Question about Kenmore 18 in. 14432 / 14439 Built-in Dishwasher
Trouble shooting kenmore dishwasher
Standing water in the bottom after dishwasher is run.
  • Anonymous Mar 17, 2009
    No water coming into our 11 year old dish washer
I have a kenmore ultra wash II Model #1675590 Serial # FC1024731
Will not run and water is standing in the bottom. I have checked the electrical breaker and tried different cycles. Can you help.
Posted on Mar 16, 2010
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
Water standing in the bottom of the washer but it runs.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 29, 2010 | Kenmore Dishwashers
Water standing in bottom of dishwasher,after wash cycle is finished? This is a Kenmore model 665.1565591
My problem too recently.
I blew compressed air back through the drain line and let it bubble up in the standing water in the dishwasher. Then I put it through another cycle and everything was fine. Something must have gotten clogged and the air blew it out.
Mar 19, 2009 | Kenmore Dishwashers
Dishwasher won't run. Light flashing on Air-Dry button.
check bottom of dishwasher, front left, round breather, gets clogged...clean and restart
Mar 13, 2009 | Dishwashers
Water in the bottom of dishwasher
try running it empty there is usually a drain hole in the bottom check if anything is in it or try a dish washer wash solution I bet the drain or drain line is cloged let me know if this dont work. Hows your sink draining
Feb 15, 2009 | Kenmore 17459 Free-standing Dishwasher
Water left in the bottom of dishdraw
Try running a wash with a dishwasher cleaner product.
There may be a slight blockage of the outlet pipe caused by grease. On a kinked pipe this will be enough to stop it emptying properly.
Make sure the outlet pipe has a plastic former to prevent a kink at the highest point, and that the hose isn't flattened or pulled taut.
If after running the cleaner and checking, there is no improvement at all, the pump impeller may be obstructed or a replacement pump needed.
Hope this helps your problem.
Jun 14, 2008 | Fisher and Paykel 23 in. DD603H SS...
Dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Feb 22, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher won't wash!
check the sump screen on the bottom of the tank for clogs.also check the wash arms
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Kenmore 18 in. 14432 / 14439 Built-in Dishwasher Logo
1,451 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
