Question about Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
Lexmark x7170 3 blinking blue lights
The power went out for 12 or hours. When it returned, the printer came back on with the fax,copy and scan lights blinking constantly. I try to print and the message says check connetions, usb port and restart. i have done that. HELP
  • chrst2764 Oct 03, 2008
    Thank you for your help!!
SOURCE: lexmark x1180 doesn't want to print
i am trying to download a driver for my printer which is Lexmark X1180
Posted on Jan 26, 2008
  • 813 Answers
SOURCE: What's wrong with X7170 copy/scan functions?
ya u need to change your blub
Posted on May 11, 2008
  • 1027 Answers
SOURCE: How do I set up my X7170 to receive a FAX?
Receiving a fax You can choose to receive a fax automatically, manually, or through an answering machine.
Note: For your All-In-One to receive a color fax, the machine from which you are receiving must also support color faxes.
Automatically Recommended for a dedicated fax line
Your All-In-One automatically accepts incoming faxes using the automatic answering mode. When the Auto Answer light is on, the All-In-One receives a fax after the specified number of rings set in the Options menu.
To set a number of rings for the automatic answering mode:
  1. On the control panel, press Mode repeatedly until Fax is selected.
  2. Press Options until ANSWER FAX WHEN appears.
  3. Press + to choose After 1 ring, After 2 rings, After 3 rings (default), or After 5 rings.
  4. Press Select.
  5. Make sure the Auto Answer light on the All-In-One is on.
When the number of rings that you set is detected, the All-In-One automatically receives your fax.
Manually Recommended for a shared fax and telephone line
You can choose which incoming faxes to accept by setting your All-In-One to manual answering mode.
  1. Make sure the All-In-One Auto Answer light is off.
  2. Press *9* on the telephone after you answer the telephone and hear fax tones.
  3. Hang up the telephone.
The All-In-One receives your fax.
Answering machine Recommended for a shared fax and telephone line
To receive a fax with an answering machine connected to your All-In-One, set the answering machine to answer incoming calls before the All-In-One does. For example, if you set the answering machine to answer calls after 3 rings, set the All-In-One to answer calls after 5 rings.
  3. Press + until After 5 rings appears.
  4. Press Select.
When a ring is detected, the answering machine picks up the call.
  • If a fax is detected, the All-In-One receives the fax and disconnects the answering machine.
  • If not, the answering machine completes the call.
Note: You must set up the equipment as shown in connecting to an answering machine.
Posted on May 21, 2008
SOURCE: Lexmark X 1270 Can not Print
I may be a bit late with this but it worked for me. Uninstall your antivirus, remove any parental controls and disable your firewall. Then, reinstall the printer and download a 2008 version of your anti virus and re-enable your firewall. I haven't reactivated the parental controls just in case it all goes pear shaped.
Posted on Nov 06, 2008
  • 3 Answers
SOURCE: Lexmark Printer Install - No Communication Error
Download the 64 bit version of the driver even thought you have a 32 bit operating system. there's a problem with lexmark's 32 bit driver for the X5495
Posted on Feb 03, 2009
I have a Lexmark X8300. All was ok till recently. I can print out anything from the computer but can't use the copy feature. Also, all of the lights stay on - the copy light, fax light, scan light,...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 23, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
My lexmark x7170 all in one won't copy or scan starts to but stops
It could be a scanner hardware problem. Try to unplug the printer from the power source to reset it. Wait at least 10 seconds and then re-plug the printer back into the power. If problem continues, please don't hesitate to contact Lexmark Technical Support Center for additional assistance.
Jun 29, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Want copy ---comes up unrecoverable scan---ties up machine for 5-10 minutes---LEXMARK 5600-6600---IT also makes a knocking sound. until red light goes off and green light comes.on---1st time happened...
Unrecoverable scan error is a hardware problem. Features affected by this error are scan, copy and fax. Recommended action is to contact Lexmark technical support for assistance.
Sep 20, 2010 | Lexmark All-in-One Printer with PictBridge
Lexmark x9350 will not copy or scan.
Great job on trying to do it both ways, scanning and copying. Try to refresh the printer by uplugging the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Make sure other end of the power cord is plugged in straight to the power outlet in the wall, bypass any surge device or power strips. Plugged the power adapter back in the printer after 30 seconds. It should automatically turn on. If not, press the power button. Try scanning and copying again. If problem persists, I strongly suggest you contact Lexmark Technical Support to further investigate the hardware problem in the printer. Hope I can assist you more on this.
Jun 29, 2010 | Lexmark X9350 All-In-One InkJet Printer
No power on my Lexmark X8350
That's the same printer I have.
First, make sure the blue "copy" button is lit. Printing is done there.
Then, go to the circle with the checkmark in it and hit the menu, and arrow down to copy papy size and make sure it says "letter".
Click start on your computer, then click control panel, then printers, and make sure Lexmark 8300 series is the default printer and has a green checkmark in a circle.
If all these things are right, you should be able to print a test page and the computer should work fine.
If any one of them are wrong they must be corrected. If you need help on any one of those please write back.
May 14, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Lexmark x7350 will not scan, fax or copy
If under warranty contact mfg for warranty repair locations
Sep 09, 2017 | Lexmark X6170 All-In-One InkJet Printer
Lexmark x4270 copy and fax
The definition corresponding to this error message is this: "The print carrier stopped before all of the data was used." To resolve this issue, please do the following:
  1. Power the printer off.
  2. Remove all cables from the back of the printer.
  3. Reinsert the power cord.
  4. Switch the printer back on.
  5. Check the operator panel to see if the 1201 error message is displayed.
  6. If the error message returns, the printer could be defective. Contact Lexmark Customer Support for further troubleshooting and warranty options.
Please rate this solution. =)
Jul 14, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lights BLINKING continously
Don't waste your time with this site! If your printer is under warnety take it back. Otherwise, buy a new one. FixYa wants you to subscribe to their site for $20!
Call me cheep!!!!!! Call me feed up with it!!!!!!!!
Jan 13, 2008 | Lexmark X7170 All-In-One InkJet Printer
Need help on my lexmark x 4270
Fax does not require installation on the PC. Driver for Vista is here:
Aug 29, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer Logo
79 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
