REMOTE CONTROL I HAVE DISH NETWORK AND I AM HAVING A PROBLEM WITH THE REMOTE CONTROL #2. I CAN NOT GET IT TO CONTROL THE ELEMENT TV THAT I JUST BOUGHT. I SET IT WITH THE DISH NET WORK CODE 627 AND 659 BOTH. REMOTE CONTROL #2 WILL NOT CONTROL THE TV. IT WILL CHANGE THE CHANNELS BUT WILL NOT TURN THE TV ON AND OFF.
  • 8 more comments
  • OLD SGT Oct 03, 2008
    THIS DOES NOT WORK
  • OLD SGT Oct 04, 2008
    THIS DOES NOT FIX THE PROBLEM
    THE DISH NETWORK CONTROL IS THE ONE I AM TRYING TO PROGRAM TO CONTROL THE NEW TV. THE TV IS A ELEMENT 19" LCD TV FLW-1920B
    0178 DOES NOT WORK. THE TWO CODE THAT CAME WITH THE TV ARE 627 and 659 BUT THEY DO NOT WORK.
    THE REMOTE DOES NOT HAVE A SET UP BUTTON.
    IT IS A DISH NETWORK #2 4.0 IR/UHF PRO FCC ID:DKNFSK01 ECHOSTAR TECHNOLOGLES 119947 MADE IN MEXICO
  • OLD SGT Oct 06, 2008
    NICE TRY BUT NO PRIZE. NOTHING WORKS.IT WILL WORK WITH THE #1 CONTROL BUT NOT #2.
  • OLD SGT Oct 10, 2008
    IT IS NOT AN EMERSON TV. IT IS AN ELEMENT TV. MY DISH NETWORK HAS TWO REMOTE CONTROLS. CONTROL #1 USES INFRARED (IR) LIGHT SIGNALS TO CONTROL TV1. REMOTE CONTROL #2 uses UHF PRO SISNALS TO CONTROL TV2. CONTROL #1 WORKS FINE WITH THE NEW TVS. IT IS TV2 THAT I CAN NOT GET TO WORK.
  • Anonymous Apr 18, 2009
    Is there a solution?? If so, what?
  • Anonymous Mar 14, 2014
    The dish net work remote for bedroom will not change channels
  • 1,879 Answers
any word from DISH about compatible TV's with that remote ?
Posted on Oct 06, 2008
    Sergeant:
  • 208 Answers
I hope this would be helpful........
www.remotecodelist.com/remotes/emerson/emerson.html
Thanx...
  • 171 Answers
If you're lucky it will respond to code 10178, if not then you will need a rc64 directv remote and try the proview codes. The proview codes are worthless in any other directv remote other then the rc64 series.
Posted on Oct 04, 2008
  • 3 more comments
  • Todd Gale
    Todd Gale Oct 04, 2008
    ALSO try code 10835.
  • Todd Gale
    FYI folks at ELEMENT Electronics advise to use code for GOLDSTAR or try 0030 or 0004 to program DTV remote
  • Todd Gale
    time for you to do a codesearch, try searching by volume with tv on:
    1. tv
    2. press and hold MUTE & SELECT for two blinks
    3. enter 9 9 1, wait two blinks
    4. enter 1
    5. press and release the VOL UP key
    6. with tv on and remote pointed at it, keep pressing and releasing the CH UP key, if and when the volume changes
    7. press SELECT to lock in code
    If you dont get a positive response, then you know for sure there isn't a code to find.
    The remote manual instructions worked with my Element LCD2610 model.
    Keep hitting the ch up/down button until you have done it 298 times
    then hit the volume button and it will change. Then press select. All
    functions work on my RC64 remote now. Still do not know what code
    # 298 is but the remote works.
  • Todd Gale
    Addressing to Other Equipment Using Power ScanNote: After this procedure is started and a button is not pressed within 20 seconds, the remote will end the procedure automatically. Simply start over again.
    1. Verify the remote is a DISH Network remote. Look for the DISH Network logo on the bottom of the remote and Mode buttons or lights at the top. Why?
        We have the codes for all DISH Network remotes and would be happy to help you with your DISH Network manufactured remote. Please contact the manufacturer of your remote for further assistance. Detailed instructions may be included in the owners' manual that came with your equipment. If not, there may be a toll-free technical support number listed.
