Question about HP Compaq Presario V2000 Notebook
PXE-E61: Media Test Failure, check cable.
Having problems booting my laptop. Everything seemed to work fine and I haven't experienced any problems with it prior to this. I've had my laptop for approximately two years. Now when I turn it on it gives me a message PXE-E61: Media Test Failure, check cable. I checked BIOS and it said No IDE detected. Does this mean that the hard drive has failed or is there some way to access the drive to back up data.
  • 2 more comments
  • Rickhelp Oct 04, 2008
    Thanks for the help, Kevin. I really appreciate it. Now to the task at hand. I checked the hard drive and it is seated properly. I also went into the BIOS menu and did the hard drive test. It stated that there is no IDE detected. It appears that the laptop isn't reading or detecting the hard drive. I also tried using the recovery disk for windows xp but it gave an error message stating that there is no hard drive detected. Is there anything else I can try? Any help would be appreciated. Thanks again!
    Ok... i turned it on and tried to listen for the hard drive.  I put my ear to the laptop and could hear a whining sound in the area of the hard drive.  I'm not 100% sure whether it's spinning but it seems to be.  I guess we can try both ways either booting with a burned disc or the less expensive ways such as granite digital or any tricks you may know and i've got no problems opening the laptop.  Thanks again!
  • phillip_tone Jan 25, 2009
    i have the same problem. i dont know wats wrong with my laptop. i tired going to the bios and when i tryed to perform the self system check it said that the diagnostics not supportedand the test status was blank
  • Anonymous Apr 13, 2009
    Same message. Installed new hard drive. Same message again. Made sure bios was set to boot from hard drive. ?????
  • 69 Answers
Well, there are a few possibilities. First, make sure the hard drive is fully seated correctly. If it is, then try turning on the computer and going into the BIOS menu. this can usually be accessed by pressing a key that appears onscreen on boot up. in this menu, be careful not to change anything unless you know what you're doing. look for an option called hard drive test or something similar, and see if it comes out ok. If it executes, but has errors, i might have some software that may work. If it fails to find the hard drive, things get more complicated. I'd like to know how much work is needed for the laptop, so if you can get back to me if these tests work, or if the hard drive wasn't seated correctly, that would be great.
Also, I have ways to access the drive if there is a complete failure and even fails to spin up, or if it is corrupted, i have a cd you can burn to recover the data. I'd just like to know if we have to resort to those though before i explain it all, since it can be a lengthly process.
Posted on Oct 03, 2008
  • Kevin Croissant Oct 04, 2008
    No problem.
    Now, the No IDE message means the hard drive can't be detected. When you turn the computer on, do you hear the hard drive try to spin up? Put your ear to the laptop too to make sure its not a fan. If it spins up, we'll have to burn a disc and boot the computer up from it. If it doesn't spin up,, well, we have a few choices:
    Spend some money(possibly over 200$) to send it to a hd company like ESS.
    Spend much less money(about 30-50$) and buy a Granite Digtal emergency drive copy tool. I use bought one, and i use it almost every day! it provides an IDE and SATA to USB interface to access the drive directly!
    OR
    Spend no money, and you can try a few tricks i have used to try to recover the drive long enough to buy a new drive and transfer the old data to the new drive.
    If it doesn't spin up, you will almost surely have to buy a new drive, but i will be able to help you along the way transfer any settings and files over. I spilled diet coke on my laptop and was able to get everything working again!
    Also, If you are interested in the Granite Digital tool, goto granitedigital .com
    Oh, if you are not comfortable with opening the laptop or drive if we need, or not sure what to do, you can always email me or goto a computer repair shop like GeekSquad, though i haven't had the best experinces with them...
    Ok, If you could use the chat function on my site, kevincroissant . com, i can show you how to use the software. its rather complicated software, so it would be easier to be able to actually 'chat' live then post back and forth. If you don't want to, its fine, we can use this.
Toshiba nb300 windows starter won't boot. PXE-E61 media test failure. check cable.
If your computer is working fine, then disable PXE boot in BIOS or remove from 1st boot option. This is a LAN (network) boot option. It can't find a DHCP server, that's why the media test failure is displayed. It's usually used to load an OS image from network.
For the most part not a real problem. More of a warning. Some corporate models use PXE to mass image.
If there is a problem (won't boot) then it lost communications to hard drive, and you need to check BIOS for hard drive.
Oct 03, 2012 | Toshiba mini NB305N410WH Netbook
Tip
Issue:
My computer gets this message when I try to boot it:
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting Intel PXE ROM.
Solution:
Your computer is set to boot from the network (PXE = Netboot).
Go to your BIOS and make sure you boot from your hard drive.
Remarks:
Shouldn't be enabled by default
[more...]
on Jan 04, 2009 | Acer Aspire 3680 Laptop
PXE-E61 : media test failure, check For Realtek RTL8101E/8102E PCI-E Ethernet Controller v1.06 (080222) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE ROM.
The system is not finding any bootable media (Hard Drive) and is attempting to boot via the network card (PXE Boot) the error message is saying that there is not PXE network to boot from and it is exiting the process.
Generally, this is caused by a hard Drive failure. Reseat the drive and or drive connections and see if the system will find the hard drive.
Generally, a Hard drive failure
Jun 17, 2011 | Computers & Internet
Pxe e61 check cable message
"Intel UNDI, PXE-2.1 (build 082)
Copyright (C) 1997-2000 Intel Corporation
For Realtek RTL8101E/8102E PCI-E Ethernet Controller v.105 (071227)
No bootable device -- insert boot disk and press any key"
sounds like a driver issue try to go to toshiba's website and download the latest drivers for the NIC card.
Nov 02, 2010 | Toshiba Qosmio G15 Notebook
PXE-E61: media test failure check cable
"PXE-E61 Media Test Failure, System won't boot"
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration(F10)
This Will Solve this problem
May 25, 2009 | Compaq Presario-Notebook 700 Series, 2500...
Video card failure replace your video card
Feb 10, 2009 | Lenovo ThinkPad T41 Notebook
id open the hard drive bay and remove the drive and then reseat it and then try to reboot the unit. make sure the battery is out and the power unplugged when you take the drive out. if the system errors like that again its either the hard drive or the ide/sata on the mobo. after getting the system up you could use an external drive adapter to try and recover any data off that drive (really doubt itll work if drive is dead)
Feb 02, 2009 | HP Hewlett Packard Pavilion DV9500T 17"...
your e-machine is set to boot from the network (PXE = Netboot)
go to your BIOS and make sure you boot from your hard drive
Aug 31, 2008 | Acer Aspire 3680 Laptop
PXE-E61 Media test Failure
hy i have your solution.its simple. the problem is remote network data entry that start in the bios systems, produce by a virus call downloader.trojan or bootable Tj.exe, normally the bios has to read it and it gives the error " media test faliurecheck cables",ir you dont repaired quickly your laptop or desktop eventually will not boot the windows att all, this have to be kill before that happens, First of all clean your pc with Trojan Remover and then do just a simple task restart your desktop or laptop and do not let it initiate windows just press F2 at the bios and go to the Bios program and then go to the tab name Bios and press F9 that means "default bios systems" and everything will change in your bios and when your desktop or pc restart it will never show that message again and your bios will initiate with no problems and the virus that put that into your pc will no longer control your bios system.
May 11, 2008 | Computers & Internet
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
HP Compaq Presario V2000 Notebook Logo
2,721 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
