Question about Facebook Social Network
Can't log on
Type in username, won't accept password, change password and then says user name is not correct.
  • Anonymous Mar 22, 2014
    Since iPad upgraded I can't log on to my rci account just keeps saying user name password incorrect but works on any other device
  • 3 Answers
I cant logt in on fascebook
Posted on Oct 06, 2008
Why Does User Authentication Fail When the User Logs In to the Switch from the Web System?
The possible causes are as follows:
The user name or password is incorrect.
Run the display local-user command to check whether the user exists.
Run the display local-user username user-name command to check whether the user password is correct.
There is no HTTP user access type.
Run the display local-user username user-name command to check whether the AuthMask field of the user contains H (HTTP login).
The user connected to the switch is full. The switch supports a maximum of five users.
LS S6720S 26Q EI 24S
Nov 08, 2016 | Computers & Internet
Cant log in
If you have forgotten your password, if you have another user account with administrative privileges you can log into that account and change your original user account's password from the User Accounts applet in Control Panel. ... At the Welcome Screen, do Ctrl-Alt-Del twice to get the classic Windows logon box.
Nov 06, 2017 | Computers & Internet
Why won't my oovoo log in :'(
Ensure that you have the correct user name and password. If you forget your username have oovoo send your the credentials using the "the forgot password". If that does not work not create a new account and just add your friends and family on the new account.
May 29, 2013 | ooVoo
My username is 4 numbers. It won't let me log in saying I don't have enough characters. How can I log in or change my username so I can log in?
go into the log in page - hit "forgot user ID" - they will email you a new one or email you a link to pick a new one - use at least 8 characters. Then go back to log in enter & enter your new user name. Try your old password - if that doesn't work, hit "forgot password" & they'll let you reset.
Apr 06, 2013 | mywalmart.com
How do I remove log in username
for which operating system ????
Windows XP users
Change password
  1. Open Control Panel
  2. Double-click the Users Accounts icon
  3. Select the account you wish to change.
  4. Select the option "Change my name" to change your username or "Create a password" or "Change my password" to change your password.
Note: Windows XP Home users can only change the Administrator password through Safe Mode
Windows Vista and 7 users
Change password
  2. Click Add or remove user accounts.
  3. Click the account you wish to change.
  4. Click Change the password
Change username
  4. Click Change the account name
Windows 2000 users
Change password
Microsoft Windows 2000 users can change their username by pressing CTRL + ALT + DEL while in Windows to open the Windows Security window. From this window click the "Change Password" button
Enter your old password and the new password you wish to use.
Change username
In order to change the username of an account on Windows XP you will need to have an account with Administrator rights. If you're logged in as Administrator or have an account with Administrator rights, follow the below steps.
  2. Double-click the Users and Password icon
  3. Make sure "Users must enter a user and password to use this computer" is checked.
  4. Highlight the account you wish to change the username for and click the Properties button.
  5. Within the Properties you'll be able to change the User name.
hope this helps
Sep 25, 2011 | Computers & Internet
User name and password were not accepted
It seems that you have lost your username or password.Please try type username and password correctly as both are case sensitive.If this not work for you fallow the fallowing procedure:
1.Start your pc in command prompt mode for that you should press F5 as soon black screen disappears.
2.In command prompt mode type as shown in fallowing manner:
C:\net user
It will display all the users on your computer.
3.If you want change your password then type as fallows:
C:\net user (desired user name) (new password) (new password)
4.Then reboot your system.You will be able to login with your new password now1
Sep 19, 2011 | Computers & Internet
I bought a MSI Wind 12 off display, and I assume there was a username and password already on it. How do I reset it, or clear that, so I can create my own username and password?
When you boot up to the log in screen type in administrator to log in once you have your computer running again you have to take control (administrator)control panel user accounts on the users tab,click the name of the computer administrator you can change the password there or if your computer has a system restore you can restore it to an earlier date which will have your personal settings
hope this helps
Dec 28, 2010 | Intel Motherboard
Want to change user name and pass word
You can do so by opening the GUI page of the router:
First connect it to the computer through a Ethernet wire and then check the default gateway (go to command prompt and type ipconfig)
put in the default gateway address in the internet explorer address bar
Log in to GUI..the default username and password is following
Username: admin
Password: admin
or
Username: admin
Password: password
Log in and change the username and pasword...you would also be able to change the wireless password (WEP key) from same
Sep 25, 2010 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
Trying to set up ethernet/wired router , linksys WRT54GS setup accepts correct username but not password ,ISP is a verizon DSL using a westall 6100 . DSL set to bridge , user name and PW are correct , have...
you can try resetting the linksys router once by pressing and holding the reset button using a toothpick for 30seconds when the power is turned on...then open the linksys router setup page by typing 192.168.1.1 in internet explorer...go ahead and change the connection type as "dynamic"(if you donot use any username,password for going online) or change the connection type as "pppoe" and enter the username and password over there in the fields provided...it ll fix your problem for sure....
Apr 03, 2010 | Computers & Internet
Facebook Social Network Logo
Top Facebook Computers & Internet Experts
David Payne
David Payne
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
