Question about Canon PIXMA MP530 All-In-One InkJet Printer
Canon PIXMA MP530 - ink cartridge carriage stuck at far right, won't move
I get an "Error 5010" on my monitor screen when I try to print a word document. At the same time, the printer screen says, "scanner error".
According to some information I found (possibly in the manual) this means the cover isn't shut.
The COPY and ALARM lights are flashing, and when I open the cover the ink cartridge carriage doesn't move to the middle where I can get at the cartridges to replace them. Instead, it remains stuck - very solidly - on the far right.
Any suggestions?!
5 Suggested Answers
geemarie
  • 876 Answers
SOURCE: Error 5100 for canon mp530
I would do all of the following and see if yo can clear this code. It is not on any Canon list of possible codes, so I have no idea what it means., but let's do this:
Turn off the printer and unplug it.
Remove the print cartridges. Look at them, are they leak free? Look into the cartridge holders. Are they clean?. Dried ink or blobs should be cleaned off with a little alcohol and a qtip.
Are the little wire holders bent or broken? Do they look exactly the same?
Turn the printer back on reinstall the cartridges.Check in your printer preferences/services and clean your cartridges.
Now turn it off again and unplug it. Open the paper jam door and gently push the paper roller forward until it clicks. At the same time, look for even the tiniest scrap of anything in there.
Close the paper jam door and plug your printer back in. Restart your computer.
If the problem is not solved. You may need to reinstall the printer. Do You have your original disc? Be sure to do a clean install. ( Turn off all running programs in the lower right corner including your virus control. Also go to Toolbar>tools>internet options>general>and delete all you cookies and temporary internet files.) Turn off and unplug your printer.
Reinstall the software. When it is finished if it has not told you to plug your print back in do so now. Restart your computer and turn your printer on.
I hope this helps. Good luck to you.
Posted on Aug 24, 2008
SOURCE: ERROR 5010
solucion a email stnilton@hotmail.com the error 5010
Posted on Mar 28, 2008
cene765
  • 787 Answers
SOURCE: mp530 u052
Try press and hold reset button for 5+ seconds.
Posted on Nov 24, 2009
SOURCE: Canon pixma mp145 service error 5010 How to
i have error code 5010 showing?
Posted on Jul 24, 2010
  • 118 Answers
SOURCE: I have a Canon PIXMA MP530 printer and showing an
disconnect it from power for 10 minutes and also check for jammed paper. That should do the trick
Rob
Ps. Thanks for ratings.
Posted on Mar 02, 2011
Carrage won't calibrate - more details
Hello! There are many types of error in Canon Printers like P07,P08, E15etc. So please notify the error or check it through your computer notification. After you see the error number (s) please send me a message. Let me try my best for you. Thanks
Jun 20, 2012 | Canon PIXMA iP4700 InkJet Photo Printer
Hello, I got an error message 5C10. What does that
I just had this error message appear on my computer screen and the 6A00 on my MP830 printer at the same time. I heard this error mean a few things (paper jam, ink carriage stuck), though not sure what it does actually mean. I moved the carriage back-and-forth, blasted compressed air and checked for paper jams. When nothing worked, I looked inside and saw a lot of spilled ink, I'm guessing from not using genuine Canon ink. I blotted the inside with paper towels (use gloves!!),especially the far right, and took out the ink cartridges and blotted the carriage. I replaced everything, powered the printer off and on, and it worked fine. I would suggest first to slide the carriage back-and-forth and look for paper jams before cleaning the ink. Hope this works for you.
May 25, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Error code 6A00
Step by Step troubleshooting canon pixma MP800 error code 6A00
The Problem Canon PIXMA MP800 Error 6A00
1. The print head cartridge keeps locking itself up on the right hand side.
2. Frequent 5100 errors even when the printer is on standby
3. Even when I wipe up the print cartridge, the next print will
mess up the bottom of the print cartridge with ink again.
Step for troubleshooting canon pixma MP800
1. Opening the cover and wait for ink carriage to center
2. Pull out power cord
3. Pushed carriage to far left (should slide easily)
4. Used paper towel and wiped purge unit a lot of times
(press down to soak paper towel with ink). Repeat until the paper towel is relatively clear.
5. Used diluted napisan (oxygen-based cleaning agent in the
ratio of 1:3 with powder:water) and soaked paper towel
6. Repeat step 4 with wet paper towel. Repeat until purge unit is near-white.
7. Pulled and pushed clear plastic wiper (north of purge unit) and wiped it down
8. Slided carriage back to original position
9. Removed Print head cartridge and wiped out excess ink stuck on bottom.
Mar 01, 2011 | Canon PIXMA MP800R All-In-One InkJet...
Error code 6A00
Hope this helps.
Feb 10, 2011 | Canon Pixma MP800 All-In-One InkJet...
Error code 5010
Error code 5010 indicates carriage lift mechanism error. That means that the carriage did not move up or down properly. You need to replace PR lift shaft ***'y (QL2-0936), Sheet feed unit (QM2-2916), Logic board ***'y (QM2-3078), Carriage lift sensor unit (QM2-3092). In brakets you have the part number for each one of them. Before replacement of the logic board ***'y, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or more, also replace the ink absorber kit (QY5-0146) when replacing the logic board ***'y.
Feb 01, 2011 | Canon Pixma MP500 All-In-One InkJet...
Error code 6A00 shut down machine. How do you fix it?
Oct 26, 2010 | Canon PIXMA MP830 All-In-One InkJet...
MP530 KEEPS GIVING US A C510 ERROR OR A 6A00 PROBLEM HOW DO WE SLOVE THIS.
6A00 means the purge assembly on the right where the printhead parks is jammed or stuck. You can look to the right if the carriage is not stuck on the right, see if there is paper or something caught in there. After that it will need a new purge assembly, around $40.00
Nov 02, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MP530 Error Code 5100
OK. It sounds like there's something on the carriage bar restricting the movement of the ink carrier. Perhaps some ink got on the bar.
Try taking a clean lintfree rag dampened with rubbing alcohol and clean the bar. This may have to be repeated a number of times to get the foreign matter off the bar and the ink carriage.
Let me know if this helps. iF it does not we can try something else.
Thanks.
May 05, 2009 | Canon PIXMA MP530 All-In-One InkJet...
MP530 alarm and 6A00 error
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Dec 11, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon pixma mp530 problem error code 5100
i had the same problem. aall i did was open the printer up and moved the thing that holds the cartridges to the middle by hand. mine seems to be working fine. post again if its still not working.
Nov 12, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
564 people viewed this question
old marine
old marine
