Question about Amana Heating & Cooling
Amana GUIC070A30 furnace won't run. Air conditioning functions but no heat. Reset thermostat, set to heat & bumped up temp to 90F. Thermostat clicks & nothing happens after that. I have covers off unit & with therm set as stated I get a flash (not continuous or pulsed) on the ICM diag LED & I can hear the trans hum. I did the full startup procedure from the manual. Has 115VAC & 24VAC trans working. ICM 3A fuse good. Any suggestions?
  • rlipp Oct 04, 2008
    you da man!
  • 182 Answers
Jump a wire between r and w on the board.if it fires its in your tstat\wire
Posted on Oct 04, 2008
I have a coleman furnace model 4066A656
Make sure your air filter is clean. Is the thermostat satisfied? or is the room temp. still below the thermostat setting? When ever you have to turn the power off and then back on to a furnace that usually indicates that the furnaces ignition control locked out. The first thing that I would try is cleaning the flame rod.
Mar 02, 2017 | Coleman Heating & Cooling
Model sf35f furnace wont quit heating after reaching thermostat setting
Sounds like the heat anticipator in your thermostat is either bad or out of adjustment. Turn of the furnace power. Remove the thermostat wires from the thermostat. Turn the power back on. Connect the white and red wires together. The furnace should start up. Let it run a couple of minutes. Then disconnect the wires. The burners should shut off immediately. The blower will continue to run for 60 to 360 seconds then shut off. If this happens replace your thermostat. If the burners continue to burn, then your problem is either the furnace or the thermostat wires.
Sep 12, 2014 | Heating & Cooling
What happen when your hvac blows cold air and the heat is set at 73
Sounds like you have a thermostat problem. If your thermostat is not triggering the furnace to ON/HEAT you will not the heat you desire. IF you know how to trigger the furnace you could jump your furnace controller wires BUT DON'T do this. Instead, get another thermostat and try it. But be sure to get the same rated thermostat... take it with you when looking for a replacement.
Not sure about everything going on with your unit based upon what you provided but your thermostat should show the current temp and the temp you set. It also show the mode that the thermostat is in (HEAT / COOL / AUTO) Manually select heat, then increase temp above the current temp setting. listen for furnace to activate or wait a few minutes for warm air output. If not, you'll have to see assistance trom a local heating and cooling company.
Mar 09, 2011 | Goodman Heating & Cooling
I just purchased a house with brand new furnace wired to a RTH2300 Honeywell thermostat. It only has two wires running to it. I can't seem to get it to work in "manual mode"-where I set it on...
?? Connect Wires 5.
Labels don't match?
If a wire does not match any terminal on the thermostat,
see next page.
Quick Installation Guide
Alternate Wiring
If a labeled wire does not match any terminal
designation, see diagram below.
Do not use C, C1 or X wire. Do not use B wire if you already
have O wire. Wrap bare end of wire with electrical tape.
This thermostat cannot be used if your old thermostat had
any two of the following wires: R, RC, RH, 4 and V.
Place a jumper (piece of wire) between Y and W if you have
a heat pump without auxiliary/back-up heat.
?? Connect Wires (cont'd)
Programmable Thermostat RTH2300
Set jumper JP1, on the back of the thermostat, if you
have connected a wire to the G terminal.
Incorrect jumper setting: An incorrect setting is
noticeable in a gas or oil heating system. When heating
starts, you will initially feel cold air coming out of the vents
as the fan is running before the furnace has enough time
to heat up the air.
?? Set Heating Fan Control 6.
HG Leave the jumper in this factory-set
position if you have a gas or oil furnace.
HE Place the jumper to this position if you
have an electric furnace.
Set jumper JP2, on the back of the thermostat, if you
have a heat pump.
Incorrect jumper setting: The heat pump operation
will be reversed, i.e., it will cool in Heat mode and will
heat in Cool mode.
?? Set Heat Pump Reversing Valve 7.
O Leave the jumper in this factory-set
position if you have connected O wire to
the O/B terminal.
B Place the jumper to this position if you
have connected B wire to the O/B terminal.
1) Install 2 AAA
batteries on the
back of the
2) Align the two
brackets on the
top of the
thermostat with
the corresponding
slots on the top of
the wallplate.
3) Push the
against the
4) Tighten the screw
at the bottom of
the thermostat.
5) Turn power back
on at the heating/
cooling system.
Nov 27, 2010 | Honeywell Programmable Thermostat Heater
I can't get my furnace fan to stop running-even in the off position
Your thermostat has AUTO and MANUAL for fan Make sure it is set for AUTO. If it is set for AUTO and the heat is off and cooled down AND the fan still runs then that will be a bad relay. If yours is newer then the board will need to be replaced. If yours is an older model you may need to replace the fan and limit switch8fe474e.jpgThis mechanical switch works on rise in plenum temp. It turns on the fan a around 110 f and it shuts down the fan at 90f. Newer furnaces use timers and relay on the IC board.
Oct 26, 2010 | Heating & Cooling
Amana PGD60C1152E no heat
Your thermostat Function 0170 must be set to "1" for Single Stage Heat/Cool. Function 0180 must be set for "0" for Heating Fan Control. Function 0240 must be set for "5" for the Heating Cycle Rate for your <90% Gas Furnace. If you have already done these steps or if, after doing these steps, you continue to experience a problem, you problem could be with your Gas Furnace. I'm including some links for information on your system and thermostat that include wiring diagrams.
Mar 06, 2010 | Amana Haier AP125HD Air Conditioner
Furnace runs on heat, air conditioner does not
If you have a Gas furnace in the Attic then the answer is yes. The outside condenser will not run if in fact you have a gas furnace.
Feb 11, 2009 | Ruud Central System Air Conditioner
Furnace wont start when thermostat sends signal
by restart button you mean reset i believe,its located on top of oil burner and says only push one time .if thats the button your pushing it is the reset button or retry for oil burner if you are pushing this there is a problem with burner
Jan 04, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
152 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
