use PsExex utility to launch 2 .exe files with some parameters on some server from a client application. The server is running Windows server 2003, the client Windows 7 Professional...
psexec in fact does run as the user running the command window that initiated the command. I use this command almost daily to run either command shells, batch or vbscripts, etc on remote computers. I've learned some about its behavior from watching the results.
Basically, psexec copies itself to the ADMIN$ share on the remote computer. It then installs a service on the remote computer, and runs that service, which is the copied file. This then executes the command that you specified in the psexec command line.
So, with that in mind, the user running psexec from the command line needs to have admin rights to the remote computer. You can bypass this requirement by using the "-u" parameter, and specifying a domainname\username. Domainname can be the remote computer's name if you have a local user. By putting in just the -u parameter, you'll then be prompted to type in the hidden password.
Once running on the remote computer, psexec will function in one of three ways:
1 - If no special parameter used, will run in the same user account as the person initiating the psexec command.
2 - If the "-u" parameter is used, it will run as that user.
3 - If the "-s" parameter is used, it will run as a local system account
In either of these 3 cases, you first have to have admin rights to use the ADMIN$ share and install a service.
When domain membership is broken on a computer, I'll frequently use a command line like this:
psexec -u COMPUTERNAME\Administrator \\COMPUTERNAME cmd.exe
This will allow me to have local admin rights by connecting to the remote computer as the local administrator account. It will also run the cmd.exe command as the local admin account.
Aug 30, 2011 | Microsoft PsExec
Code ck sr tuner no sound
Hello
So many improper commands send to the unit may make its system and memmory to be confused, and will not operate properly. Just reset the unit to factory settings, and try.
To reset the unit to factory default settings, so the following
[1] Press STANDBY/ON on the front panel to set this unit to standby mode.
[2] Press and hold TONE CONTROL and then press STANDBY/ON to turn on this unit. The advanced setup menu appears, in the front panel display.
[3] Press PROGRAM buttons to select PRESET.
[4] Press STRAIGHT repeatedly to select RESET.
[5] Press STANDBY/ON to confirm your selection and set this unit to the standby mode.
This procedure completely resets all parameters of this unit including SET MENU parameters. However the advanced setup menu parameters will not be effected. The intial factory paramenters will be activated next time when you turn on this unit. To cancel initilization procedure at any time without making any changes, press STRAIGHT repetedely ot select CANCEL and then press STANDBY/ON.OK.
Apr 03, 2011 | Yamaha RX-V463 Receiver
Error 118, google chrome
This problem is occcured due to the IP Address you need to renew the IP Address. To do this follow the steps below:
1.Get to a command prompt in your startup menu and
type: cmd or Click on Start and then Run.
now you are in command mode
2.type: "ipconfig/release"
(without the quotes ,on the command line by itself)
3.type:
"ipconfig/renew" (without the quotes ,on the command line by
itself)
done!
hope this answer can help
If you like the post then please leave a feedback and rating.
Thanks in Advance.
Oct 06, 2010 | Google Chrome
I am having problems with downloads with my WBR-2310 Dlink Router. The downloads are much quicker without it in line. How can I fix this? Do I need to make some type of parameter change within the router...
Yes check this settings in your Router Setup Page.
In your D-Link Setup Page.
Go to Advanced Tab > Advanced Network
Check the following :
Enable UPnP
Enable Wan Ping Respond
( Wan Port Speed - set to Automatic )
Enable Gaming Mode
Enable Multicast Speed
Save the changes.
Jan 24, 2010 | Computers & Internet
Hp s3700y when i acess my live mail acct. my internet connection terminates
Hi, Make sure that your the box to automaticaly disconnect is not checked in your email program. If it is not here is a another thing to try. This is a setting to the registry so make sure you back it up before you change any thing. Just in case some thing goes wrong. Start/Run/Regedit HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\LanmanServer\Parameters. In the right pane, find Autodisconnect and change the time accordingly. Or... Start/Run/net config server /autodisconnect:30 (30 being an example). The valid value range is -1 to 65535 minutes at the command line. To disable Auto-Disconnect set it to -1. Setting Autodisconnect to 0 does not turn it off and results in very fast disconnects, within a few seconds of idle time. (However, the RAS Autodisconnect parameter is turned off if you set it to a value of 0.) Hope i helped you. Thanks for using ' Fixya ' and have a nice day!!
Sep 26, 2009 | HP Computers & Internet
Installing yahoo messenger incorrect command line parameters
why cant i send a message to all my friends on yahoo messenger?how can i solve this?
Jul 02, 2009 | Yahoo Messenger
Chkdsk will not run
You need to run chkdsk /F /X and then the drive letter c: for example.
May 03, 2009 | Seagate USB 2.0 External Enclosure + 400GB...
Installing Yahoo Messenger
download yahoo messenger stand alone version from here
select your country then download
http://www.mydigitallife.info/2009/11/16/yahoo-messenger-10-final-full-version-offline-standalone-setup-installer-download/
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Apr 09, 2009 | Yahoo Messenger
Can't access 3Com OfficeConnect Router browser
you go to start, run, type cmd. and then type ipconfig. locate the ip for default gate way. Use the ip to go to your browser.
Aug 10, 2008 | 3Com OfficeConnect Router
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
