Panasonic VIERA TX-26LMD70 26 in. LCD TV Logo
nina izard Posted on Dec 20, 2011
Input for second hdmi cable
There is a socket for the second hdmi cable, but when I go to input there is not an option
I have connected my laptop to my element tv via vga cord;sound is comin frm laptop..want the sound frm TV; THEN, I have a headset/microphone ... can I connect my headset/microphone to the TV?
If you need to get sound from your TV, you should have a sound input socket in your TV. If you have that you can connect an audio cable from your sound sound socket to your TV.
The second option is that your laptop and your TV should have HDMI ports. If its there, you can use an HDMI cable(instead of VGA cable)to connect the two. With HDMI cable, you will get both video and audio through that single cable.
If you need more help please let me know
2answers
I need help setting hooking up my DVD player to my hisense tv
There are 3 options for connecting a DVD player to a television. HDMI, Component or VGA. The most common, and best, these days is HDMI which requires 1 cable, called a HDMI cable, between the player and television. These input / output sockets are clearly marked & there is usually about 3 of them on most televisions. HDMI 1, HDMI 2, HDMI 3. The next is component. These consist of 4 separate connections. RED, GREEN, BLUE & YELLOW. Again simply connect like to like. The third (VGA) are RED, WHITE & YELLOW. Same deal, simply connect like to like on player and set. Once one of the connections are made select SOURCE on the television remote and select the connection that you have made. Cheers
How do i get the hdmi working
HDMI start by putting one end of the HDMI cable in the HDMI socket on the tv, then the other end in the HDMI socket on the device your are going to use. It can be a decoder, an apple tv or something else that needs an HDMI connection to the tv to work.
Secondly find the remote control and push the input button then there should be a picture on the screen with different possibilities for input. Click where it says HDMI.
You should be connected now,
kolbrub
My cello tv has an hdmi port but no option on the source menu
have you put any thing in the HDMI socket usually needs something to be there to open up the setting on the menu. if you have some thing in the HDMI socket and its still not there it maybe a faulty cable or faulty input device. of HDMI on tv has gone and needs replacing. but should come up when somthing is using the socket.
2answers
HOW DO I CONNECT A AN EZPRO 610 PROJECTOR TO A LAPTOP COMPUTER.
1. You will need a VGA or S-video cable and a 1/4 inch stereo plug that will go from the earphone jack to the EZpro then out to a amplified system for the sound.
2. I believe the EZpro has connections for HDMI which will supply sound as well as High definition video. You should have an adapter for the HDMI also if you
3. connections port as follows:
1. USB Connector (Connect to PC for Remote Mouse function)
2. RS-232 Connector
3. Audio Input Connector
4. S-Video Input Connector
5. DVI-I Input Connector
(PC Digital (HDCP)/PC Analog/Component Video Input)
6. VGA In/SCART Connector (PC Analog Signal/Component
Video Input, HDTV/SCART Input)
7. VGA Output Connector (Monitor Loop-through Output)
8. Power Socket
9. KensingtonTM Lock Port
Looking at the usb port go counter clockwise the numbers are in succession. 1- 9
1 Power Cord
2 VGA Cable
3 DVI-I to VGA Cable (Optional accessories)
4 Audio Input Cable (Optional accessories)
5 RS232 Cable (Optional accessories)
6 USB Cable (Optional accessories
I can't get signal when I hook up my hdmi cable. What am I doning wrong
Are you switching the TV's input to the HDMI socket..? and the output of the device you are trying to connect to the same HDMI socket..? Look in the TV's menu system and cycle through the available inputs with the HDMI cable connected ( some systems will only allow the HDMI socket to become active when something is actually plugged into it). Do this on both devices with the cable connected. Check the cable by plugging it into another, working HDMI link, maybe to a different TV in your house, if it works then it aint the cable..
3helpful
2answers
Connecting to HD TV
This TV has no HDMI input socket. It Has a DVI input socket. Therefore you will require an HDMI to DVI converter adapter or an HDMI to DVI cable. The DVI is video only so you will require audio cables from your Sky box (Audio L and R ) which will connect to the back left of your TV (Audio L/R sockets next to the s-video and component video connectors)
1helpful
Connecting Bravia to PC using HDMI cable
You did okay but the phono sockets are not for Computer/TV use. Phono sockets should be checked int the manual on why they're there. If you have connected the Bravia to your computer, using the appropriate cable, then you should also purchase or request from the retailer where you purchased the TV a cable that has stereo phono plugs and, you didn't say what size phono sockets they are but I presume they are 3.5 mm. So, if the TV has 3.5 mm sockets, you purchase a cable with stereo 3.5 mm plugs. This is adequate for the stereo wav sound coming from the computer and going into the TV. Remember, having 2 Phono inputs on the TV doesn't mean anything. The TV could have a number of video inputs too, ATD AVT, AV, COMPONENT1, COMPONENT2, HDMI1, HDMI2, HDMI3, etc. each have it's respective sound inputs for AV, S-VIDEO, DVD, Blue-Ray, etc. But for the computer there may be a different type of socket for it's sound inputs, normally it is the old phono sockets. Seek help from the retailer or else you could cook the circuitry of the TV's sound system.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
