Question about Panasonic PT-47WX51 47" Rear Projection Television
Panasonic projection tv (shuts down)
MODEL NO. PT47WX49 got problem,abruptly shut off when power on.....pls help me I had been hearing a pop every now and again when the tv was on. Now, the tv will begin to come on with a steady LED light and sound. However, before the picture fully comes in it shuts down without warning. It will not come back on unless I unplug it and try to turn it on again. BUT it repeats the same cycle. Please help.
  • Anonymous Jan 29, 2009
    My tv turns on with steady led light, then goes off without picture coming on. Smelled like electrical burn at back of tv.
    Problem Solver:
  • 11 Answers
Check r517 on the power supply board if it is burnt or damaged replace it with a + or - 5% 10K 1/4 watt resistor this has been a problem in other units.
Posted on Dec 23, 2008
I have a Panasonic PT-47WX42 .. porew light flashes 3 times the stops,, then repeats..if I unplug the power cord then turn on the tv. it warmsup the picture comes on for maybe 3 sec then hear a click just...
The 3 blinks is indicating the set has shut down due to the convergence circuits. You can get the convergence repair kit for your model from www.tvrepairworld.com the kit contains the parts and the CD with repair instructions.
Jul 28, 2011 | Panasonic PT-47WX42 47" Rear Projection...
The tv is only 4 years old and just stopped working while we were watching it. it is a "52 model number pt-52lcx65-ka.
If lamp in tv has not been replaced in last 3-4 years then check lamp and replace it.
Did tv showed lamp replacement requires warning/ message on screen before going to shut down?
Did you hear any pop sound inside tv when it get shut down? that pop sound could be lamp that got broken.
Let me know if you have additional question.
Thanks.
Feb 27, 2011 | Panasonic PT-52LCX65 44" HDTV
My tv powers on and then shuts off in a few minutes. I love this tv and the picture looks great, i think its a fan problem. But not sure.
Do you see any light lit solid/ blink when tv shuts down?
Let me know is it Panasonic PT-50LCX63 or any other model?
Above info will help me to diagnose problem and to suggest a solution.
Thanks.
Jan 24, 2011 | Panasonic PT-50LCX63 50" Rear Projection...
Pt47wx49 panasonic rear projection tv has very dark tv scenes
Has this problem been getting progressively worse? I would suggest cleaning the CRT's inside the tv with lcd screen cleaner or something similar. Make sure the tv is unplugged, all you have to do is undo some screws on the back to gain access to the inside of the cabinet. Hopefully that's all it is. Your set has no lamp if it is a Panasonic Pt47wx49.
Nov 29, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Toshiba shuts dowm
pls .check your tv power cabel pin and plugg bitwin sparked or luss canaction [pls unplugged cabel pin and see tv. power cabel pin on top side black spot.]
pls try power cabel properly canact if loose replace with new.
NOTE:most of tv poblum is making power cabel loose. so canacting tv power cabel or power bord check with electrician
Oct 08, 2009 | Toshiba 42H81 42" Rear Projection...
When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
915P028010
Mar 13, 2009 | Mitsubishi WD-62526 Projection TV
TV powers up for literally a second then shuts down (PT-47WX49)
check R517 on the power supply board if burnt replace with 5% 1/4 watt 10K carbon resistor.
Dec 12, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Does the power indicator blink? Let me know and I will try to help you out. Just keep responding to this same psot so previous info will still be available.
Jun 30, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Shutting down....
You have POWER supply board that went out.....apparently this is a common thing for this model.....sorry to see such low activity on this site......hope it helps.....
Apr 13, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-47WX51 47" Rear Projection Television Logo
207 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
