Question about Motorola Mobility DRC800 Universal Remote Control
Device Code for Insignia TV
Cannot find the device code for a new HD Insignia TV.
  • tvisner Feb 01, 2009
    Looking for the device code for Insignia model NS-LCD26A
Hi, I have tried about everything I could find on the internet, and I just found the one that worked, its 1033... Hope it works....
Posted on Dec 26, 2008
  • 520 Answers
RC-800M Remote Control
Are you trying to use the Insignia RC-800M to control a TV or some other JVC device? How old is the JVC product? Most universal remotes won't control a device that was built within 6 months of when the remote was programmed. (Newer devices will not work at all with an older remote.)
The RC-800M code for a JVC TV is 11601. For a JVC set-top box try the codes: 00775 or 01775. For a JVC DVD or Blu-ray player, try 32365. The manuals for most of the Insignia devices which came with the RC-800M remote are available from the Insignia support site: http://www.insigniaproducts.com/support.html .
I hope this helps.
Oct 01, 2013 | Insignia RC-800M Remote Control
Program my insignia zrc-101 remote
Your Insignia remote already contains the codes. The instructions for your remote will tell you whether there is a code available for the device you want to control (TV, etc).
Dec 02, 2012 | Insignia New Original ZRC101 Remote...
Trying to program Insignia remote to JVC TV
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Codes for JVC TV are: 0060 0026 0197 0069 0247 0923 0012 0065 0067 0141
Aug 19, 2012 | Insignia New Original KK-Y284B Remote...
WHATS DE CODE NO.
Hello
You are in need for universal remote code for Insignia TV, I assumes and post this solution.
Four digit universal remote codes for Insignia TV are:
0103 0189 0217 0135
0133 0116 0167 0456 0029
Direct Code Entry
CODE SEARCH METHOD
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Sep 11, 2011 | Insignia 42" LCD Flat-Panel HDTV
Need the code for insignia tv, so I can watch it thru my cable dvr...can't get the correct code for the remote
Hello
Four digit universal remote code for Insignia TV are:-
0103 0189 0217 0135
................. 0133 0116 0167 0456 0029
Direct Code Entry
[edit] Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
OK.
Mar 08, 2011 | Insignia 32" 720p Flat-Panel LCD HDTV
Need the code for insignia dvd player
Hi, unfortunately there is no code for insignia dvd players with this remote. But you can do a code search and see of another code will work for it. Usually there is another code that is compatible. Try these steps below,
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then
release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off.
NOTE: In the search mode, the remote control will send IR codes from its
library to the selected device, starting with the most popular code first.
5. To lock in the code, press and hold SET until the LED blinks
twice, then release SET.
6. To search for the codes of your other devices, repeat steps 1
through 5, but substitute the appropriate device key for the
device you are searching for.
Feb 10, 2011 | One For All URC-6011 Remote Control
INSIGNIA TV'S REMOTE CONTROL CODES FOR PROGRAMING A UNIVERSAL REMOTES
Hello
Four digit universal remote control codes for Insignia Tv are :-
0103 0189 0217 0135
Direct Code Entry
OK.
Dec 13, 2010 | Insignia NS-24 TV TV
Remote code for my new insignia 19 inch tv using a verizon remote
A variety of remote control codes can be found at InsigniaProducts.com; just search for your TV model number and click Support. Also, try codes for the following brands: Orion, Emerson, Memorex, Sansui, Sylvania, Zenith.
May 10, 2010 | Insignia 37" LCD Flat-Panel HDTV
I can't find the code for my insignia TV, for thr universal remote control
Found this bit of info online:
PROBLEM: Tried “Search Method” and still could not find a working code.
SOLUTION: Try the “Search Method” again after clearing out the device key as follows: Press and hold SETUP until device key blinks twice, then release. Next enter 9 - 9 - 2.Then press and release the device key to be cleared twice.
And then I'm assuming you already have the instructions for searching for codes, but I'll post here anyway.
1. Turn on your TV.
2. On the remote control, press TV once; it will blink once.Then press and hold SETUP until the TV key blinks twice, then release SETUP.
3. Enter 9 - 9 - 1.The TV key will blink twice.
4. Aim the remote control at the TV and slowly alternate between pressing PWR and TV.
NOTE: In the search mode, the remote control will send IR codes from its library to the selected device, starting with the most popular code first.
5. Press SETUP once to lock in the code.The TV key will blink twice.
6. To search for the codes of your other devices, repeat steps 1 through 5, but substitute the appropriate key (e.g., AUX, DVD, AUD, or CBL) for the device you are searching for
Dec 27, 2008 | Insignia IS 20" TV040919 TV
Code for insignia tv
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
then release SET.
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
1 through 5, but substitute the appropriate device key for
the device you are searching for.
Nov 23, 2007 | One For All URC-3021 Remote Control
Televison & Video Logo
712 people viewed this question
Top Motorola Mobility Televison & Video Experts
Are you a Motorola Mobility Televison and Video Expert? Answer questions, earn points and help others
