Question about Dell Dimension 2400 PC Desktop
Cd rom My cd rom stoppped working what could be the problem
  • 41 Answers
You might want to try this, try to boot to the disc by pressing F12 on the Dell Splash screen. You will be redirected to the boot menu options, select CDROM then press enter. Make sure to use a windows disc to do this since this is the main bootable disc that we can use. If it was able to boot up to windows setup, the Drive is working as designed, otherwise, a windows issue.
Let me know if this is helpful.
Posted on Oct 07, 2008
    Scholar:
  • 155 Answers
It depends on the symptoms. Insert a cd in the drive and check what exactly happens when you go to My Computer and double-click the drive letter for the cdrom?
What error do you get?
Posted on Oct 03, 2008
My cd rom drive does not recognize media
First check CD (bad, scratch) Change it... if not OK then
then Check Software (like media player, VLC player) re-install it
if not OK then...
Then check Cable of cd rom (loos connection) in not OK then
bring any friend's or neighbor's CD ROM for few minutes and replace... if other CDROM working ok then problem in your CD ROM
open cd rom and Check Lance (head) of CD rom... mostly lance not working in these cases.
Oct 13, 2012 | Dell Inspiron 8600 Notebook
CD-ROM drive doesn't acknowledge DVD-ROM, what's wrong?
CD-ROMs dont play dvd becuase they are not designed to read dvd.
If a dvd drive for your model is not available, you can buy an external usb dvd drive.
That should solve your problem
Dec 28, 2009 | Dell Dimension E521 PC Desktop
My samsung cd-rom sc-148c drive is not working. It is not listed in "My Computer". I have uninstalled and reinstalled it but that does not work.
Is the CD-ROM drive on a separate cable on the second IDE controller on the desktop motherboard? Then the jumper setting can be set to Master or Slave if no other drive is connector to this cable.
If the CD-ROM is also on the first IDE controller and IDE cable as the hard drive then the jumper setting on the CD-ROM must be set to SLAVE because the hard drive would be jumpered as MASTER.
Check the BIOS setting to see if the CD-ROM drive is detected.
If the CD-ROM still does not work after you checked and configured the CD-ROM drive, then is is faulty and needs to be replaced.
Dec 16, 2009 | Samsung SC-148 CD-ROM Drive
CD ROM DRIVE/DVD ROM DRIVE PROBLEM!
it is infecetd by viruses.. scan for viruses..
please vote for me...im sure this will solve your problem...
Sep 14, 2009 | Computers & Internet
New DVD burner won't read blank DVD-r's.
Hi again, just saw the brand and model number you posted.. noob me....
sorry to inform you that your drive HP 344542-005 is just a dvd rom drive. Its not a burner and will never burn a dvd. not even a cd.
Specs of drive:
344542-005
Hp 16X ATAPI/IDE DVD-ROM optical drive - With +R media read support - CD read up to 40X, DVD-ROM read up to 16X
May 29, 2009 | HP (344542-005) DVD Drive
Cd rom
go back to device manager. right click the cd rom name in device manager and click uninstall. right click on an empty area in device manager and click on scan for hardware changes. if this doesnt fix the issue try booting from a windows disk. if you are unable to do this than it may be a physical problem with the device. you may also want to try doing a system restore (if it is win me or higher) by going to start - accessories - system tools - and then system restore. follow the prompts from there.
Oct 30, 2008 | Computers & Internet
Cd/dvd dosen work pleace geimy a solution
i cant get you. cd/dvd is not working or cd/dvd rom drive is not working ? To work cd/dvd rom drive properly, Make sure the Jumper settings of the drive is set to slave or else remove all the jumpers from the cd/dvd rom drive, it automatically sets to slave. Check the power cable and the FRC(flat ribbon cable) of the cd/dvd rom drive. Hopefully it should work. Thank you.
Sep 11, 2008 | Computers & Internet
Cd-rom
CD-ROM not working in Windows 9x, 2000, or XP. If after cleaning the CDs that do not read you're still getting errors ... If, however, the CD-ROM does not work, refer to the next and final possibility
CD-ROM recieving power but does not work. CD-ROM receiving power but does not work. Issue:. CD-ROM receiving power but ... CDs are read by a laser within your CD-ROM drive
Good Luck/Please dont for get to Vote, Thank You.
Dec 15, 2007 | Acer Aspire 3610 Notebook
CD ROM Won't work
First you want to make sure the CD you are using is good. Try a different CD-ROM, a known good one. If a different CD-ROM is readable then the problem is with your CD media and not the CD-ROM Drive. If another known good CD does not work then the problem is with the drive.
To fix this you must purchase a new CD-ROM drive and install it. Newegg.com has great deals. If you only want to read CDs and are not interested in burning then you can get a name brand CD-ROM drive for around $15.00, but if you need to burn as well the CD+-RW will run you about $30.00.
If you are using Windows XP then it is pretty simple to install the new CD-ROM drive.
Nov 20, 2007 | HP Pavilion a1330n (EL466AA) PC Desktop
Dell Dimension 2400 PC Desktop Logo
Alun Cox
