Alesis prolinear 720 active speakers for music production. The fuse has not blown, the lead works fine but the speaker is not responding, it doesn't turn on.
  • johnnysd Nov 07, 2008
    Same problem here. They just stopped working. First one, then the other. The just won't power up anymore.
  • stacyjones Jan 30, 2009
    personnaly the same thing happened, but i open them up and two components have blown, one is a fuse i believe, but not sure what type, could do with finding a schematic, not sure what the other component is but the same components have blown on each monitor speaker
Open the rear and look on the amp board (you may have to unscrew and unclip this too) next to the small white clip that comes from the power supply.
if it looks something like this:
http://img183.imageshack.us/img183/9676/blown.png
then the following burnt out parts need to be replaced:
NTC thermistor 5 Ohm (Farnell part No:- 1704471)
and
5A antisurge fuse (Farnell part No:- 951620)
upon these parts blowing should protect the rest of the board, so that should be all.....for at least another year.
alesis will either try and charge you £20 per speaker just for parts or try and sell you the whole replacement board for about £100 each.
(the parts are under £2 each)
get some1 with a bit of soldering experience to do it if unsure.
Posted on Oct 14, 2009
  • Brambo Sep 13, 2013
    I have the same problem - no visible sign of a component being blown. No charred elements. Thought maybe a fuse but can't seem to find a fuse anywhere on the board. Any ideas?
Farmerwardy, you're a star! Was gutted when the one refused to power up today. The power board looks just like the top picture. All the components around the thermistor are a little charred but seem intact. Would you say it was fair to assume they are unharmed? Thanks very much for the info. Much love x
P.S. the part number for the fuse at Farnell has a 4 on the end (Farnell part No:- 9516204). Should make it easier to find.
Posted on Apr 11, 2012
  • farmerwardy Jul 10, 2014
    My understanding is that the fuse blows once the thermistor fries, thus protecting the other componants.
    Also since posting this reply after making the repair myself, i have not experianced a repeat.
Right monitor has stopped working, left still works
Electrical parts were bad, I returned the speakers for replacement under warranty. FYI... I opened the back and noticed an electrical burn smell.
May 06, 2014 | Alesis M1 Active 320 USB Speakers
My alesis m1 active 320 usb speakers will not turn off even when i turn the knob ALL they way off.
I have the same problem. ¿What happened when the problem started? I disconnected them and left them thus for a day or so. When I tried again, the problem happened. Did you find a solution yet?
Apr 28, 2014 | Alesis M1 Active 320 USB Speakers
No noise coming from right speaker
Change the volume control potentiometer.
Jan 31, 2014 | Alesis M1 Active 320 USB Speakers
I lost the treble on both Alesis Monitor 1 speakers. The treble is good on the amp output toward the speakers. I'm thinking they went out one at a time and I didn't realize it until I lost the...
It's probably blown tweeters. But if you want to spend the money on a hipshot guess, try to find the the crossovers somewhere first; then find the readily available tweeters if/when that doesn't work out. Google "alesis monitor one MK2 tweeter".
You could test the tweeters by just removing one non-functional tweeter and wiring it directly to the speaker leads and with REALLY LOW volume containing NO BASS see if it makes any sound, which would prove it does/does not work.
Going forward, if the speakers sound stressed at high volume - THEY ARE. Too much power or too much distortion (overdriven amplifier) will kill speakers.
Sep 16, 2011 | Alesis Monitor One Mk2 Speaker
No power or light
Or possibly the transformers! But fuses are probably inside and also check for low ohmage resistors open in the power supply!
Apr 15, 2010 | Alesis M1-Active MkII Main / Stereo...
Alesis M1 Active MKII Don't get power / Blue light is off
Sure they don't have power? Light breaks all the time on those things. If no power still, open it up and find out if there are any loose connections from the power leads. Bad power cable?
Mar 16, 2010 | Alesis M1-Active MkII Main / Stereo...
Alesis prolinear 720 powered monitor stopped working
The power amp has failled and is driving DC current to the speaker. This can destroy the speaker. It is LIKELY that one or more transistors in the power amp and possibly other components have failed.
The unit will have to be serviced by an electronics repair facility. It takes test equipment to weed out all the failed parts, and it is likely there are several since when one fails it often burns up others. Likely one of teh power transistors or the amplifier "stick" has shorted. I would guess the parts will cost under $25 but finding which are bad can be labor intensive.
In the meantime DO NOT power the unit or you may destroy the voice coil of the speaker.
Dec 14, 2009 | Alesis Music
Alesis M1 Active Mk2 Speaker won't Power Up
Hi, This is usually the Capacitor C8 on the powerboard it usually bulges and pops, its becuase its right next to a resistor which gets very hot and sometimes puts the capacitor into meltdown, yours might have gone past that stage but this is worth a look; http://www.neufeld.newton.ks.us/electronics/?p=232
Hope this helps
Cheers
Steve
Apr 14, 2009 | Alesis M1-Active MkII Main / Stereo...
Speaker will not turn on
Actully the problem is your speaker which is shorted. The speaker assembly or the one who crashed out always, when you excited the volume to max it feedback to amplifier Ic to cut the fuse blown. The amperage goes up and sent to either left or right amplifier power supply.
Even you replace the fuse with a new one it will repeat the situation and story.
later sooner it will damage more.
r_ic7
Nov 28, 2008 | Alesis M1-Active MkII Main / Stereo...
798 people viewed this question
 Grubhead
Grubhead
