Question about Logitech Inc MM50 Portable Speakers iPod Computer Speakers
Will not charge
When i plug the ipod cord into the wall it doesn't charge . no lights light up.
  • pdonohue33 Apr 03, 2009
    mm50 seems to be dead. have not used in a long time. AC power adapter seems to work because when put ipod in cradle screen lights up, recognizing connection to power; I think maybe internal battery is dead? Any ideas? If I understand #1 "solution" posted it sounds like charge it for 12 hrs?
If this Problem has come because you not use a speaker for a long time.I Know How to Repair. In This Morning. I had a Problem Like you but I Can Repair it. Try it you Self.I use a Plug and Play a lot of time. lot of charged. and a lot of on-off switch mm50. I do this for a 12 hour. in my school holiday. Battery is become life! . I Can Portable with It Again. but now is mid night
PS.This is true , I test with myself to Resurrection that Death Battery
Posted on Oct 04, 2008
I've just had the same problem today and found out that the connector that you insert the mains jack into (at the back) is glued onto the mother board with very light soldering joints and glue. that had come loose so there was no connection between the mains and the battery charger, which meant the battery (and in turn the iPod) wasn't charging. I need to re-solder the joints as it works when you take the back off and press the connector hard on to the mother Printed Circuit Board.
Posted on Mar 18, 2010
  • William mcphail
    William mcphail Feb 12, 2015
    I had same part soldered today thinking that this was the problem also put new input socket in but won't charge ,my i pad charges ok with white charger buy I need it to work in io dock to play backing tracks thro pa system
    New Friend:
  • 35 Answers
I would try a new power supply first. If that does not work then you need to buy a new battery. The power supply is pretty easy to locate but the battery (NTA2335) is VERY hard to find but here is a site that carries it: Replacement NTA2335 Battery for Logitech MM50 iPod Speaker
I hope this helps!
Posted on Jul 23, 2013
Which do you charge it with, the black power adapter or the white one that looks like it plugs into a computer?
Posted on Jun 14, 2010
  • William mcphail
    With black one and have had it checked it out and is ok , have also checked out input at back of doc and resold erred this , could it be connection when I slide I pad into dock?
When i plug my ipod touch into a wall socket it will not charge
if the charger cord wont work into a usb port then it could just be you're cord or it could be the wall charging port if its not either then it could be something internal.
Oct 08, 2014 | Apple iPod touch
Tip
How to convert a USB Battery Charge Cable to AC
<p>Many of the new battery-operated devices such as phones and MP3 players come with USB cables to charge the battery while the computer. However, wall chargers for these items are missing, damaged or undelivered. If so, you can use a USB wall charger, USB cables, adapters and because all have the same size at the end with these boots are endless. <br /> <p><br /> <p>Generic Battery <br /> <p>1. Buy a USB wall charger. These are available online through www.amazon.com and www.bixnet.com or a limited number of electronics stores like Radio Shack or Best Buy. <br /> <p><br /> <p>2. Connect the USB end of cable to the USB wall charger. <br /> <p><br /> <p>3. Connect the charger to the USB cable. Then connect it to the wall. The machine starts working the green light. <br /> <p><br /> <p>iPod Battery <br /> <p>1. Connect the USB cable to the iPod. Be sure to press the two ends before inserting it into the iPod. If you do not, you can damage the pins, once that happens, you will not be able to charge your iPod. <br /> <p><br /> <p>2. Mount the USB wall charger sliding the top in half, for the manual. <br /> <p><br /> <p>3. Connect the USB cable for both USB wall charger. Plug the wall charger. The costs start when the lights come back on the iPod screen and you will see the battery icon fill. You can find this anywhere iPod charger are supplied. <br />
on Aug 09, 2011 | Apple iPod touch
I have an ipod model a1199. i was wondering if you can use a newer ipod touch charger for it? and if not what kind of charger does it use?
Charge an iPod Nano Without a Charger
If you've misplaced or broken the charger that came with your iPod Nano, you might think you need to purchase a new one in order to continue using your Mp3 player.
However, there is a way that you can continue enjoying your iPod without having to purchase a new charger.
