Question about HP Compaq Presario V5000Z Notebook
COmpaq Presario V5000 Battery will not hold charge
The charging indicator shows the battery charging, however when the laptop is unplugged fron the AC, the computer dies. I purchased a brand new battery with the same results. I checked the power settings, AC adapter, even tried calibrating the battery all with no luck. Any info would certainly be appreciated
    Genius:
  • 1,124 Answers
Problem with the motherboard connector that charge the battery.
Posted on Oct 03, 2008
  • Pablo Csaky
    Pablo Csaky Oct 03, 2008
    This issue can be caused by any of the below possibilities.
    1. Computer AC / DC cable is bad not allowing the computer battery to charge.
    2. Battery is bad.
    3. Battery charger board is bad.
Compaq Presario V5000 does not come on
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
http://www.chargerbuy.com/replacement-compaq-presario-v5000-ac-adapter-65w-18-5v-3-5a.html
Nov 20, 2012 | Compaq Computers & Internet
Compaq presario cq61 showing battery problem concider changing your battery how can i solve it i am using windows 7
Charge your battery, it's empty. If you get this message even after you have charged it then the battery has aged and it can no longer hold its charge so you must replace it.
Apr 11, 2011 | Compaq Presario CQ61-310US Laptop
Battery will not charge compaq presario v5000
I would try replacing your ac/adaptor (power plug) before troubleshooting any further. It sounds as if the adaptor is faulty. Check eBay, you can get a replacement for less than 10 dollars.
Sep 20, 2009 | Computers & Internet
Laptop battery wont charge?
It could be the battery needs replacing ... it shows that the battery is charging but it doesn't keep the charge .....
May 23, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq presario v6000 laptop plugged in but not chargin
YOU NEED TO RECALIBRATE YOUR BATTERY. FIRST UNPLUG THE POWER CORD AND LET YOUR BATTERY RUN ALL THE WAY DOWN TO 5%. THEN PLUG YOUR POWER CORD BACK UP AND LET IT RE-CHARGE THE COMPUTER. SOMETIMES WHEN YOU FREQUENTLY UNPLUG YOUR AC ADAPTER YOUR BATTERY FORGETS HOW MUCH POWER IS ACTUALLY AVAILABLE IN CONJUNCTION TO WHAT THE BATTERY METER IS SHOWING. RECALIBRATING THE BATTERY WILL RE-SET THE METER WITH THE BATTERY.
Apr 06, 2009 | Compaq Presario Notebook
Laptop isn't working
have the charger tested, the original battery may have been flat, because of charger failure rather than battery failure. try an automotive connector if one is available
2c worth
Jul 11, 2008 | HP Compaq Presario V5000Z Notebook
V5000 problems
what you need 2 do is either take the whole laptop back 2 where you brought it or even the battery cause you have a faulty battery.
most laptop batterys last for at least 5-10 years and after that no matter how much you charge them up they alwayz seem to be flat.
so my suggestion is get a new battery or take it back to the place that you brought it from and than get it replaced for free as long as you have your recept.
Jul 06, 2008 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V5000 PC - Shuts doen while plugged into AC adapter.
eather you have one or a couple of the following problems,
1. you have a bad battery
2. the power supply is defective
3. the charging circuit in the laptop is defective and the motherboard will require replacement or repaired.
Dennis
Jun 19, 2008 | HP Compaq Presario V5000Z Notebook
Compaq V5000 Laptop wont recongnise / charge battery anymore
yes may be bcoz u already replace 2 battery but the problem is same may be the charging ic problem (in mother board) or the battery quality is not good try with the original battery and see. if still u facing the same problem then show it to repairing center and get it done.
Jun 11, 2008 | HP Compaq Presario V5000Z Notebook
HP Compaq Presario V5000Z Notebook Logo
361 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
