Question about Memorex MVD2042 DVD Player
DVE not loadong
Rarely, I find that a DVD will not load when inserted correctly. The screen
displays "no disc". Sometimes cleaning the disc with a fine cloth against
the grain works to make it load.
Thanks, Malc
  • 86 Answers
Try cleaning your lens on the dvd player
Posted on Oct 14, 2008
Is there an easy fix when the dvd keeps spinning and screen says loading but does not play?
You have to clean the dirt off the laser lens inside as it cant see the codes on the disc.Use a cleaning disc first or it will have to come apart to clean.
Dec 06, 2013 | RCA 9" Lcd Portable Widescreen Dvd Player...
My DVD is playing my videos in black and white .. It's a Panasonic tv model is tc-L32c5
follow the steps. God bless you
Insert a DVD lens-cleaning disc into your player and press "Play" to clean the DVD laser, eliminating picture problems due to read errors. Do not use a CD cleaning disc as the brushes on these discs can damage your laser.
  • 2 Wipe your DVDs clean of all visible marks and dirt using a lint-free cleaning cloth moistened with rubbing alcohol or glass cleaner. This further fixes read errors which can damage the quality of picture and sound.
  • 3 Disconnect your DVD player from the TV or receiver you have it connected to. Reconnect the DVD player directly to the "AV" or "Video In" port of your television, firmly pushing the plug into place, to eliminate possible noise from the receiver and ensure a clean connection.
  • 4 Connect your DVD player using an S-Video, component video or HDMI cable. Standard yellow/red/white RCA connectors cannot carry the high-quality signal that DVD discs are capable of transmitting, and will display a particularly poor picture on flat-screen high definition televisions. Use an HDMI cable, if your television and player support it, or a red/blue/green component video cable.
  • 5 Press "Setup" on your DVD remote and enter "Picture Settings." Make sure your DVD player is set to display images in the correct screen format ("Widescreen" or "16 x 9" for HDTV sets, "Standard" or "4 x 3" for older square sets) and scan mode. If you are using a DVD player that supports "Progressive Scan" on an HDTV or flat-screen set, activate this setting; for older sets, choose "Interlace" if given a choice.
  • Nov 14, 2012 | Televison & Video
    Bluray BD-6900 turns and is stuck on Load. No menu, nothing on screen, just the word LOAD displayed
    Hello
    Its laser pickup unit should be suspected. Just insert a lens cleaning disc and try to clean it. If it do not help you, the set need service
    Mar 04, 2012 | Samsung BD-C6900 Blu-ray 3D Player
    Can't Read Disc
    You could try updating the firmware.
    Jul 06, 2010 | Philips DVP5990 DVD Player
    Hi -- my toshiba SD3990 model DVD player won't
    Your DVD player is fu.k.d up.  These things are made so cheap now a days that it is more trouble to try to fix the thing, than going out and buying a new one.  You can try running a disc head cleaning kit through it first to see if that helps.
    Nov 23, 2009 | Televison & Video
    After inserting a disc the dvd goes into the machine, the menue box on the tv screen changes to loading, stays on loading for a short time then pushes the dvd back out. The machine never changes to play.
    the dvd player is unable to read the disc. either the disc is scratched and cannot be read or the player needs cleaning. cleaning discs are available pretty much anywhere. sometimes simply blowing into the area when the tray is open can temporarily fix the problem.
    Nov 17, 2009 | Mintek DTV-263 26 in. LCD Television
    Cyberhome dvd 1600
    unplug the unit and wait 5 minutes and plug it back in. See if that helps
    Oct 21, 2008 | Cyberhome DVR 1600 DVD Recorder
    No Disc keeps popping up
    yes , the eye is not reading correctly, if it is still under warranty i'd have the factory replace it, if not , any tv repair place can help u out, hope this helps jason
    Dec 28, 2007 | Sampo DVE-620 DVD Player
    Sampo
    POWER ON
    OPEN/CLOSE
    Key in 3,3,0,8,8,0 on the remote for region-free
    OPEN/CLOSE
    POWER OFF
    Oct 02, 2007 | Sampo DVE-612 DVD Player
    Memorex MVD2042 DVD Player Logo
    Top Memorex Televison & Video Experts
     Grubhead
    Grubhead
    Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
