Ace Hardware Ace Digital Timer and Cord Combo Pack Logo
Kimberly Posted on Dec 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ace digital timer & cord combo pack
Had a power outage and now can't set the timer for dusk till dawn...or anything. It remains on constantly for all settings except F (no power). help
Gene Haynes
Level 3:
  • Ace Hardware Master 5,391 Answers
  • Posted on Jul 01, 2012
Gene Haynes
Ace Hardware Master
Level 3:
Answers
5391
Questions
0
Helped
2603949
Points
14124
Buy another outdoor dawn-dusk timer.
Timers can be damaged by simple power outage, when power resumes there is a surge.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
2answers
I am having trouble understanding how to use a photoelectric switch E210007 T-044. What does pushing the green button mean in relating to the letters or number that appears?
Here are all the functions of this switch:
F = Switch is Off
O = Switch is constantly On (no timer mode)
d = Switch turns On at Dusk, and turns Off at Dawn
1-9 = Switch turns On at Dusk, and turns Off after the number of hours shown in the display
1.-9. = Switch turns On immediately, and turns Off after the number of hours shown in the display
Dec 13, 2016 • Motorcycles
How do I set the timer for a GE relocatable power tap EMP700UL-PC?
1) Copy following links:
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1502
http://waterheatertimer.org/GE-timers-and-manuals.html#outdoor
2) Timer turns ON automatically at dusk.
Push button to select duration of ON time.
d is probably dawn, so dawn-dusk
Maybe A is always ON, and maybe F always OFF.
1-9 will be number of hours timer remains ON, for example ON at dusk and OFF 9 hours later.
Dec 02, 2012 • GE Home
I can't set my Malibu Low Voltage 200-watt Digital timer
Problem is not identified.
Is timer not functioning? Or are instructions confusing?
Add a comment with more information and include which timer you have.
There are 3 different digital timers and each works similarly.
Open following link to identify timer.
Also scroll to top of page to read advisories and tips to prolong life of power pack.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#dawn-dusk
Each of these timers is dawn-dusk timers that turn ON at dusk.
Then you can set options for how many hours the timer works until lights turn OFF.
Malibu transformer 120w 1-8100-9120-01 transformer has no power and LCD is dark. Power plug was verified to be working. Unit is new, installed, configured and came back to see if lights came on during...
I don't have repair for defect timer, except return to Home Depot and exchange for another.
Try unplugging timer to see if will reset. There is no specific reset button on timer.
Test outlet with circuit analyzer to confirm there are no electrical problems.
The label shows advisories: Don't use extension cord, unplug unit when working on bulbs, and plug unit into GFCI protected outlet to protect from surge and short.
Other advisories not shown: Unplug power pack if breaker trips or if power goes out. Wait until power is on before plugging back in. First bulb should be 10 feet from unit. Do not wrap extra cord around power pack. Match bulb wattage and power pack wattage: 200 watt power pack should have 200 watts and not more or less. Replace bulbs as soon as they burn out.
These advisories should not affect initial operation of timer, but are things that shorten life of power packs,
Open following links for resources:
http://waterheatertimer.org/images/Malibu-8100-9045-01-large.jpg
How do I set timer
manual for HB51RC
http://www.intermatic.com/%7E/media/files/intermatic/products/instructions/timers/hb61rc%20-%20english.ashx
See timer at Amazon
http://www.amazon.com/Intermatic-HB61RC-Digital-Outdoor-Control/dp/B00004W4X5
Plug timer into outlet
Plug lights into timer
Timer turns on automatically at dusk + override lets timer run during daylight hours
Timing cycle repeats each 24 hours
Use selector button to set timer
Timer must be reset after power outage or after unplugging timer.
Rotate selector button and choose one of following
F > Lights are OFF
O > Constant ON
1 through 9 > timer turns ON at dusk and turns OFF 1 to 9 hours later
d > timer turns ON at dusk and OFF at Dawn
1. through 9. > timer turns ON immediately and then turns OFF 1 to 9 hours later
Maximum wattage 1000
50 mini-bulb-string of Christmas lights is 25 watts
I HAVE MODEL #83643B POWER STAKE AND 15 FT DIGITAL TIMER AND HAVE LOST THE INSTRUCTIONS ON HOW TO SET THE TIMER CAN YOU PLEASE TELL ME HOW TO SET THE TIMER
That sounds like the Woods 17321 Dusk-to-Dawn yard stake
Product image:
http://www.amazon.com/Woods-17321-Outdoor-3-Outlets-6-Foot/dp/B000BHN4H8
Manual
http://waterheatertimer.org/pdf/Woods-17321.pdf
If this is not your timer, check following page:
Instructions:
Yard stake control outlets, and turns ON automatically at Dusk
Rotate dial to set options:
Rotate to OFF > outlets OFF
Rotate to ON > outlets ON
Rotate to Dusk-dawn > outlets on at dusk and off at dawn
Rotate to 2 4 6 8 > outlets on at dusk and off 2 4 6 8 hours later
How do I set the hb51r so it turns on and off after 6 hours?
manual for HB51RC
See timer at Amazon
Timer turns on automatically at dusk unless you set override feature shown below
Push selector button and choose one of following
F > Lights are OFF
O > Constant ON
From these instructions, you should push button until 6 displays. Timer will turn ON at dusk and turn OFF 6 hours later
If timer.
If you want timer to turn ON immediately and turn OFF 6 hours later, push button until 6. shows in display.
If timer does not display or does not operate correctly, then timer is suspect. Return timer for another one.
Setting
manual for HB51RC
See timer at Amazon
F > Lights are OFF
O > Constant ON
Top Ace Hardware Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you an Ace Hardware Hardware and Accessory Expert? Answer questions, earn points and help others