    2. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate (about 3 seconds), then release.
    3. For AUX mode Power Scan ONLY: press 0 for a TV, press 1 for a VCR/DVD, press 2 for any other device, then press *.
    4. Press and release the Power button.
    5. Press the Up button once per second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
    6. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
    7. To verify the code works try several different functions for that equipment.
  • Todd Gale
    Please follow the steps below to program your remote control to equipment other then your DISH receiver:
    Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
    1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
    2. Press the numbers 5-0-0 on the remote control.
    3. Press the Pound (#) button on the remote.
    4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
    5. Press and release the Power button on the remote control.
    6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
    7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
    8. To verify the code works try several different functions for that equipment.
    We cannot guarantee our remotes will work all other devices. If this does not correct the issue, unfortunately our remote will not work for that device. We apologize for any inconvenience this may cause.
    __________________
    President:
  • 2,712 Answers
You can try the following procedure to find the TV's code:
  1. PRESS the device, (TV, VCR, CABLE, etc.), button - RELEASE
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. PRESS 9 - 9 - 0.
  4. PRESS 1, carefully COUNT the number of blinks. (1st digit)
  5. PRESS 2, carefully COUNT the number of blinks. (2nd digit)
  6. PRESS 3, carefully COUNT the number of blinks. (3rd digit)
  7. PRESS 4, carefully COUNT the number of blinks. (4th digit)
If the remote DOES NOT blink it means the number is 0.
This is your 4-digit setup code.
If that does not work, try the following procedure to search for your code. (If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.)
  1. PRESS the button for the device you want to program, (TV) then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
After getting the proper codes from your manual or Customer Service, use the following instructions to enter them into your remote.
  • PRESS the button for the device you want to program, (TV) then RELEASE.
  • PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  • ENTER the 4 digit code for your brand.
  • You should receive 2 quick flashes after entering your code.
  • PRESS the POWER button to test the code.
  • Hope that helps! Should you have any further questions, please post them here.
    If you are satisfied with my solution or have no further queries, please take a moment to "Accept" this solution.
    Thank you for using Fixya!
    Cheers!
    IrishDruid
    Posted on Oct 03, 2008
      Scholar:
    • 188 Answers
    I just read in a thread to try 0178. This code is 1 year old. The other comment was that Element did not have plans to include a universal code I hope this works.
      Scholar:
    • 125 Answers
    I can help you with your problem all i need to know is what kind of remote you are using example the company that makes the remote and model number. If you would be kind enough to provide that information i would be more than glad to assist you with the problem.
    Thank you,
    Jacob
    • Jacobis Soriano Oct 03, 2008
      I found some info here. If its for a Vizio the codes are 627 or 505.
      Genius:
    • 1,913 Answers
    Reconect your cell or battery of remote again to it.
    try to reset your remotecontrol.
    if possible open the case of it check that button of on and off press and contact properly.
    • 360 Answers
    Remove the batterys to reset memory. store your oyher codes in it before you do this........
    Lost my Dish network remote for the upstairs tv (LG) - which has NO box. Is there anyway to program my TV remote, so I can access the TV staions - turn on the network basically???????
    No,the Dish Network satalite box signals require it own remote for it INFER RED INPUT and INFER RED OUTPUT signals.Call Dish Network customer service ask for a another original Dish Network remote.U pay $5 or $6 dollars a month for the satalite box as rental.They should wave the fee or charge u very little for a another remote.
    Sep 05, 2011 | Universal Remote Control Dish Network...
    I need a code for my element tv for the dish remote
    Hi there! This is Cheri Torres with DISH Network customer service. I was reading through the questions posted here and wanted to see if I could be of assistance to you. :) We have a few different codes for each of our different IR remotes, so I will give you the remote codes that work the best for the most common remotes that we have. For the 3.0, 3.1, and 3.2 IR remotes the best codes are 627 and 659. For our 5.0, 5.2, 5.3, and 5.4 IR remotes the best codes for the Element TV are 627 and 902. I would also like to list for you the instructions for addressing your remote to your Element TV. I hope you find these codes and instructions useful. If you have any further questions regarding this issue or any other issue please feel free to post back here or email me at Cheri.Torres@Dishnetwork.com.
