The headphone jack on my RCA opal M4008A are not working i have to mess with the cord to my ear buds to get sound at all. I know its not the earbud cuz i use them on my wife ipod without a problem. please help i just got it and it doesn't work.
  • BiigCash Nov 10, 2008
    same exact problem my mp3 player's headphone jack is faulty. it goes in and out and i kno itz not the headphones 4 a fact bcuz i use the same 1's on my laptop
  • sariahsue Jan 05, 2009
    Me too. I have to wiggle the headphones around in the jack, and sometimes hold them there. I guess I'm pushing it to the side of the jack or something, forcing a better connection. It's really annoying. Anything (short of taking the iPod apart) I can do?
Unsoder and resoder the connections to the headphone Jack. Be sure you know how to soder well because this will cancel your warrenty.
Posted on Jan 15, 2009
My phones' audio jack won't play music from the right ear bud
Have you use another headphones insteading of your Sony headphones to have a try? Make sure it is not the problem of headphone, then you may need a headphone jack replacement to replace the old one.
I've also met this situation with my phone. Finally I found the right
Headphone Earphone Audio Jack Flex Cable for Samsung Galaxy S4 i9500 to solve this problem. You can also look for one repair part for your phone, then find a video following to fix. It is easy to make it. Hope it can help.
Mar 07, 2014 | Bose QuietComfort 2 Consumer Headphones
The whole wire that connects the left ear bud along with the ear bud still on it just fell out of the part where the two wires come together. Is there any solution to this problem?
buy new headphones?. i think a lot better than trying to repair it. it sounds like you are talking about where both earbud wires come together at the molded connector part that splices the wires together. unless you are mechanically inclined and electrically astute, you should just replace the
Mar 25, 2012 | Bose in-ear headphones - Black with...
Left earbud won't play
Are you inserting the headphone jack all the way in? Failing to insert the jack for a few millimeters may cause one earbud not to play.
Mar 03, 2011 | RCA OPAL M4001 MP3 Player
I purchased this mp3 on 11th devmber. the music is not getting through to the headphones - can you help? is it powered by a battery & is one included as standard?
Hi mharrington9,
You may want to post the make and model of your mp3 player. Someone may have solved the same problem with the same player, and would then be able to give you a more specific answer than this one;
I assume you have replaced or re-charged the battery first, and that full power to your player did not help. If so, it is likely to be a problem with the headphones, the headphone receptacle, or the amplifier inside the mp3 player;
1) Headphone problem?
Get a different set of ear-bud headphones, and try them out. If the alternative set works but your headphones do not work, it's the headphones.
1a) Large headphones, small player?
If your headphones are large, but the power of your MP3 player is small, the player may not have enough power to drive the headphone speakers. If you run your MP3 player through an additional amplifier, you may then have enough power to get sound out of your headphones.
1b) Broken wire in ear bud jack?
Most of my broken ear-bud sets have failed because one or more of the wires has broken, usually at the plug-end. There are 3 thin wires; If you break the left-channel or right-channel wire, only one earbud goes out. If you break the ground wire, both earbuds stop working, or you may hear a very faint sound at full volume. If you like to solder things, it is possible to get a new plug, cut off the old one, and solder in a new one. But it may be easier to get a new set of earbuds.
2) Broken Receptacle?
Plug your ear-buds into a different, working MP3 player. If the ear-buds work, then
Plug your MP3 into a computer through the data cable, and try to play something through the computer.
If the MP3 works through the data cable, something is wrong with the receptacle for your ear-bud plug.
You may be able to get your MP3 player replaced under warranty, since the purchase was recent. Or, if no warranty and you feel adventurous, take the back off and try to re-solder or replace the receptacle-- Though this usually ends in irreparable damage to the MP3 player :-\
3) Broken MP3 player?
If you can't get any music to play through the data cable or the computer, something is seriously wrong with the guts of the MP3 player. Try for a warranty replacement if you can.
Best of luck, mharrington9
Dec 12, 2010 | Audio Players & Recorders
The left and right ear bud work some times. and if i turn the base were you plug it into the device it coukd work how can i fix it so they can both work at the same time.
Probably can't. What typically happens is that the base of the wire gets stressed from wrapping the cord around you media player and it eventually breaks the copper wire inside of the insulation. You likely can not even see the damage, let alone repair it. Be more carefull with the next set, and might I recommend a set of AKG ear buds. I use AKG studio headphones and bought my little sister some AKG ear buds, very impressive quality very close to my studio headphones. AKG K 313
Oct 29, 2010 | Skull Candy LINK Earbuds Consumer...
My skullcandy earphones are busted
could be caused by the way you wrap them up the cords should never be wound tightly it causes a short and it just so happens that earphones are made of light weight wiring to make them seem to disapear when wearing them so what to do is instead of winding them when your done simply fold them loosely so to speak
Feb 25, 2010 | Skull Candy Ink'd Stereo Ear Bud...
My earbuds the music goes in and out and half the time wont work work in one ear bud then the other and sometimes with
Have a look at the info at this site:http://www.metacafe.com/watch/1045725/how_to_solder_how_to_repair_headphones/
Jan 19, 2010 | Bose in-ear headphones - Black with...
Ipod (30 G) earbud jack only plays out of one ear
Does this still happen with a different pair of headphones? If not, get another pair. If the same behaviour with any headphones you will need to contact Apple if still in warranty to get it repaired.
My bet is with the headphones not the IPOD.
Good Luck
Mar 18, 2009 | Apple iPod MA446LL/A MP3 Player
My left earbuds on my JVC gummy earphones went out.
I have this problem all the time with my JVC earbuds. This may sound a little gross but it will work. I put the ear phone in my mouth and **** on the end of it pretty hard. What I have found is that sweat or even wax will plug the little hole and prevent the sound from coming out.
Nov 16, 2008 | JVC Gumy Ear Bud Headphone - Peppermint...
Only One Ear Bud Works
It is likely that your right stereo channel has either been severed somehow or there is a severe short in one of the cables. What you can try to do to test this theory is first turn on your music. Then wiggle the cable at the very base of the right earbud. If nothing happens wiggle the cord right where it connects to the stereo jack. If still nothing happens run your fingers along the right earbud audio cable bending and twisting it. If at any point you hear music again then you likely have a short. If it is near the earbud then it is going to be difficult to fix since these earbudfs have a large gauard. If the short is at the stereo jack then the fix is simple. A standard 1/8" stereo jack can be purchased from any electronics or audio store. You can then fairly easily seperate teh old stereo jack and solder this new one in place. Search the internet for tutorials on how to do this if need be. Even if you do not get any kind of sound when wiggling it at the base of the jack this is the most likely culprit since this is where most of the stress on the headphones occur. Be wary though, if you do attempt a stereo jack repair you will void whatever kind of warranty your earbuds may have so check before you try. But, in teh end you may end up saving a 60-100 dollar set of earbuds for 5-8 dollars. Hope this helped.
Oct 28, 2007 | Skull Candy LINK Earbuds Consumer...
121 people viewed this question
 Grubhead
Grubhead