As long as you have a USB cord and a computer, you can charge your iPod without having the charger.
Locate the USB cord that came with your iPod Nano package.
It is the same cord that you use in order to sync or transfer music.
Plug the small end into your iPod Nano.
Plug the other, larger end into your computer's USB port.
Choose "Do Nothing" when your computer presents the dialogue box to let you choose what to do with the hardware or USB connection.
Leave your Nano plugged into your computer for at least 4 hours to charge.
Unplug your iPod Nano when charging is complete.
Charge an iPod Without the Charger
Many iPod owners purchase a charging unit that plugs into a standard wall outlet to recharge the iPod's battery.
However, the iPod wall charger is not included with new purchases, so consumers must either purchase a separate charger or find a way to charge their iPod using other means.
Here's a simple method to charge your iPod using your computer.
Plug the iPod USB cable into the bottom of your iPod.
Plug the other end of the iPod USB cable into a free USB port on your Mac or PC computer.
Open the iTunes program by clicking on the icon in the Dock on a Mac or using the Start menu on a PC.
Click on the name of your iPod under the "Devices" heading in the main iTunes window.
Click on the "Sync" button to synchronize your iPod with your computer data.
While the iPod is syncing, the power from the USB port on your computer will charge your iPod's battery.
Unplug your iPod from the computer once the battery is fully charged.
http://www.bing.com/images/search?q=images+of+apple+ipod+usb+chargers+&qpvt=images+of+apple+ipod+usb+chargers+&FORM=IGRE - view=detail&id=8DEA58C0DAF392E29FCB03D9C
This one should be ok.
Aug 05, 2013 | Apple A1199 ipod nano
When i try to charge my i pod touch i just bought from some kid it doesnt show me its charging the cord seems fine what would be causing it not to charge but when i just plug the usb part of the cord...
If there is another USB cord around try using that. The problem might be with the cord.
If the iPod is still not charging, the problem might be a dying battery. If that is the issue, try to see if the iPod is less than a year old. Register the iPod and then go to the Apple Store. They might be able to replace it for you for free.
If not, you can go to the Apple Store to get it fixed for a fee
or
Bring it to the Apple Store and buy a new iPod for 10% off.
Jan 27, 2011 | Apple iPod touch
My ihome won't work. The ipod is playing, but there is no sound coming out of the ihome nor is the radio working.
Make sure you have power to the unit. Do you see indicator lights that show the unit is working. Speaker switch on?
Aug 31, 2010 | Audio Players & Recorders
How do I charge my ipod? Just got it from my
Connect it to your computer via the USB cord. You can also get adapters which will allow you to charge it using a wall socket (AC power). The adapter plugs into the wall, and then you plug the Nano's USB cord into the adapter.
Jan 29, 2010 | Apple iPod nano
Ipod doesnt work
I think I know just the problem. The connection cord that came with the wall outlet charger can only be used for charging. You have to have the original apple cord in order for the computer to recognize it.
I had the same problem.
Sep 20, 2009 | Apple iPod touch
Apple ipod not getting charged
What type of IPod is this? Also what type of charger are you using? If the ipod does not have a charge at all you will need to plug it into a wall charger for it to get a "Base charge" (this usually takes 5-10 minutes) as if the ipod is totally dead then there is not enough of a charge for the ipod to let your computer know it is there to start being charged. After it has the base charge you can use the usb connection to finish the charge or leave it plugged into the wall charger to finish getting the charge.
May 08, 2008 | Apple iPod MA446LL/A MP3 Player
I purchased one of these and I don't have access to a computer all the time is there any way to charge it without the usb cord?
you can purchase a generic ipod wall charger and then you can plug the usb into the player and into the wall charger to charge the unit. You obviously have to have the usb cord but not the computer. Wal-mart has the generic wall plug pretty cheap.
Apr 26, 2008 | Audio Players & Recorders
When i plug my ipod into the wall or computer, it doesnt recharge the battery.
have yu tried any other cable? your maby starting to get very bad:p ...try any friends cable or buy a new...
Jan 29, 2008 | Apple iPod MA446LL/A MP3 Player
723 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