    Instructions for addressing your DISH remote to your TV
    1. Turn the Television On.
    2. Press and Hold the TV mode button for three seconds until all of the mode buttons light up. Once you release the TV button it should flash.
    3. Enter the three-digit code using the buttons on the number pad.
    4. Press the pound(#) button once. Note: The LED will flash three times.
    5. Test functionality with the TV
    6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
    Dec 08, 2010 | DISH Network IR Remote Control
    My dish remote does not control my element tv do someone needs the codes?
    castro_ed387, I am unable to provide you a code as I do not know the remote model, but the steps below will help in programming the remote to the TV, and I included a link on the bottom that has the codes on it.
    Program to TV:
    2. Press and hold the gray TV button on top of the remote until all lights turn on.
    3. Let go and TV will be blinking, enter the three-digit code using the buttons on the number pad.
    4. Press # and test functionality with the TV
    5. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television. If it works press SAT.
    Link for codes: http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml
    Tommy Faust
    DISH Network
    Oct 04, 2010 | DISH Network IR Remote Control
    Dish Network remote will not turn the set on or off and will not adjust the sound level. Dish tells the they do not have the code For Element TV's and I will have to use 2 remotes. Can you solve this...
    Sometimes the remotes have a hard time programming to the tv. Below is the link to the steps for a power scan. Instead of needing a code to program the remote, the remote will scan through the codes on the tv until it reaches the one that works. I hope that this helps!!!!
    http://www.dishnetwork.com/SupportSection/power-scan-instructions
    Becki Barned
    DISH Network Customer Service
    Sep 16, 2010 | Element Electronics FLX1911B 19 in. LCD TV
    Dish remote
    cathyw43
    I have provided instructions on how to program your DISH remote to your TV. I have also provided a link with the codes for TV manufacturers. I hope this helps.
    Program remote, step 6:
    Ray Calo
    DISH Network
    May 29, 2010 | DISH Network IR Remote Control
    Setting my Dish network remote to new tv
    customz28,
    Since you have tried several codes for your TV, the next procedure to attempt would be a power scan. I have provided a link with the instructions. The link is:
    I hope this helps.
    Ray Calo
    DISH Network
    Feb 19, 2010 | Universal Remote Control DISH Network...
    Program sony remote to operate dish vip722
    The Sony RM-YD029 Remote control will work with the Dish Network VIP722 DVR HD Satellite Receiver, but the Dish Network VIP722's Primary remote address must be set to 1.
    The procedure below will allow Sony RM-YD029 remote control to operate Dish VIP722.
    Using the Dish Network Remote Control -
    1. Press menu 2 times to get to system info page
    2. In the system info page the primary remote address is in a white box (bubble) followed by a Green TV (1)symbol that says IR and indicates you the channel your remote control one is configured. The Sony RM-YD029 will work when this primary remote address number (in the white box) is set to 1.
    If the Primary Remote Address of your VIP722 Remote control 1 is not set to channel 1, here is how to change it:
    1. While displaying the system info page, press and hold the SAT button on your dish network remote until all other modes are flashing, about 3 seconds.
    2. then press the '1' button on the numeric pad of your dish remote
    3. then press the '#' button on the numeric pad of the dish remote
    4. then press the 'record' button (red dot button - stores setting)
    5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
    Ensure you enter the corresponding IR code into your Sony remote control per the instructions in the manual or Sony's web site. My 722 works with Sony IR code - 01775.
    Sep 08, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
    Need Dish DVR ViP722 remote code.
    If you are looking to have the Dish remote operate your TV, just do a random search for your tv. First, hold down the tv button on the dish remote until all the rest of the light up. Next press the tvpower button on the dish remote. Next, press the channel up button (this is the up arrow button) until the set turns off. When it does turn off, press the # key at the bottom right of the remote. The tv button will light and flash twice. That's it. Your done. Hope this helps.
    Feb 20, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
    Dish network remote with a element tv
    Since you dont have a popular brand set you should try using the scan method. Here is a link with a video to help program your dishnetwork remote to work with your set. http://www.disheez.com/videos/dish-network-video/programming-dish-network-remote/
    Nov 23, 2008 | DISH Network IR Remote Control
    Elements TV need code
    the new element television I purchased listed codes in the manual (on the back or as an insert) for dish network. Worked on mine.
    Apr 11, 2008 | Televison & Video
    Televison & Video Logo
    2,255 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
