Question about Vector 995 Radar Detector
I have a beltronics vector 995 radar detector, it works as normal for some times as long as three days then other times like five minutes then it continuosly beeps and flashes reading 'service required'.where do i take it to to get looked at?or what do i do about it? thanks.
  • bdpayne2 Nov 18, 2008
    thanks for that but its actually a mate of mines and i borrowed it and its done this so i just want to get it fixed so i can give it back thanks.so how do i go about getting a reflash?
    Problem Solver:
  • 6 Answers
It needs a reflash.
If you want to sell it please tell me a price.
ssilvviu@yahoo.com
Posted on Nov 08, 2008
SOURCE:
Message indicates it needs service.
The radar detector goes through a quick diagnostic check at power up - not unlike a computer does at boot time. During this time, critical operational parameters are checked and should any be found out of spec, you receive a warning message - letting you know that all is NOT well. You can not expect to have the same level of warning or protection from this device while it is not operating as designed.
Your best best is to contact Beltronics Customer Support and review your options with a representative.
I hope this helped - good luck!
Nov 19, 2010 | Vector 995 Radar Detector
Need a Window Mounting Bracket
well if you modify it to make it work and sme thing happens to your radar detector it wont be covered by bell so i would call them and have them send out the right one
Jul 24, 2009 | Vector 995 Radar Detector
No sound on my vector 940
Beltronics is now using a special "high temperature" speaker which resolves issues with speakers blowing due to high ambient temperatures. Contact Beltronics and schedule service for your V940. Not only will Bel replace the speaker with the newer model, but they will also test and calibrate your V940 and install whatever the current firmware is for your V940.
Jun 22, 2009 | Vector 995 Radar Detector
Manual to vector xr950
My radar was constantly scaling from low to high volume on my vector xr950 but now it does not power up at all. Has anyone got suggestions.
May 17, 2009 | Vector 995 Radar Detector
Beeps and says service required
This message occurs if your V995 can't properly calibrate its internal circuitry for the antenna. As the message implies, you need to send in your V995 for factory service.
Jan 02, 2009 | Vector 995 Radar Detector
I have a beltronics 995 radar detector and i have a problem with it. The message "Service Required " appears.Please help . Thank you
This means that your RD has failed several attempts to self-calibrate its internal antenna. Like the message says, you must send in your V995 for service. Bel will fix whatever the issue is, and they will install the latest firmware too. Also, be sure to ask Bel to check and see if they need to replace the existing speaker with their new "high temp" speaker. The new speaker resolves potential issues of the original speaker failing due to high heat conditions.
Dec 03, 2008 | Vector 995 Radar Detector
Beltronics Vector 995 Radar Detector Problem
this means it needs to be sent in for repair. Heres bels num
1-800-341-2288.
Oct 17, 2007 | Vector 995 Radar Detector
Beltronics Vector 985
If its still under warrenty Call Beltronics 800-341-2288 I had the same problem and they re-tuned the Detector and updated the firmware my Vector 985 was out of warrenty by 5 months and Bel repaired it for free. Hope this helps
Jun 17, 2007 | Vector 985 Radar Detector
Vector 995 Radar Detector Logo
694 people viewed this question
Top Beltronics Vehicle Parts & Accessories Experts
Jerry Greenberg
Jerry Greenberg
Karl Kittsteiner
Gary Kennedy
Gary Kennedy
Level 1 Expert
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
