Check that the timer is set correctly as often owners don't set them right; I'm guessing you changed the element without turning off the breaker. If this is an oven with a digital display, turn the breaker off and back on, this might reset the board.
Hope this helps; also keep in mind that your
feedback is important and I`ll appreciate your time and consideration if
you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Hi
F9 is a door lock error and to solve this issue you can hold
the light switch for 15 seconds, this will reset the control. If it won't work
then hold the light switch in and set the unit to clean and after a minute
press cancel to cancel the clean cycle. If still it won't work then the door
lock assembly should be replaced. Hope this helps...please post
back for further assistance.
Daniel
Also none of the buttons will work ?
